Question about Hitachi Televison & Video
I have a older hitachi ultravision projection tv and it is giving me a slite dual image on the screen almost like its out of align.
  • 1 more comment
  • gearheadx Dec 26, 2008
    I have replaced one of the ic. How do you realign it
    The model # is 50UX26B
    Were are the knobs located to align it
  • Hitachi Master
  • 19,396 Answers
Here is convergence alignment procedure for older hitachi projection TV.
If the convergence is badly out of alignment, and the alignment procedure does not fix it, that is because there is an internal fault, either convergence IC, or the faults listed on website below.
HITACHI
Posted on Dec 27, 2008
    Genius:
  • 2,920 Answers
I have an hitachi too but mine works....the controls for aligning it are in front behind the speaker casing..
  • 505 Answers
There is a switch you have to push inside the tv. this gets you into alignment mode. theres a lot of buttons you need to be exact on so you don't accidentally erase the data. you should get a service manual before you procede. to get to the button, open the front panel (take off speaker grille) and take out 4-6 screws on the board behind grille. inside on the front most part of the circuit board youll see a tiny switch... its on the left side when you look into the front. don't touch anything but that.. if you click it the screen will change to convergence lines.. the button gets you back out. to move adjustment positiions use 2, 4, 5, 6 like the arrow keys on a keyboard.. use the joystick or arrows on the remote to move data. 0= red
input = blue
cc = green -- or some other button by there...
*be careful.. if you hit the pip buttons you will save or erase data.
remember mute button always goes back during saving
ie - if you hit pip mode and it says rom write, push button again to write data ... if you hit it and you get rom read !!!push mute to go back!!! so you dont erase everything.. you can use this to trial an error to find out which pip button will save..
service manual will work best
Posted on Dec 26, 2008
  • thielectronick
    thielectronick Dec 26, 2008
    i doubt it has any knobs.. hitachi has used microprocessor controlled convergence alignment for the last 15 years i believe.
  • thielectronick
    2.7.5 Convergence point adjustment
    Adjustment preparation
    (1) Select color to adjust.
    “INFO” - Green
    “0” - Red
    “ANT” - Blue
    (2) Use 4, 6, 2, and 5 to move the cursor position
    (dotted lines).
    (3) Use thumb stick to move the convergence point.
    (7) When convergence is acceptable, press PIP MODE
    to write data to ROM memory. ROM WRITE? is
    displayed to alarm system that ROM will be
    overwritten with new data. Press the PIP MODE
    button again to write displayed data to ROM.
    (8) DATA WRITE TO ROM will take approximately 4
    seconds and no picture will be displayed.
    (9) Green dots will be displayed when operation is
    completed.
    (10) Press MUTE to return to convergence pattern, then
    confirm again convergence is acceptable.
    (11) Press PIP MODE (ROM WRITE) mode, then press
    PIP CH to initialize sensor data positions.
    Master:
  • 479 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm click the link
-========-======== You can try getting into it and if so, try adjusting the color, contrast, etc. once you enter.
You can find out how to enter by going to this site:
http://www.fixyourowntv.com/servicemenu.php
If that does not help, you may find the video processing and color separators, drivers or matrix is all messed up.  This is usually a function of what is loosly called the "jungle chip".  A big integrated circuit that manages all these things.  The problem area could be within the chip itself or the hundreds of components that hang outside the chip.  A tech will need to take measurements to find out the real problem area, in this case.
Does this help?  The set is getting along in years. You may think twice about pouring much money into it.
  • 100 Answers
It can be realigned by adjusting the small knob like buttons on the board or else u will hve to replace the convergence part.
  • Hitachi Master
  • 5,138 Answers
Replace both STKs-- STK392-110s do not hold up need to up grade to 180s and you need to ck low ohm resistors around ICs.if they are 020s use 040s.How to aline convergences on TV depends on model number.What is your model/chassis it will be on back of TV.
  • ladywinn
    ladywinn Dec 27, 2008
    I am wondering how many on this web have A Degree in Electronics?
    Scholar:
  • 61 Answers
Before replacing the main board IC, go to the manual for your t.v. an see if you have a way of adjusting the convergence (alignment of the three lenses that make up the Red, Green, and Blue colors that give you millions of color options). Read back in a sec and I will give you a link to the manual.
  • 1Guru
    1Guru Dec 26, 2008
    can you give me the model number of the T.V.?
    Sergeant:
    Novelist:
  • 327 Answers
The ic on the main board needs to be replaced and it needs reallignment to make it  proper.
I'm not getting any red in my picture on my hitachi rear projection ultravision tv
A model number would help here but if it is older and uses 3 picture tubes carefully with the back off and set on does the red one come up and produce a red image?
Dec 12, 2012 | Hitachi Televison & Video
My 61" Hitachi UltraVision has
hello my name is rico, you have bad convergence problem. you need to replace the stks inside the tv, and look for colder on the boards. you gonna need a gun solder, solder, chawick, 2 stks(look in the tv for the number loooks like stk392-120 o something like it) look for bad fuses. that should fix your problem. if you need more help let me know at 602-810-7149.
Jan 07, 2011 | Hitachi 61SDX01B 61" Rear Projection...
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi Ultravision Projection Tv problem
Hitachi TV also Model # 46UX7K, Serial # W1H002013. I was hoping I can get help with this one too. The picture is dark and has lost most of it's color. I don't know if the color is off because it is so dark. Is there parts that I can buy from you to fix this problem.
Aug 09, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Remove screen from Hitachi Ultravision
underneath screen remove screws holding screen in place ,it should then slide upward and off.
Dec 08, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Can`t get clear picture anymore
Hello dhack56,
Can you post a picture of the screen as the TV is playing, this way I can see if the picture is fuzzy, or if the images are split, all of which classify as not a clear picture. A picture of the screen will help with the diagnosis.
Thank you,
Shuttle83
Oct 02, 2008 | Hitachi 53UDX10B 53" Rear Projection...
My alignment is off on the picture
If you can reply to this same post and Include your model number of your Hitachi I can assist you with what you will need to get the set operating properly again, as its your Convergence amp Ics Its a very easy an inexspensive repair that you can do yourself and save about 400.00
Jun 19, 2008 | Sony KP-41T65 41" Rear Projection...
Red outlines in the picture
somewhere in the tv menu there is a place to make video adjustments. one should be for aligning the color guns. one is for red and the other two are green and blue. it will give you a cross in the center of the screen. it should also give you prompts to adjust the lines for centering and to save changes. this happens eventually on all rear projection tv sets.
May 02, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
29 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
