Question about Dremel Variable - Speed Multipro Rotary Tool 395
Nylon Coupler crscks when installing
Moto-Tool 395.. Nylon coupler cracks open whrn I replce it. Two ?'s : How do I order replacement nylon couplers and why do they crack open when I install?
  • 2,176 Answers
I'll answer last question first. They might be cracking because they are in a bind and when turned on or inserted on the shaft there is too much pressure. Make sure the shafts are free of any debris from the original coupling, also check the bearings for wear or being so tight that they twist the coupling. Everything should move freely. And second I would recommend calling Dremel direct at 1-800-437-3635 for replacement parts. Hope this helps.
Dave
Posted on Dec 26, 2008
Leaking coupler while compressor is running but only when hose is plugged in.
If the leak is around the threads use a nylon thread tape on the threads on the hose. If it's leaking from the center, then there might be something jammed in there holding the shut off valve slightly open
Mar 20, 2013 | Air Tools & Compressors
I need part # 2615294309 coupler for a 395 Dremel tool
I had the same problem - couldn't get the part (plastic coupler between the spline drive shafts). I purchased a waterproof **** Splice (GB-AMT-5126 12-10 gauge -- used for electrical wire splicing -- got it at Home Depot). Clipped off about 3/8" on each end with diagonal cutters and attached it to the shafts. The steel ring in the middle of the **** Splice connector provides good structural support to the connection. Works like a charm. Plus with a pack of 4 connectors, I have 3 in reserve.
May 24, 2010 | Dremel Variable - Speed Multipro Rotary...
I just changed out the gear and sproket assembly with no problem. The nylon gear was badly worn. Now, with or without the door engaged in the trolley, when I push the door opener, the motor runs in one...
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
Dec 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
Stripped plastic coupler on output shaft of Dremel model 277
I'm guessing, but I think that the Sears tool uses the same flexible coupling. If you go to www.searspartsdirect.com and put in the model 572610031, you can look at the diagram and decide for yourself. I think the part costs $2.57. If it's the right one, I'd order two or three for the future.
Hope this helps.
Oct 04, 2009 | Dremel Variable - Speed Multipro Rotary...
Nylon Coupler cracks when installing
I would call Dremel direct at 1-800-437-3635 and order them. They also have a tech line, but I would think that they are in a bind when installing and cracking. Look at the bearings to make sure they are not tight or completely locked up. Let me know if I can help further
Dec 26, 2008 | Dremel Variable - Speed Multipro Rotary...
Coupling broke
I have a Dremel 395 Type 3. Motor works fine, shaft doesn't turn. Took it apart to find that the white plastic or nylon flex coupling on the shaft had crumbled and the spline driver, which fits directly over the motor end of the shaft was somewhat worn. I emailed Dremel and got an overnight reply listing the 2 parts I need and the cost: Coupling is $1.00 and the driver is $1.25. Placed order by phone: 1-800-437-3635. I ordered 2 of each in case future replacement is needed. Total bill came to $7.27 including Florida tax and shipping. Can't beat that. They said it would be in the mail by tonight. (Flex coupling number is 2615294309; spline driver is 2615294308.)
Rating Locked! (?) lexrehabtech has rated this solution as Helpful
Oct 26, 2008 | Dremel Variable - Speed Multipro Rotary...
Buick Regal Gs supercharger nose assembly please help if you can
the 3.8" supercharger (belt) pulley? You need a special tool as they are press fit.
www.intence-racing.com and www.3800performance.com
both carry it and offer the tool for rent as well.
Much of the noise comes from the coupler, however there are case (needle) bearings as well that wear, Those are much more difficult to replace.
Oct 13, 2008 | 1998 Buick Regal
Dremel 395 Type 2
REFERENCE M/N: 395 - Type 3 - Dremel does not have the parts listing on their site for some reason. I actually have the original I saved from 1988!
The part number for the Nylon Coupler is:
Illustration Code Number: 5
Description: Flex Coupling
Part Number: 529430970
This is all from Drawing (Form) Number:5296074 10-88
Jun 15, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
188 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
