Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Clicking of the burner ignitors
I have a GE profile gas cooktop. After cleaning it today, the burner ignitors won't stop clicking. How can I get them to stop?
I pulled out the electrical cord and then let the system dry out for about 8 hours. When I plugged in the oven again, the clicking had stopped.
Posted on Dec 27, 2008
My GE Monogram 5-burner gas cooktop has a constant buzzing sound. The cooktop is working properly, but the buzzing is annoying.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 23, 2010 | GE Profile JGP636 Gas Cooktop
We have a GE free-standing range top. I spilled water everywhere when my pot overflowed, and the clicking noise will not stop. All burners burn though, what to do?
This is a very common problem when moisture comes in contact with the ignitor. The ignitor sometimes stays in one position causing the clicking sound. it will eventually wear itself out. Best thing to do is try to take it apart, clean it, dry it and adjust it if necessary. If that doesn't work for you, then the ignitor may have to be replaced. Good luck
Jul 11, 2010 | GE Profile JGP636 Gas Cooktop
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
Ge profile gas range. one burner with no clicking and no ignition
You may have a bad burner switch. If you turn one of the other burner switches to make the spark modules spark look and see if the electrode is sparking at the bad burner. Most of the spark modules send a spark to all 4 burners when activated. If it sparks when another burner is activated open the valve and see if the burner will ignite. If so you probably have a bad burner switch.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The electrodes are ticking when we turn on the burners
THAT IS THE IGNITOR FOR THE GAS. TURN THE KNOB JUST BEYOND THE START POSITION AND IT SHOULD STOP. IF NOT UNPLUG THE STOVE AND FIND THE IGNITOR ON THE BURNER HEAD AND CLEAN IT WITH A SOFT TOOTHBRUSH. PLUG THE STOVE IN AND IT SHOULD STOP CLICKING
Aug 22, 2009 | GE JGP975SEKSS Stainless Steel Gas Cooktop
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
GE Profile Gas Cooktop
Do you hear the spark ignitor trying got light the burner?
If not, then make sure there is not a residue or film of cleaning solution on the burner bases or burners themselves. It could be coincidental that the spark ignitor failed when she just happened to be cleaning the unit.
Jan 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
261 people viewed this question
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
