Question about Baumatic MEGAWDSS Front Load Washer / Dryer
Baumatic megaWD55 Washer Dryer - How Do i work it??!
Hello, i was wondering if you managed to solve your washing machine problem??? I have the same machine and cannot start it atall. i've tried lots of different settings and everytime i press start, the door locks but it does not start. Thankyou for your time and if you can help, please email back. I do have a manual for it but it does not help me... i was looking for advice from someone using one first-hand. If you still need a manual, i can send you a copy. Thanks.. Leanne
3 Suggested Answers
SOURCE: Baumatic BTWM6 washing machine flashing F02 error
hi, you need to empty the filter, ours does the same all too often. The filter is located bottom right of the machine at floor level, which is rather daft for an integrated applicance; we have to remove a whole length of plinth to empty ours. Be warned, a lot of gunge and water will come out so have towels at the ready, especially if you have a laminated floor. Turn the white slot with a a 10p piece......and empty. Not the most pleasant of jobs, but effective. Good luck!
Posted on Mar 18, 2009
SOURCE: Baumatic WD55 Washer Dryer - How Do i work it??!
  1. how does the dryer work
Posted on Oct 26, 2010
I have no instructions on how to installa baumatic bwr 1206 wasing machine
Hope this helps :)
http://talkappliance.co.uk/downloads/?sa=view;down=103
Apr 23, 2012 | Baumatic BTWM4 Front Load Washer
My aeg lavamat L washer/dryer has suddenly stopped working and there is no power
Sorry this isnt a solution .. Im just wondering if you did manage to get this sorted as it happened to my machine this morning?
Feb 17, 2012 | AEG Lavamat 16810 Front Load Washer/Dryer
Beaumatic washing machine says fault code co3, what does that mean
machine is out of balance. Manual below. www.ecowashinglines-blog.co.uk/.../Baumatic-Fully-Integrated-Full-height-Washer-Dryer-BWD12.1.pdf
Mar 18, 2010 | Washing Machines
F02 Baumatic error not cleared Even when filter cleaned...?
Perhaps you need to check the outlet hose from the pump for a blockage, and of course, make sure the pump itself is working.
Jan 17, 2010 | Baumatic BTWM4 Front Load Washer
Baumatic washer draining but not spinning
I had this problem, may be an easy fix if similar issue: Remove back cover. Take a look at the underneath the drum towards the right hand side. There may be a hook on a wire hanging there. If it is just hanging, there, it should be hooked onto a grey coloured lever, which has a hole on the edge of it. This is the drum brake which during the spin cycle releases the brake allowing the washer to spin. Hook the hook onto this grey lever through the hole. Replace the back cover. Test the machine with a towel or something, allow it to fill a little, then jump to the spin setting and see if it spins. Worth a shot, these are great machines.
Sep 05, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic megawdss leaks in front when wash cycle starts. How do I fix this?
The front door seal is bad,check to see if there is anything jammed up inside that seal,money,ex,ex,lint
May 07, 2009 | Baumatic MEGAWDSS Front Load Washer /...
machine needs to be on half load for dryer to operate
Dec 26, 2008 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic MEGA WDSS washing machine
go onto manualtree.com type baumatic megawdss washing machine, if this does not bring anything up scroll down until you see it in the listings. type in the code it asks for (this will be supplied underneath, its just to stop cumputers auto logging) and then download then manual. good luck
Jul 02, 2008 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic washing machine instructions
the twelve programs are explained on the detergeant drawer.if not i will post them for you.
to use the dryer turn the middle knob clockwise to the amount of time you desire upto 140 minutes then select the temperature on the far left knob and then depress the half load button your dryer should now work.
Jan 11, 2007 | Baumatic BTWM4 Front Load Washer
Baumatic MEGAWDSS Front Load Washer / Dryer Logo
Top Baumatic Washing Machines Experts
Marvin
Marvin
NOEL
NOEL
TriciaGirl
Level 1 Expert
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
