Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
GE g2220iephww Refrigerator too warm at top, too cold at bottom.
After defrost the fridge works fine for about a month, then begins to warm in both compartments at the top, and get too cold on both compartments at the bottom. No great amount of frost in freezer side at time of defrost. I also don't put the food items in front of the cooling device at top, or touching the sides of the appliance. The appliance is kept reasonably full at all times, but not overflowing. I can also hear the fans working just fine. I no longer use icemaker as it is too annoying at time of defrost (but it's use make no difference in time between defrosts). The doors seal fine, and no lights stay on while closed.
Suggestions on where to start repair, or just throw in the towel and move on? Thanks!!!!
    President:
  • 1,214 Answers
If you are manually defrosting by turning the refrigerator off or unplugging to defrost, then you've got one of the following -
1) Defrost heater has failed
2) Defrost sensor has failed
3) Defrost timer/refrigerator control has failed.
As ice builds on the evaporator, if not defrosted properly, the accumulated ice restricts airflow through the evaporator, which reduces air flow and air velocities through the box. Lower velocity allows the cold air to fall to the bottom of the box, warmer air to the top of the box.
Posted on Jan 15, 2009
GE 17.2 freezer on top fridge on bottom. Freezer is cold, but fridge is warm. Help!
Is there any frost buildup on the rear panel inside the freezer? If so you have a defrost problem of a bad defrost heater, defrost thermostat, or defrost timer/ control board. If no frost then you probably have a clogged defrost drain. Remove the rear panel to access drain hole.
Nov 09, 2011 | GE 17.2 Cu. Ft. Top-Freezer Refrigerator
Top too warm bottom too cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 22, 2011 | GE Profile PDS22MHR Bottom Freezer...
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
heatman101
Dec 26, 2010 | Refrigerators
Freezer working but refrigerator is not cooling
if freezer is close to zero, top to bottom, and fridge is warm(ing), then you likely have a defrost problem, you will notice an abundance of snow/frost on back wall of freezer. it could either be your heater, thermistor, defrost safety thermostat, or your defrost control/main cpu, depending on model. if either or both sides are warm at the top, and cold at bottom, then your freezer fan is out. again depending on your model, it may just be the fan, or a combination fan/main cpu board hope this helps
Feb 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model PDS22MBRABB bottom mount
These fridges were made by LG they are very problematic, the defrost cysle does not work properly due to board defects and the fridge freezes up, I have replaced my board twice and the fridge has worked properly for 6 months max them the board shorts again, I talked with the LG rep he said scrap the fridge they are ****.
Nov 06, 2007 | GE Energy Star PDS22SIS Stainless Steel...
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
300 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
