I don't know if this is the same problem, but I know a site whom is dedicated to htc phones. You can try in here and see i=f they can help you. www.htcimeiunlockcodes.com/
SOURCE: my htc hd2 phone has just stopped me from using
Well you can click on start then settings go to Today then Items and see if the Htc sense is checked or not. It should be checked and your problem will be solved. If still no help then you can hard reset your phone. Method to do Hard Reset is turn off your phone and while holding the volume keys up and down press the power button and it will take you to the hard reset screen now if you press volume up then you phone will be hard reset and come back to factory settings but you will loose all the phone book and other data on the phone. I hope this will help.
SOURCE: Where do find a free code to unlock my HTC HD2
As far as I know free codes does not unlock your phone, so even if you would find a unlock code or whatever you'd have to spend some money.
I would recommend the Unlock-Zone.com site is nearly perfect and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
SOURCE: HTC HD2 not "booting up" I have an HTC HD2
take it to your service provider they will fix your problem on the spot usually or order you a new one free of charge. -Derek
SOURCE: I have an unlocked HTC HD2 and I want to use it in
Here's the fastest way to unlock your phone... just visit this site http://www.imeiunlockcode.com you can purchase an IMEI unlock codefor your Blackberry, HTC, LG, Motorola, Samsung or any other GSM phoneand unlock it in seconds. its 100% safe (no loss of data or contacts).All you need is type the IMEI unlock code and your phone is 100% SIM lock free.
SOURCE: hi, i have smashed the glass screen on my HTC HD2
HTC might help you with this because it is so new. However if you dropped it (etc.) and if HTC doesn't replace it for you, You can get the part at HTC HD2 Repair and there is a guide that shows you how to put in the part at HTC Repair Guide.
thanks help me a lot
