Question about Sansui TVS2750 27"
Horizontal White Line
Hi, I have a Sansui SV118Si TV which after about a minute of being switched on ends up with a Horizontal White Line. I have replaced the Vertical output IC (LA8470). The problem is still there. If I switch the TV off for a few minutes and then back on I get a picture for about a minute. Any ideas on what else I can replace?
    New Friend:
  • 76 Answers
In your statement i found during switch on you get picture. Check whether in a few minute picture suddenly goes to the horizontal line or height reduces and then goes to line. If suddenly goes means change any zener diode in pumpup circuit. If it is not means LA 7840 ic getting imbalanced supply voltage i.e.,negative and positive voltage are not equal. Suppose only one vcc means supply resister getting high ohms and change the the supply resister.
Posted on Aug 24, 2007
    Novelist:
    Champion:
  • 236 Answers
Sounds like something is getting hot causing voltage loss or drive pulse loss to the vertical IC. Maybe you have a bad solder joint. Try tapping the circuit board around the vertical section. A capacitor could be heating and opening up. Stargazer Also you might try using circuit cooler spray and make the problem show up.
Posted on Apr 23, 2007
SOURCE:
Where is horizontal scan out put section?
Hi Majid
Just contact any service technician to repair your TV. It will be best for you.
Gopakumar Gopalan Google
Feb 01, 2015 | Televison & Video
Tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
TV MODEL :SANSUI HARD ROCK 21'' PROBLEM : TIME TO TIME ONE HORIZONTAL LINE COMING WITH BLACK SCREEN
Hi The problem of your teevision is what we called the vertical line problem.The problem is in the vertical section of the board.There are many of cause of that problem.First is either loose connection,the circuit at the vertical section have cold solder so its need to resolder using soldering iron.Second,it maybe no vertical supply,its better to check the 12 volts dc supply of vertical ic output.if thers no supply in the ic,there a open resistor near the flyback.try to replace.Third if theres no loose connection and have a voltage supply the problem is either leaked capacitor or deffective vertical ic output. Commonly in that problem is the loose connection,try to resolder the verical section.
Jul 12, 2011 | Sansui DTV2760 27" TV
I have about an inch to inch and half of light colored and looks to be horizontal line at the top of the screen on every channel. Haven't tried anything to fix at this point.
Hi there ! If you know technically try this :
1. try to adjust manually the trimmer at the vertical and horizontal section of your tv (located inside)
2, check for possible cold solder and try to fix it by using soldering Iron and soldering pump.
3.there maybe a change value of resistor inside the horizontal Section.
4. An open and leaky capacitor might also be the cause of Horizontal line at the top of your tv screen . thank you.
Feb 06, 2011 | Sansui 27" TV
Solid white horizontal line
Horizontal line WITH SOUND is only vertical output stage problem.horizontal line without sound is osc problem.So kindly verfy that.If h line with sound then
check vertical ic and ver supply voltage.
Aug 02, 2010 | Sansui DTV2700 27" TV
Tv not showing picture but just horizontal line.
Failure of vertical output. Check vertical output components.
Jul 06, 2010 | Sansui DTV2760 27" TV
Describe your Sansui DTV2760 27" TV Problem Loss of picture. A very thin line goes across the screen.
vertical line = bad horizontal output transistior
horizontal line = bad vertical output transistor
Oct 05, 2009 | Sansui DTV2760 27" TV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Sansui tv sv2918
replace vert IC301, C432, ( D431 & R431 should also be blown)
Jun 18, 2008 | SansuiM1315 TV
Sansui TVS2750 27" Logo
292 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
