Question about Baumatic MEGAWDSS Front Load Washer / Dryer
Baumatic WD55 Washer Dryer - How Do i work it??!
Hello, I have moved into a flat with a baumatic wdss/wd55 washer dryer and I do not know how to work it. I cannot find a manual and have tried doing the obvious and setting it to the usual settings and the door locks and it sounds like its about to start but nothing happens. Does anybody know how to solve this or where i can find a manual for it??
  1. how does the dryer work
Posted on Oct 26, 2010
Machine needs to be on half load for dryer to operate
Posted on Sep 12, 2009
Baumatic washer dryer, dryer has stopped working any ideas
test the drying element to see if power is getting there during the drying cycle. if it is getting power but not heating you will know to replace the element. if it is not getting power, you will have to check the components that supply power to the element
Nov 25, 2013 | Baumatic Dishwashers
I have no instructions on how to installa baumatic bwr 1206 wasing machine
Hope this helps :)
http://talkappliance.co.uk/downloads/?sa=view;down=103
Apr 23, 2012 | Baumatic BTWM4 Front Load Washer
F02 Baumatic error not cleared Even when filter cleaned...?
Perhaps you need to check the outlet hose from the pump for a blockage, and of course, make sure the pump itself is working.
Jan 17, 2010 | Baumatic BTWM4 Front Load Washer
Baumatic washer draining but not spinning
I had this problem, may be an easy fix if similar issue: Remove back cover. Take a look at the underneath the drum towards the right hand side. There may be a hook on a wire hanging there. If it is just hanging, there, it should be hooked onto a grey coloured lever, which has a hole on the edge of it. This is the drum brake which during the spin cycle releases the brake allowing the washer to spin. Hook the hook onto this grey lever through the hole. Replace the back cover. Test the machine with a towel or something, allow it to fill a little, then jump to the spin setting and see if it spins. Worth a shot, these are great machines.
Sep 05, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic megawdss leaks in front when wash cycle starts. How do I fix this?
The front door seal is bad,check to see if there is anything jammed up inside that seal,money,ex,ex,lint
May 07, 2009 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic BW012
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!
Mar 30, 2009 | Washing Machines
Baumatic MEGA WDSS washing machine
go onto manualtree.com type baumatic megawdss washing machine, if this does not bring anything up scroll down until you see it in the listings. type in the code it asks for (this will be supplied underneath, its just to stop cumputers auto logging) and then download then manual. good luck
Jul 02, 2008 | Baumatic MEGAWDSS Front Load Washer /...
Baumatic BWD12
Yes you can do it yourself using the manual which can be found at the link below...
http://www.laundrymanuals.com/manuals/mfg/hotpoint/bwm12_bwd12.html
You will need to register for free to download it.
If you couldnt do it for some reason just let me know and i will guide you..
Happy fixing!
Oct 19, 2007 | Baumatic BTWM4 Front Load Washer
Baumatic washing machine instructions
the twelve programs are explained on the detergeant drawer.if not i will post them for you.
to use the dryer turn the middle knob clockwise to the amount of time you desire upto 140 minutes then select the temperature on the far left knob and then depress the half load button your dryer should now work.
Jan 11, 2007 | Baumatic BTWM4 Front Load Washer
Baumatic MEGAWDSS Front Load Washer / Dryer Logo
504 people viewed this question
Top Baumatic Washing Machines Experts
Marvin
Marvin
NOEL
NOEL
TriciaGirl
Level 1 Expert
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
