Question about Canon imageRUNNER 400S Copier
I have a Canon 330 Home copier, and the paper drive, sprang the spring on the left side, and the paper goes in crooked. Where may I find a repair service, In Shawnee, Kansas 66216
  • smurf01763 Dec 30, 2008
    I guess i dont have the bushing, but i appreciate your trying to help me.
  • 168 Answers
I am assuming you are talking about the spring on the sponge roller under the drum you can use a small spring like from a pen just cut it in half or so.. that is if you have the little bushing that goes over the roller shaft.. ( the same set up on bothsides) the put tape it to hold it in place
Posted on Dec 27, 2008
My canon pixma ip90v is drawing paper in crooked
Your Pixma's paper holding drawer has adjustable feeding attachments on the front and left side you can use to make sure the paper is square and secure in the tray. This will help your paper load straight.
I hope that helps.
Jul 14, 2010 | Canon Office Equipment & Supplies
Paper will not feed on right hand side. Goes in crooked
the wheel is worn down. cheaper to get a new printer. you amy also have a small peice of paper wtuck. turn the printer around and take off the cover plate. look for msall paper jamed ont hat right side under the wheel.
Dec 04, 2009 | Canon MP970 Photo All-In-One InkJet...
Paper feeder is not straight
Push the copy button with the cover up and no paper on the glass. Is the light bar straight up and down, or is it crooked? I can't imagine how paper could go thru the machine crooked, but check it out if you can. If the paper is too thin, it may not be getting grabbed by the rollers right.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Spring sprang out of paper receiver tray holder
the spring that sprang has sprung, you cannot get a replacement from HP Buy a new machine
Mar 01, 2009 | HP Officejet 5610 All-In-One InkJet...
PAPER FEEDS CROOKED, JAMS, WRINKLES LEFT SIDE
Hi
Normally something get stucked between the write roller and the small presure rollers.
You can released it by inserting a paper in the opposite direction as the feeding direction.between the rollers,and the turn the machine upside down for the obstacal to fall out.This help me 80 precent of the time.Otherwise you have to stip the machine to repair.
Good luck
Dec 19, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paper not feeding on the left hand side of our lexmark 5100
open the backdoor and try to move the rollers in upward direction...if the roller on the left is hard to move then..replace the machine.
Nov 25, 2008 | Office Equipment & Supplies
Printer will not allow paper to flow freely; it jams on the left side and prints crooked.
first cancel all the prints going on and switch off and on the printer and keep the paper slowly
Aug 07, 2008 | Canon PIXMA MX310 All-In-One Printer
Printing
kindly ensure that the paper guide is set correctly according to your paper size, like 81/2 x 11 or letter size.you will find this when you first place your paper it is like a guide on either left or right side
if not chances are it wil come out crooked and distorted
hope this helps
Aug 05, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer paper feed for Canon iP4200
There are probably problems with the rollers or the gear sequence that drives them. This type of repair may be more costly than what the printer is worth!
Jerry G.
Apr 10, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon pc 430 feeder problem
You may have to fabricate a new anchor for one end of the spring on the side opposite the control panel. There is a wimpy plastic tab that breaks off here, right next to a black Phillips-head screw. Remove this screw and bend a piece of light wire around it, leaving a small hooked end sticking out for the spring to fasten on to. Replace the screw and install the spring. When you install the spring, it must go over the top of the tiny white plastic wheel, in the U-shaped groove.
This is how I repaired my PC430 several years ago and it's still working fine.
Jan 27, 2008 | Canon PC-430 Color Copier
Canon imageRUNNER 400S Copier Logo
43 people viewed this question
old marine
old marine
