Question about Toshiba 57H82 57" Rear Projection Television
Video Inputs are scrambled
When ever I try to use any of my video Inputs(DVD, VCR, Nintendo) the picture is Scrambled, I have tryed all the inputs with the same result. is there some kind of video card that all the inputs go to, that might have gone bad, or is ther something I can adjust, to correct this problem.
4 Suggested Answers
SOURCE:
  • 67 Answers
SOURCE: other inputs not working on rear projection toshiba
check for progressive scan and interlaced setting also verify if you have component hook up that it auto maticall chooses your resolution because if your tv is waiting for 1080i and you send 1080p it will not always work and if it expects 1080i and you send it 480i(s-video or rca connection) it may not automatically flip
Posted on Apr 14, 2009
  • 157 Answers
SOURCE: picture is scrambled until it warms up. Can play
unit has a bad hyper module,NLA thru toshiba.try contacting tristate module or pts to see if they still rebuild them.toshiba part-23786198,MVPU13,PD0264A
you mite have to search to web a bit to find one if they dont rebuild them anymore.
Posted on Sep 29, 2009
  • 1030 Answers
SOURCE: basic cable scrambled on ANT input but not PIP
it sounds like you have the common problem with these models. The poblem has occured so offten that toshiba issued a service bulliteen about it. There is a problem with a cuircit board called the Hypermodule its a signal processing board/ the ideal situation would be replaced this board but it has happen so much it may be difficult to find this ooard so this board can be repaird. The secound problem is to fix this board 11 very very small parts called capacitors need to be replaced. i have also replace these and only someone advance in solder should attempt it very small. twezers and magnifer. You can hire someone but it very labor intensive. Our shop charges 300 just in labor It can be fixed but I would adviise its just no worth it
Posted on Dec 10, 2009
How to program the autio vidio inputs for zenith tv
Hi cathie
If you have sound it means that the tv is in aux/video mode.
Now make sure that the video output of the vcr is connected to the same aux/video input that has the sound connected to. i.e input 1 or 2 .
Also you want to try and switch with another cable to make sure that the cable you are using now is o.k.
Another way to try the tv input would be to connect something else in that input(cable box ,dvd ,video game etc,)
Try it and let me know.
Feb 02, 2010 | Televison & Video
Video camera inputs get srambled as unit warms up
Try with new 5.23 Software. If you still have the problem send it to Raymarine.
Some E 120 series had problems with the Videoinputs use the warrenty as soon as possible.
Oct 25, 2009 | Raymarine E120 Multifunction GPS Receiver
Picture is scrambled until it warms up. Can play DVD without any issues, but all other video inputs are scrambled for 30 - 40 minutes.
Sep 29, 2009 | Toshiba 42H81 42" Rear Projection...
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Scrambled picture with DVD or Video Game
You have a bad digital board. Expect to spend some serious money to repair this.
michtech
Feb 20, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Toshiba 50h12-reception problem with ant 1 & 2
the tv has a built in decoder. if its scrambled it may be on the wrong setting. try resetting tv to factory settings and see if it sorts its self out. if not it may need the av board changing as it has a fault with the decoder chip.
May 23, 2017 | Toshiba 50H81 50" Rear Projection...
When I want to watch something whether it be Cable, a movie, or video games the screen only stays clear for 4 seconds then it scrambles. Not only that, jumps from being scrambled to going to "no...
you have to go into the settings of the video card and change the "signal" from the one you are using now, this could be RGB, S-Video, Composite, Digital or Analogue, flick through these settings until you find the correct signal
kind regards
Nov 25, 2008 | Computers & Internet
Recording from my vcr to the dvd hardrive
It may be that the tape you are trying to record from is copy-protected. You will then get a "scrambled" picture
Nov 04, 2007 | Wharfedale DVD-M3 DVD Player
VCR DOES NOT WORK WITH NEW CABLE BOX
If you can get some of the stations without the box (often the case for those who subscribe to digital cable or movie channels), then one setup is to split the raw cable and feed the box and the TV, then have the box feed the VCR and hook up the VCR composite video and line level audio outputs to the TV. The VCR tuner would always be set to the VHF frequency your cable box RF output is on, usually ch. 2, 3 or 4. This setup allows PIP to work, with the TV tuner limited to unscrambled analog stations, and it also allows you to tape anything coming through the box, while watching unscrambled analog stations on the TV. However, it requires the VCR to be on and the TV set to the external video input to simply watch what is coming through the cable box. There are other ways to set this up with more flexibility using splitters and A/B switches, or you can look for a special switch box that handles the job. The above assumes your TV has composite video and line level audio inputs. The only way to have full flexibility to watch any scrambled or unscrambled station at the same time as taping a scrambled station is to have 2 cable boxes. The only way to have your VCR control the cable box and record different programs by switching the box by itself is to have a VCR with a cable box controller, also known as a cable "mouse". Hope this helps
Dec 15, 2005 | Quasar VHQ720 VHS VCR
Toshiba 57H82 57" Rear Projection Television Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
