RTO Echo 25.4 Cc Backpack Leaf Blower - Pb-265lc Logo
A
Anonymous Posted on Sep 17, 2012
Echo PB 265L - Throttle Issues
Full Choke, Full Throttle, it runs. I can take off the choke a little and still runs. Once I back off the throttle the tiniest but, it shuts down.
1 Related Answer
Roger Davis
  • 32 Answers
  • Posted on Sep 23, 2009
SOURCE: I have an echo pb 265l leaf blower. It starts
If its a two cycle engine it sounds like its loading up on fuel.. Need to lean out the fuel on the carb. Not much or it will be to lean an stick the piston..
My echo pb 265L won't run at full speed, just finished putting a new carb on it can you help
should be two air adjustment screws, at full throttle or as close as you can get to full throttle, open or turn screw counter clockwise take note on how much you turn it, in the event it does not help, try one then the other as on of these will help 96% sure. have a great day
Apr 19, 2019 • Echo Garden
1helpful
Echo pb 265l backpack blower bogs down at full throtle
Hi ryan...
You still have problems in the carb highspeed circuit..some debris in the passages...
BE SURE TO USE COMPRESSED AIR TO BLOW OUT THE CARB.
(be sure to watch the inlet valve seat, you can loose it and not even know it) Blow the carb clean in a box or something that will contain any part that may be expelled during cleaning.
Please take time to rate me
Bud
Mar 31, 2013 • Echo Garden
3helpful
3helpful
2answers
I have an Echo PB-500T blower that won't throttle up. I bought this blower new about 3 months ago. Before this blower I had an exact same blower that gave me the same problem. I returned that blower...
Remove the in tank fuel filter and take it apart, the felt Echo uses on the filter clogs quickly. There is still a mesh screen filter in the assembly so make sure you put it all back together and reinstall the fuel filter into the tank.
Pb-413 blower. starts w choke, then stalls when choke is taken off. wont run at full throttle without choke on about 90%
Most likely there's a problem with fuel supply - choking cuts air supply optimizing the air/fuel mix. Most common solution is to check and clean the carburetor.
If there's a tiny fuel filter in the fuel line between tank and carburetor check it on excessive pollution. Replace it when necessary.
When opening the blower for carburetor cleaning - also check the airfilter and replace when dirty.
If never opened the blower - take pictures with a digital camera at each step. The pictures can help with assembly after cleaning.
Jul 11, 2011 • Echo Garden
2nd use of chainsaw pp3516avx, it won't start, choke lever will not stay extended. I followed the instructions to start and nothing works
The choke system is connected to the half throttle position, if you lift the throttle trigger the choke pull will automatically return, whilst trying to start do not lift the throttle trigger, the starting procedure is, pump the primer bulb as many times as it takes to 3/4 fill the bulb, pull the choke pull fully out, this will switch the saw on and engage the half throttle, crank the engine until it fires once, do not continue to pull,it will actually not run on full choke, if you do continue to crank with the choke fully out, you will very quickly flood the engine, now push the choke fully in, now crank the engine until it fires up, lift the throttle trigger once, this will dissengage the half throttle, and it should now come down to idle.
My BMW R1100RT is difficult to start. Must use full choke, give full throttle once and then hit the start button. It then starts just when I let go of the start button. Often it refuses to start and then...
The choke actually just opens the throttle bodies a little (the bike is fuel injected). Try using putting on the 'choke', then pressing the start button, but dont touch the throttle. Does it start ok? Also, when started, if you use the 'choke' does it increase the engine speed? If it does not, then you need to set it up correctly.
Let us know how you get on.
10helpful
I have a Echo PB/251 Gas Blower which I recently starting having problems keeping it to run. I have to keep the choke on to let it stay at a fast idle. I have taken the carb apert along with all gas and...
Check the muffler and/or spark arrestor screen in the muffler outlet pipe and also the engine's exhaust port behind the muffler. These are prone to carbon-clogging and the engine cannot "BREATHE" enough to reach full throttle. If all-clear in the muffler, go back in the carb and locate the inlet screen directly opposite of the inlet needle. Carefully pull it out with a pick and hold it up to a light source. If you cannot see thru it, replace it. This is another, (less) common area of obstruction.
Hope this helps,
Dolf-
2helpful
2answers
Echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Apr 06, 2009 • Echo Garden
Top RTO Garden Experts
Sean Wright
Sean Wright
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a RTO Garden Expert? Answer questions, earn points and help others
