Question about Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117
Start to weld a few seconds, HLP comes up on display, and arc sto
When starting to weld alum. arc will start for a few sec. then stops and HLP comes up on display
  • indtech May 11, 2010
    what is the number to the right of hlp, this will tell you the help code
  • Carl Gehrke
    Carl Gehrke May 11, 2010
    The other display should have a numeric code that specifies exactly what the welder is shutting down for. Your manual has a nifty chart that explains what to do for each of the HLP codes.
    Regards,
    Carl
4 Suggested Answers
  • 87 Answers
SOURCE: Hi, starts to weld fine after a few seconds hi
It sounds like you need to change out your SCR chip on your motherboard; Miller makes one that i have installed on all our 350xl's, I don't have the number on hand but i can get it for you tomorrow.
Posted on Oct 20, 2009
Testimonial: "appreciate the help."
mxtras
  • 194 Answers
SOURCE: I have a miller microwave 200. what settings
I think you mean you have a Miller Synchrowave 200.
Typically, you would want to use AC below about 250 amps. In this case (to keep it simple), use AC, adjust your balance to about 4, use an 1/8" pure tungsten, pure argon at about 20CFh, and set the panel at 170amps to get things started. For general purpose, use 4043 filler.
Now - these are just generic settings, but they will get you going.
Posted on Jan 12, 2010
  • 691 Answers
SOURCE: why is my arc unstable when I start Tig welding? Sometimes it starts nice and smooth and sometimes it blasts really bright and flashes me.
The tungsten point has to be quite sharp, the gas has to give constant flow relative to the tip size and shroud and the amps adequate to create a spark without immediately making a mess of the parent metal. The two most common issues will be the cleanliness of the parent metal and the Gas flow. Assuming you have all this set up, it actually sounds like you have a problem with your mask as you shouldn't get flashed at all.
I had a similar problem once with a solar powered auto mask because the batteries had died and wouldn't recharge. I retro fitted a couple of button cell 2032 to the mask and it's working fine.
Posted on Apr 25, 2012
Tip
What are 4 common welding processes?
There are four common welding processes utilized through out the work industry today. They are :
(Stick Welding or SMAW) Shield Metal Arc Welding
(Mig Welding or GMAW) Gas Metal Arc Welding
(Tig Welding or TMAW) Tungsten Metal Arc Welding
(FCAW) Flux Cored Arc Welding
There are many many welding processes, however these are the most common. The type I am going to discuss briefly today is SMAW. The most economical and cheapest way to learn if welding is for you or not is to start with stick welding. It has the least amount of variables that can go wrong for a beginner. It is not fast paced like mig or flux core, so you have time to watch the molten puddle to see what it is doing and make necessary adjustments to correct the size, shape, and contour of your weld bead. The hardest part for a beginner is to keep the electrode from sticking to the work piece. Thus is the reason it got the name of "stick welding". There are three common ways to strike an arc in SMAW. Tap Start, Scratch Start, and the last is to place the electrode upon your fingers like a pool cue, and shoot the rod like your playing pool.
on May 31, 2010 | Welding Tools
What electronic part is damaged?
Does the electrode stick to the metal? In which case your problem is with the elctrode or your method of striking the arc.
Jul 24, 2013 | Welding Tools
I have a dynasty 300dx serialno kk330787.in ac tig process the hf spark is not continuous.it works like pulse.after a few attempts it works correctly.but when i stop for a few seconds the machine does the...
Hi there, Hf is used to soft start your arc so you don't have to scratch the metal with the tungsten.Then it shuts off for the next start.Thank you for trying FixYa.com
Jul 03, 2011 | Miller Welding Tools
I have a miller sycrowave 250DX i have been tig welding for about 10 years i bought this machine 2nd hand hoping it would work ok when i weld in AC and hq the arc seems like it just wants to stop it...
Did the machine ever work properly? I am assuming you are using a remote for tig welding. If you watch the points, does the HF stay on after the 5 to 10 seconds as you stated. It should stay on as long as you activate the machine. Make sure your Start Mode is in continuous. See page 42. Since there are so many options, check page 34 for help setting the options. If you still cannot get ti to weld properly, contact Miller for service. https://www.millerwelds.com/files/owners-manuals/O363AU_MIL.pdf
Aug 29, 2017 | Miller Electric Manufacturing Electric...
WHEN I TRY STRIKE AN ARC WITH A ROD YOU HAVE TO HIT IT 5 OR 6 TIMES TO GET IT TO WELD ITS HARD TO KEEP IT GOING BUT AFTER 4 OR 5 SECONDS IT WILL BURN LIKE NORMAL (USING PROPER AMPERAGE)
Is this on new rods as well as one's you'be been already welding with? Depending on rod types, some will "flux over" the end, after welding insulating the tip. When you're welding at a low setting, with a small rod, sometimes it is hard to start an arc. A 7018 rod is a good example of this. Strike the rod like a woodden match, or drag it on the metal, to expose the rod. It also depends on your welder. Some have settings to help start an arc and then control the current. Older transformer welders arn't that smart and are less forgiving on low current thin metal settings.
Jul 02, 2010 | Lincoln Ranger 250 Gxt Welder Generator...
I have a miller microwave 200. what settings should i use for aluminum welding? dcep, ac, dcen? i'm using a3/32'' tungsten and trying to weld on 1/4'' alum plate. the weld is not turning out to be a smooth...
Jan 12, 2010 | ARC Welding Secrets Book - Mig/tig/oxy/arc...
Oct 20, 2009 | Welding Tools
Bad tig weld job
Wow you have a lot of variables here. Let's go over some of them.1.AC current 2.100%argon shield gas 3.Check your Tungsten, it must be the recommended 1or 2% and the right size, clean and the tip rounded by meting 4. High freq. turned to continous-not just "START"
5. CLEAN,CLEAN,CLEAN your Alum. with a S.S. brush that has touched NOTHING else in in it's life!
Start here and GOOD luck
Dec 18, 2008 | Welding Tools
GIANT 200AMP INVERTER ARC WELDER NO POWER TO THE LEADS
remove the fan from the circuit and try it then, does it weld ok with the fan removed?
Dec 13, 2008 | Inverter 220 Volt Tig Arc Welder
Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117 Logo
157 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
