Question about Air Hogs Havoc Heli Helicopters
Havoc heli will not charge
Green lite will not come on when charger plugged in
  • 3 more comments
  • mobart Dec 26, 2008
    We have the same problem with one of ours. The charger is working because it will charge our other havoc heli. The plug goes in and the prongs appear straight, but it will not charge and the green light will not turn on.
    HELP!!
  • Anonymous Dec 28, 2008
    green light will not come on when one of the air hogs havoc helis is plugged in
  • hypnozia Dec 29, 2008
    Havoc heli mini worked the first day, but then stopped charging. Not the batteries in the charger. Green light doesn't come on.
  • stevie3 Dec 31, 2008
    I stuck a tack in the nose for balast and thought maybe I had impaled the battery, but no, it just doesn't charge.
  • flyboy108 Apr 05, 2009
    my havoc heli flew perfect the first day then the next day when i went to charge it it would go to full power after charging then it would die if anyone can help please help ASAP
  • 3 Answers
As far as the green light on the charger not coming on: after I tested the batteries in the remote, I found that it was due to 2 of the 6 batteries in the remote control being dead (0.1volts) The charger probably sucks the power out of the #1 and #6 battery.
Make sure all batteries in the Remote have the same charge.
Also, there seems to be a loose contact in the charger plug prongs. You will have to find a way to sit the helicopter so that it stays in contact with the prongs while charging. Mine has to be on it's side to keep the green charger light on.
Posted on Jan 02, 2009
Have you tried to turn off the little blue switch on bottom of the heli. keep the remote on
Posted on Dec 27, 2008
  • j tepale Dec 27, 2008
    have you tried to turn off the little blue switch on bottom of the heli. keep the remote on
Have you tried wiggling the charger
Posted on Dec 30, 2008
My solution to an Air Hog Sharpshooter charging problem is linked below. I would venture that the internals of the havoc are very similar...
http://www.fixya.com/support/t7454774-sharpshooter_remote_both_turn_but
Posted on Dec 27, 2010
My Air Force infared control 2 in 1 helicopter wont charge. (The light wont come up green)
Found a previously posted solution here:
http://www.fixya.com/support/t13972794-havoc_heli_won_39_t_charge
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Dec 25, 2013 | Spinmaster Air Hogs Red Defender Remote...
My Havoc Heli won't charge
http://www.buynicer.com/SWIFT6020--1-New-3--Channel-RC-Helicopter-w-Infrared-Remote-Control_pid8096.html
Aug 12, 2012 | Spinmaster Air Hogs Red Defender Remote...
My helicopter has no lift even when fully chargered. The props are spinning but it just stays on the ground.
i got a new model havoc heli and the trim buttons did not help at all... in the end I took a motor/prop off of an air hog styrofoam plane I had that was identical to the havoc heli tail rotor and swapped em out.. Problem solved... there was some sort of error with the tail rotor
Mar 22, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
Charger won't stay in heli...green light won't stay on to indicate charging is occurring
I had the same problem after not using that for one year. I guess the cell is dead. Time to change the rechargible battery? If any one know the trick, please send me an e-mail to: xy_zhu2001@yahoo.com. Thanks.
Jan 02, 2011 | Air Hogs Havoc Heli Helicopters
I cant charge my helicopter i dont know how its called havoc razor
you take the charger and under the buttons open the small compartment. there is a small cord that plugs into your helicopter.
Dec 25, 2010 | Air Hogs Havoc Heli Helicopters
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
Mine will not charge everytime it goes for like 10 seconds
Hello. I recommend that you clean all of the contacts and the ends of the batteries using the eraser end of a common pencil. Now charge it and see if it takes a charge. If it does not, then the problem is either that the batteries are shot and need to be replaced, or the charger is bad. Regards, Joe
Dec 07, 2009 | Air Hogs Havoc Heli Helicopters
Nephew lost directions for charging
make sure both heli and controller are off and batteries are new and then plug wire into heli and then turn controller on it doesnt matter abc, abc is just the frequency to controll heli just match with the letter under the heli
Jan 04, 2009 | Air Hogs Havoc Heli Helicopters
My Havoc Heli got wet
Most likely you short circuited something and now it can't be fixed. I would send it back to the company to be replaced.
Jan 01, 2009 | Air Hogs Havoc Heli Helicopters
Air Hogs Havoc Heli Helicopters Logo
3,069 people viewed this question
Top Air Hogs Toys Experts
Marvin
Marvin
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
