Question about PNY Verto GeForce 8500 GT 512MB DDR2 PCI Express Graphics Card
Geforce 8500 GT dual monitor second monitor goes dark
I normally plug my second monitor into my xbox 360, then when im done with it, i plug it back into my computer. this last time, the screen went a weird dark blue/black tint. I tried swapping the monitors, via changing the cords from one to the other, and i thought it might be the cords, after the monitor color darkness changed. So I changed cords, no luck.
I went into the nivida control pannel on my computer, and found when I click ''clone view'' the monitors color both stay the same brightness, but when i hit ''dual view'' the second monitor goes black.
  • skarabee Jan 05, 2009
    I connected two identical TCL (kingston Tecknology) on my new Core2duo/Vista, and when I choose dualview (clone or differencied) my first monitor goes black, and the second is not recognized, and the PC hang on...must reboot :(( tried to inverse the monitors, with only one, DVI or VGA, it's good, then I plug the second, and same scenario again...
SOURCE: Nvidia GeForce 8500 GT
Have you removed the old drivers and reinstalled the new ones... i.e right click GeForce 6100, uninstall, then reload the drivers you got with the GF 8500
Posted on Jun 30, 2008
ZeroCool2u
  • 15 Answers
SOURCE: GeForce 8500 GT installation problrm
Try looking for a message in the BIOS startup screen usually delete or an "F(X)" something button i.e. F1 or F2 That says it will let you chose your boot device. If you can than press that and chose the hard disk option. If it doesnt let you or it doesn't work than theres probably something wrong with your hard drive and I doubt it has much to do with your video card unless the driver caused it. In that case try starting your computer in safe mode by pressing F8 after the BIOS startup and selecting safe mode and then uninstalling the driver from the change/remove applications part of the control panel. Of course if none of that works you could just yell and swear at HP until they help you. :)
good luck
Posted on Jul 04, 2008
geokohler
  • 304 Answers
SOURCE: and the screen goes blank...
Enter bios setup and select restore factory defaults. If this does not work get back to me
Posted on Jul 15, 2008
babygenius55
  • 96 Answers
SOURCE: poor tv output
Download 'media player classic'. you can resize on the fly with the number keypad. 5=reset
Posted on Nov 26, 2008
SOURCE: nvidia geforce 7300 se 7200 gs
i hav nv7300 gforce graphic card it is not work very well with explod pro transition why
Posted on Nov 04, 2009
HP W2007 + Xbox 360 = Constant Sleep Mode
the monitor is bad
if it will not power on,
or show NOSIG< with XBOX on then turned off the monitor must show NOSIG>
why not test the monitor on any pc made even laptops VGA jacks works, so that works, its not the monitor.
and bad xbox video caused. but is not it. as you said.
the menu needs sync lines active. to pops the OSD button menu.
so the monitor is bad.
or the cable.
what is w2007, lets see.?
its old. at 1680 x 1050 @ 60 Hz
this old monitor runs CCFL lamps.]
im shocked it glows at all up to now.
ever do flash light trick test?
see got data, but no back light, CFFL is dead.
HP W2007
users guide last page.
This HP product contains mercury in the fluorescent lamp
in the display LCD that might
require special handling at
end-of-life:
that means CCFL died, also all do, soon.
(as short as 2 years, full time , they die. 20k hours)
out of your service manual it shows.
ccfl-wcj1avqu0msqxnqr1cdquwfl-1-0.jpg what any running pc connected the OSD menu most work
not in sleep mode.
if there is sinc, H/V pins active
that OSD must work or the blacklamp is dead
use flashlight see, there is data there, see?
Sep 09, 2017 | HP W2007 LCD Monitor
Tip
Xbox 360 Tips
Ok guys we all know that the 360 was rushed and it has many glitch's on games, So im going make a 5 golden rule for the xbox 360 cause im sick of the same questions over and over...
1. If one game dosnt work try another game and see if it has the same problem.
2. Make sure that all cables are plugged in correctly.
3. If a game crashs and continue's too. Then replace it and see if you get the same problem.
4. Let you xbox have breaks for example.. Dont over use it cause it will burn out in the end.. So dont leave it on for 4 hours doing nothing cause ur wasting its life..
