Question about Technics SL-BD20D Turntable
Very low sound from old turntable
I pluged in two jacks into my stero from turntable there is a black wire in back of turntable I dont now what to do with it runs good but very low sound
  • joe2eyes Feb 05, 2009
    My Akai D210 has a very low sound too! Do all turntables required a pre-amp ? Duane
  • 948 Answers
You need to run that black wire to ground, perhaps a screw on your electrical outlet. You also need a pre-amp with your turntable, I use the mcm 40-630 you can find it many places for sale.
Posted on Jan 11, 2009
How do I fix my sound on my acer AX3400?
Try looking in your sound mixer settings for the default audio. Make sure it is set to the stero jack and not the digital coax. altho windows is suppose to automacticly detect what is pluged into the sound card, many times it does not and will default to the digital coax. These settings are found under control pannel
Hope this helps
Feb 22, 2012 | Acer AX3400-U4032 Desktop - Black...
I've connected my turntable to my stero system. When I try to play a lp the sound is terrible. I've replaced the needle. Did not help. Any ideas?
is the vinyl clean vinyl is supposed to sound weird thats what its all about. if the records not clean it could make it sound ****
May 21, 2011 | Numark ttUSB Turntable
No sound being amplified through RCA jacks... I can hear it coming off the literal record player, barely, but when plugged into receiver, there is no sound being transmitted to the speakers. Could the...
The first thing to do is uplug the jacks and put your finger on the input to the amp. If it buzzers then the amp is working. If the turntable has jacks pluged into it pull them out and touch the end of them too!
If you can't do that, then disconect the wires to the cartridge, with the amp on touch each wire (one at a time). You should hear a buzz on two wires (left & right) and nothing on the other two. If you don't then the cables are faulty or the amp is. If you do then the cartridge has gone.
Dec 07, 2010 | Aiwa PX-E860 Turntable
My two year old put sixteen cents in my CD player. I have gotten the change out however my stero sound is not working right. I got upset and hit the steering wheel and the sound worked for a short period...
reset the stereo by pulling the fuse it sounds like it just needs reset sounds like also check the wiring on back of stereo make sure no wires came unpluged loose theres 2 power wires red and yellow 8 speaker wires 1 ground wires black
Sep 13, 2010 | 2002 Toyota RAV4
There is very low sound from turntable to teac
Check out if the earth connections are are good in the jack.
Are you connecting to a dedicated socket for turntables on your amp? Turntables have to have a pre-amp stage (unlike CD/Tape) before they go to the main pre-amp. If the Teac doesn't have a turntable socket, you will need to buy a pre-amp for the turntable.
Jan 20, 2010 | Audio Players & Recorders
How do you use aux jacks on back of radio
The aux on the back are usually outputs for amps and subs. If there IS and aux in, it is usually on the front panel and accepts a mini stereo plug.
Jul 28, 2009 | Pioneer DEH-P690UB CD Player
Low volume on PS LX250h
This turntable has a built in pre-amp, under the platter is a on-off switch. Turn it to "on".
-Former PS-LX250H owner
Dec 12, 2008 | Sony PS-LX250H Turntable
Not a good sound
you can't...the technics need to be pluged into phono..because the signal has to be amplified for it to play...phono channels on amps and dj mixers have an amp built in....
Apr 06, 2008 | Technics SL-1200MK2 Turntable
Pluging in a turntable
I dont understand why you would want to connect a turntable into your phone. Can you explain?
Mar 30, 2008 | Audio Players & Recorders
Stanton STR8-30
How did the internal wiring come out? Was it pulled, does it look like someone attempted to repair it, and didn't do a good job? Unfortunately, you have to open up the unit to see where exactly those wires were removed from. Those are the tonearm wires, which attach to the PCB which distributes the sound to the RCA cables. If those were pulled out from the tonearm, you have to have the entire tonearm replaced (not diy work). If it came loose from the board - VERY ODD that all 5 cables came loose, but it was bought on ebay, so anything is possible - you need to open up the turntable and solder the cables back (easier said than done). Yes, the black wire is the ground. I suggest you take it to a qualified service center for a diagnosis. You might be able to recover the costs from the seller. Hope you didn't leave any feedback as of yet. It might be the only thing you can hold over the seller's head.
Sep 13, 2007 | Stanton STR8-30 Turntable
Technics SL-BD20D Turntable Logo
327 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
