Question about Dryers
Hi, I have a Maytag gas Dryer, Legacy series, heavyduty. I clean the lint filter each time used but there is still a build up which I cannot get out unless I remove the filter housing. How do I do this?
  • 179 Answers
You do not have to remove the lint housing all you have to do is go to an applaince store and ask for a lint brush you then take the lint brush and shove it down where the filter goes to loosen the lint turn on your dryer and it will blow it outside
Posted on Dec 26, 2008
Sdg515daww maytag legacy series gas dryer will not put out any heat until the dryer has been on for about an hour or an hour and a half...have cleaned external vent tubing and vacuumed (as far as vacuum...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Dryers
Dryer is not drying or heating up like it use to - takes forever and ever
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Dec 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My Maytag Dryer is heating up but not working to full heat level?
If your
Dryer Maintenance
heatman101
Dec 03, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The dryer is not drying
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Oct 10, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Why is my maytag dryer running for a long time but not getting my clothes dry, and the vent pipe its clean?
I note the vent is clean.... Now start checking for heat from that vent with the dryer on. You did not mention the model number so we at FixYa do not know if this is a gas or electric dryer. If it is electric cycle the circuit breaker to off (PUSH hard to OFF) then back on. There is a chance that only 1 breaker is connected. It would run and not heat.
Also the airflow out the back of the dryer should gently push a relaxed hand / wrist away from the vent outlet. If it does not do this you have an airflow problem. Look inside the dryer vent outlet for any signs of lint build up. You can have a clean vent but a blocked dryer vent inside the dryer. Go outside the house and check the thru the wall vent hood and flapper for lint buildup. This is a VERY common airflow restriction point. check BOTH sides of the metal flapper for lint. Lastly if after all of this you still have airflow problems the blower wheel hub can be broken or lint on the blower wheel.
Pull the lint filter and wash the filter with vinegar and water then soap and water. Fabric sheet particulate can cause restricted airflow. Also take a flashlight and look hard around the lint filter area for lint build up. Use a folded metal coat hanger to assist in lint removal along with a vacuum and crevice tool.
If you do not have heat... at all... after all of this; please respond with a model number so we can sort out where to go next in troubleshooting.
Thanks for choosing FiXya.
Kelly
Sep 08, 2010 | Maytag Dryers
Bosch Nexxt 500 series gas dryer lint building up inside dryer
Get a long brush they have ones made for this chore proably at Ace hardware.
Aug 06, 2009 | Dryers
Maytag Legacy Series Washer. Lint settles on
Lint is in majority flushed out in drain cycle. make aire the tissue and match books aren't in any pockets. the lint is then deied and separated in the drier , Well so I was told . good luck
Jun 07, 2009 | Maytag Legacy Series Top Load Washer
Maytag gas dryer taking too long to dry clothes
Not too familliar with the gas temp either, but you should definitely take your lint filter out and clean it with soap and water. If you use dryer sheets, they can leave a clear film on your filter and it can be just as bad as a filter full of lint. Try this out, if it works, clean your filter periodically with soap and water to remove the chemical buildup.
Jan 19, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Smell Gas.
you need to clean out you venting ...it is most likely clogged or filling up
Jan 02, 2008 | Maytag MDG2706A Gas Dryer
Lint build-up
remove the lint screen by pulling on it ,around build up scrub w/ brush clean w/ portable vacuum .
Dec 31, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
182 people viewed this question
Top Dryers Experts
Marvin
Marvin
