Question about iRiver E100 Digital Media Player
Iriver E100 is not recognized on PC
Unable to view E100 as a usb device on my PC. Only displays it as Mass Storage Device.
  • 1 more comment
  • keywiz Mar 04, 2009
    My player somehow switched to MTP - now it does not seem to let me switch it back to MSC mode.
  • johjo Apr 12, 2009
    My windows will not recognise my new e100 iriver-reads as an unrecognizable usb? Help
  • micknvicki Apr 28, 2009
    every time we plug in, it say usb not recognized. I once was able to transfer some cd's onto it, but will not show up as a device anymore...stupid thing is giving me the s#@ts. My ipods work fine on here
  • 8,596 Answers
That might be a blessing in disguise. I have never liked the non-MSD option, but I tolerate it. You should be able to transfer and view files with the computer recognizing it as an MSD device. If you insist on changing it, use the iRiver plus 3 software from iRiver's website to update the firmware on the player, and your computer will no longer treat it as a Mass Storage Device - don't say I didn't warn you.
-Tha Mp3 Doctor
Posted on Dec 29, 2008
IRIVER E100 stuck. Display "USB
Take out the batteries and hold power button for ten seconds. Replace batteries and see if anythings changed. If not, then plug it into a computers USB port and then hold the power button for ten seconds. Safely Remove from the USB port and then check again. If none of these work, you just have a malfunctioned device and it may cost more to fix it.
Good Luck,
FV
Mar 10, 2011 | Cameras
Computer not recognizing device
Connect it with the USB cable and if that dosen't work install the software that came with it. If your memory card for the device is removable use an adapter to connect the card to the PC.
Feb 21, 2011 | iRiver E100 Digital Media Player
I have a LG Cu920 model and bought a micro sd 8GB card and used the USB data cable to connect to the PC and i am unable to get connection established as it displays connecting to mass storage device and...
When it displays insert memory card for connecting as mass storage device, switch off the phone and reconnect so the phone will perform as a memory storage device.
Good luck.
Mar 16, 2010 | LG Vu CU920 Cellular Phone
I cant put music on my lg volt
when the phone is plugged into computer via usb port, on the display of the phone will say usb modem , usb mass storage device with a checkmark beside it. tap where it says "usb mass storage device
" on the display of the phone. on your computer it should begin to install device drivers, and now you can view or transfer files to/from the phone. note: you need to have a micro sd card installed on the phone before you can select usb mass storage under usb phone settings. hope this helps because i like to never found the answer, had to call lg customner service to find the answer, this info is not in the owners manual or anywhere to be found on the internet.
Feb 02, 2010 | Cell Phones
Not recognising the device
REPLACE THE USB CABLE NO OTHER WAY
Jul 13, 2009 | iRiver E100 Digital Media Player
Olympus E510
Make sure the camera is on and STORAGE is selected on the camera screen when connected to the computer. You will need to have STORAGE highlighted and select OK on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Aug 01, 2008 | Olympus Cameras
Laptop VISTA basic will not recognize 3.5" Nexxtech enclosure as mass storage device
run diskmgmt.msc there it will show all disk drives. if it detects usb mass storage and the hd is not showing. soulds liek hd is bad or jumper set wrong
Apr 28, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Windows xp drivers
Make sure you have the latest version of Windows Media Player. XP has all the right drivers but the iRiver needs to synchronise with Media Player inorder to transfer music onto the player using the sync function. Get Media Player 10 or higher then plug the iRiver into the computer.
Jan 18, 2008 | iRiver T20 MP3 Player
Motorola RAZR V3
To view your V3r as mass storage device
pressMenu>Setting>connection>SelectUSB Mass Storage
before you connect it in your PC
Jan 17, 2008 | Motorola Mobility RAZR V3
iRiver E100  Digital Media Player Logo
890 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
