Question about Kitchen Ranges
Whirlpool SF377PEGQ 0 ,Gas Oven not igniting...
The oven doesnot light, nor do i have any gas smell when trying. The igniter does glow. The broiler does ignite. The top burners ignite. I can't seem to find any schematics out there that actually match my model. The gas valve has 1 inlet, 3 outlets. I suspect the top burners have another valve either under the cook top or behind the unit.. When I Ohm either set of contacts on the valve that serves the oven and broiler, I get only 1.1 ohms on both sets.
Summary - I suspect that the valve is bad, but was reading that the igniter could be weak?? I also do not know if perhaps that the igniter does not get hot enough(or draw enough current), that the gas valve won't have enough current to open???
Any help would be appreciated...
Daryl
Burners work without a problem--broiler works but oven burner does not light--if I keep the oven selector switch on long enough (over 2 minutes), I will get a minor explosion in the oven. I have a GE XL44 self cleaning range.
  • terryfowler3 Feb 24, 2009
    Whirlpool GS395 LEG Q, Oven will not light. It is sporadic, sometimes working fine.
  • Anonymous Mar 21, 2014
    One burner on the gas hob will light but not remain alight, suspect the burner safety valve probe has faled. How hard is it to replace and how can I identify the part number?
  • 71 Answers
If you have 120 v to ignitor then ignitor is bad.
Posted on Dec 27, 2008
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Oven Not Working
Your igitor mat be glowing but it is not generating the proper amps to ignite the gas. The proper solution is to replace the oven igniter
May 27, 2009 | Whirlpool GS460 Gas Kitchen Range
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
I don't seem to be getting gas to the oven and broiler.
top of stove work but the oven dont work the igniter come on and glows but no gas
Jan 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
Kitchen Ranges Logo
827 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