5. Ok guys this is the most importent one of all!!!. You your head.. If somthing goes wrong think why has it done that and try to solve it for yourself!! It feels good trust me... Or if you cant be bothered... then send me a messege. lol..
Well thank you for looking at this guys.. Im allways here to get you back on that train.
Cheers.
on May 09, 2010 | Video Game Consoles & Games
I have an HP Pavilion Elite m9200z. A while back it just refused to turn on completely. I tried replacing the power supply but had the same result. I was told to try reseeding the ram. In order to do so I...
From your description, it would seem that the monitor itself could be the problem. If you have a second monitor, try to plug that in and see what occurs. If you have a display, you have located the problem. You may also try to go to the BIOS and disable the onboard video, so that the GeForce will load. It could be conflicting with the onboard video.
Let me know how you make out,
Joe
Sep 27, 2011 | HP Computers & Internet
Free download Installation geforce 8500 512 bm
Download the driver here at nvidia:
http://www.nvidia.co.uk/Download/index.aspx?lang=en-uk
Select:
1.Geforce
2.Geforce 8 series
3.Geforce 8500 GT
4. Your operating system 32 or 64 bit
5.Language
6.Press seach and download and install.
Hope this will help you.
Mar 22, 2011 | XFX NVIDIA GeForce 8500 Graphic Card
Dual Monitors. #1 works fine. Plug inb #2 and #1 goes to sceeen saver and #2 stays blank.
Both monitors must be plugged in when the computer is started for the second monitor to be detected, and you must configure the second monitor once the computer has started
In windows XP: control panel -> display -> settings tab -> select second display -> check "extend my windows desktop onto this monitor" -> click apply
In windows vista/7: control panel -> adjust screen resolution -> select second display and then under "multiple displays" select "Extend desktop to this display"
Mar 08, 2011 | Acer AL1917 LCD Monitor
Monitor goes blank.
Did you swap the monitors to see if the problem follows or stays at the same video output port since you have dual monitors set up? Need verify before opening up the monitor.
Mar 30, 2010 | Gateway FPD2275W LCD Monitor
Im trying to hook one of these up to an xbox 360, is it possible to do so via hdmi cable, or just via vga?
hi if you have an xbox elite the you can do it via hdmi cable, but if you have the normal xbox360 then its just the vga plug ime affraid hope this helps
Feb 22, 2010 | iiyama ProLite E481S-B 19" LCD Monitor
World in conflict not running on vista (legitimate version)
Do you meet the specs?
  • Operating systems: Windows XP or Vista (32-bit)
  • CPU: 2.5 Ghz or Faster (2.8 GHz for Vista)
  • RAM: 1 GB (1.5 GB for Vista)
  • 2.5 GB of free HD Space
  • Video Card:128 MB Video RAM, DirectX 9.0c Compatible (GeForce 4 MX, Radeon 8500, 9200 Not Supported)
  • Sound Card: DirectX 9.0c Compatible
May 31, 2009 | Sierra Entertainment WORLD IN CONFLICT PC...
Nvidia gedorce 8500 gt and the cpu gets overheated and shuts down
well it might be over clocked, but i have a computer with 4 fans and cpu fan and other fans to. though this still doesnt make a difference casue my cpu still heats up. so get a liquid cooling system, expensive i knw but it will keep your computer running, but you coudl also try cleaning you computer out. Like all of the dust and everything
Apr 26, 2009 | XFX NVIDIA GeForce 8500 Graphic Card
Xbox 360 playing music
plug it into the xbox and select an option on it that is `normal` it is probably on intro.
May 22, 2008 | Samsung YP-K3 MP3 Player
PNY Verto GeForce 8500 GT 512MB DDR2 PCI Express Graphics Card Logo
344 people viewed this question
Top PNY Computers & Internet Experts
David
David
pankaj rautela
pankaj rautela
Alun Cox
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
