Question about HP OfficeJet V40xi InkJet Printer
New ink cartridge problem
When I replaced the color cartridge the printer doesn't see the new cartridge and tells me to "Install color cartridge". When I reinstall the old cartridge the message goes away. Then I reinstall the new cartridge the same message comes back. I removed the protector tape before installation. The cartridges look identical, the only difference is in the product bar code, the nimbers are different. Both cartridges are C6578D. Thank you for your help. Kelly
  • Anonymous Nov 09, 2007
    When I replaced the ink cartridge the toolbox then showed all of the cartridges as being empty. I pulled the new one out and put the old one in and the toolbox showed the other three as having ink and the one as needing replaced. The new on is exactly the same with correct numbers and an expiration of 2009. I guess it is just a faulty cartridge that HP will get back.
  • 163 Answers
Pleaz change the same original cartridges
Posted on Sep 16, 2007
Selphy cp780 continues to say ink cartridge empty even after installing new one. Tried 2 new ones to be certain it wasn't the cartridge, same thing...tells me ink cartridge empty install new.
try and reset your printer,unplug the power cord and wait 10 min, then plug back in,understand that Canon has installed a chip so you cannot use refilled cartridges,or cartridges you refill,if this doesn't work,then contact Canon,and you could get the same message I got take it in to be repaired, (to costly), so I end up buying a new one,,
Oct 10, 2012 | Canon SELPHY CP780 COMPACT PHOTO...
Error u053
this error signals that something is wrong with ink cartridge.
You can try re-install ink cartidge, if this doesn't helps ink cartridge is defective and you need to replace with new one.
Hope that helps!
Aug 23, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
I was troublshooting my ESP 5 with two new ink cartridges when they told me they would have to send me a new printhead. The new printhead is here, but when I install the cartridges (again and again with...
If the cartridges were out of the printer in the open air,they might have gone dry. Try to reseat cartridges 2-3 times,if isssue persists,get a new colour ink as Kodka will certainly not replace the ink for you.
Dec 10, 2009 | Kodak ESP 5 Printer
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
Problem with replacing color ink cart. #5
Is it the right Cartridge you are trying to install please check and then check if the sensors are working.
Mar 31, 2009 | Lexmark X2600 InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
New ink cartridge for Kodak Easy Share 5300 will not work
The version of firmware you originally had on the printer when you changed the ink cartridge was bad. There is a known issue that when you put in a new ink cartridge when the printer is in the error state "COLOR INK EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the new ink cartridge so you will continue to have that error.
So to fix your problem Open the access door and Remove the ink cartridges. Then download and install the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
I hope this helps
Mar 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My kodak 5300 will not accept the new ink cartridges
Mar 09, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
HP OfficeJet V40xi InkJet Printer Logo
59 people viewed this question
Clive
Clive
