Question about Toshiba Refurbished TECRA 510CDT P133/32MB/2.1GB/CD/TFT (PA1232UT2A) PC Notebook
No windows system
I bought a reburbished Toshiba Tecra 510CDT. It came without windows installed. I can't get it to recognize CD drive to load windows program. How can I get it to acknowledge the drive? Is there something I can add to the autoexec, etc., to get it work right?
  • Thomas F. Schneider May 11, 2010
    Have you tried to going  into ther setup screen and make sure it is turned on in the BIOS?
  • 565 Answers
In bios put the boot sequence so that cd is first when computer as to boot from cd click enter after installing xp - use drivers downloaded here (if u dont have the cd) - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1073769787&rpn=PA1232U&modelFilter=510CDT&selCategory=3&selFamily=1073768664&selModel=1073769787|PA1232U
Posted on Dec 27, 2008
Toshiba portege 2000 windows xp invalid system disk.
When booting, try going to the Boot Menu by pressing F12 when you see the Toshiba logo so you can select your hard drive as your boot device. After doing so, if you still get an "Invalid System Disc" error, then your hard drive may be shot.
Jan 04, 2014 | Toshiba Tecra 510CDT (P000224080)...
Dispaying broad colourfull vertical lines.
hi how are u 1st off replacing aonbord video not that easy its built on motherbord ok would need new bord and
Jan 28, 2008 | Toshiba Tecra 510CDT (P000224080)...
Toshiba Tecra Notebook
INstall the hard drive, if the hard drive came with a cd, put the cd in the drive and boot the laptop. When you see it say "boot from cd hit any key" do so and follow the prompts. This software will "initialize" the disc and install for the first time. Once the disc is "officially" installed take the hard drive disc out of the drive and replace it with Operating Disc. Reboot the machine and again look for the "Boot from CD Hit any Key" hit any key and let the system load windows. You only have to hit the key one time when it says "hit any key" even if during the windows install, the system may reboot but it still may need the disc in the drive, if you see the heading "boot from cd hit any key" dont hit any key any more....just let windows finish loading. When windows finally reboots, sometimes up to three times, then you can take the disc out of the drive or take it out if the operating system instructs you to. Good luck, ParrotHead PC Repair
Sep 04, 2009 | Toshiba Tecra 500CDT Notebook
Replaced hard drive in Toshiba Tecra M9. Laptop.now refuses to re
Look on the back edge of your old HDD where all the gold pins are and on one side there is a group of 4 pins in two rows of two... and see if there is a tiny jumper installed across two of them (white or black about 1/8" tall and 1/16th wide).
Now look on the new HDD and see if there is one there. The NEW HDD must be set up exactly like the OLD one or it won't be detected by BIOS or Windows.
I am beginning to think your LT has the CD as MASTER and the HDD as SLAVE, which may require adding or removing a jumper. Some new ones come with, some without ;-) I didn't think of this earlier
Check that. Email me the result
Mar 27, 2009 | Toshiba TECRA M9 Notebook
Toshiba Tecra 510CDT Laptop
hi,
this is mainly dependant, on what input/outputs the laptop has at the rear. If it has a printer port, or USBs. you need to be able to physically connect, laptop to printer, as i,d imagine it has no bluetooth or infra-red et,c.
Thankyou for using fixya.
Mike at compurepair.
Jan 20, 2009 | Toshiba Tecra 510CDT (P000224080)...
My tecra 510cdt needs a bios update it.wen i turn on the computer it sais put in bios disket and press any key.....how do i put it in it has no disket drive?? i downloded the bios on a disket but how do i...
you have to buy a toshiba FDD attachment case which plugs into the computer.I have the opposite problem.. I have a built in floppy drive but I must buy a cd-rom .
Dec 15, 2008 | Toshiba Tecra 510CDT (P000224080)...
Memory Up-Grade
hi there, the memory slot is under the main case. lift the computer up from the front and you will see a panel on the left with two small screws. undo these two screws and you will see the memory card. they have also two small screws that must be removed to be able too remove the card.
sam
Oct 31, 2008 | Toshiba Tecra 510CDT (P000224080)...
Help with a toshiba TECRA 8100
Yes, it should run WinXP. The minimum system requirements to run both Windows XP Home and Professional are 233Mhz, 64Mb RAM and 1.5GB hard drive space. I have a Toshiba Tecra 8000 that still runs XP, a little slow, but has run smoothly for 5 years.
The setupdd.sys error is most likely a due to a defective hardware like RAM. Try installing only one ram if you have two to see if either one is defective; it should work for most users.
Sep 09, 2008 | Toshiba Tecra 8100 Pentium III, 850 MHz...
Start Up Problem
Usually means that Operating Sytem needs to be reloaded or the hard drive is dead. Try to re-install Operating System first.
Hope this helps!
Mar 24, 2008 | Toshiba Tecra 510CDT (P000224080)...
I am failing to partition my hard disk after formatting
Which Windows OS are we using on this notebook?
Mar 22, 2007 | Toshiba Tecra A3 Notebook
Toshiba Refurbished TECRA 510CDT P133/32MB/2.1GB/CD/TFT (PA1232UT2A) PC Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
