Question about Black & Decker V9650 DustBuster Handheld Wet/Dry Vacuum
How do I open the dustbuster to clean out the end
I can't open the dustbuster to clean it.
  • Anonymous Mar 21, 2014
    everthing seems fine except it makes a loud squelling sound.
  • Anonymous Mar 22, 2014
    motor clean
    Genius:
  • 1,036 Answers
There should be an area to press at the joint between the front section, and the motor section. The whole front cone comes off to empty the contents, and there is a filter - but no bag with these.
Hope this helps you.
Thanks for using Fixya
Posted on Dec 26, 2008
How old are these dustbusters
The Black & Decker DustBuster (now stylized as DUSTBUSTER) is a cordless vacuum cleaner that was introduced in January 1979.
Mark Proett and Carroll Gantz are listed as the inventors on the utility and design patents, respectively, assigned to Black & Decker for a cordless vacuum cleaner.
If you want to get some other insformation, please be more specificabout your question
Nov 08, 2015 | Vacuums
HV9010P ROLLER BRUSH DOESN'T MOVE
That is probably the belt. Open up the bottom screws and take a look. The cat or dog hair usually gets stuck in the ends of the rollers and stops the belt from effectively pushing the roller. You may find that the belt is still on the drive and the roller. If you do just clean out the roller.
Jan 22, 2013 | Black & Decker AV1200 DustBuster Handheld...
How do I clean filter on black&decker DustBuster pivot 18v
(The below worked with my 9.6v version - I assume the others in the pivot range will be similar).
If you open the lid (where the dust collects) you can twist the inner plastic filter about 30 degrees to unlock it. Then, with a bit of "fiddling" with the fold out part (press the unlock button and rotate the suction part as if you were going to use the unit) then, the plastic internal part and the whole suction bit will come off the motor part. Do this slowly as the inner filter will be full of dust and muck. You can then take the filter out, tap it clean in the bin and then wash and dry it with washing up liquid (gently) and allow to fully dry before putting it all back together again.
Nov 28, 2012 | Black & Decker 15.6 Volt DustBuster Vacuum
What is the "wheel" on the side of the dustbuster for? what position should it be in?
The wheel is the pivot and cover for the filters. It opens up to show the filters behind for cleaning.
Mar 11, 2010 | Black & Decker AV1200 DustBuster Handheld...
Charging Black & Decker Dustbuster
Leave it in the charger for at least 7 hours and then try and see if it works on a full performance time of roughly 3 minutes.
Feb 04, 2009 | Black & Decker V9650 DustBuster Handheld...
Cyclonic 14.4 volt DustBuster started loud humming noise?!HELP
Ours began making a hideous grinding racket and then quit altogether. Upon disassembly, I found a plastic guard protecting the fan that had warped and was preventing the motor from turning at all. Your problem may be related to the same plastic guard. I removed mine and now all is well...I think. If only I could find a replacement for this little guard. Every online parts distributor I've seen will only go as far as selling filters and prefilters.
Nov 20, 2008 | Black & Decker AV1200 DustBuster Handheld...
DUST BUSTER 7.2 POWER LASTS FOR UNDER ONE MINUTE??
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=859375
Generic problem for all Vacuums
Posted by bettedxx on July 31, 2008
DUST BUSTER 7.2 -- POWER LASTS FOR UNDER ONE MINUTE??
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The problem that people have with dustbusters is that when they 1st get them they need to say train the dustbusters to extend the battery life, the process is simple – when you 1st buy the dustbuster then you charge it up the 1st time and then you turn it on and drain the battery down to nothing, and then recharge the dustbusters again, and by doing that you have a larger battery life and it will run longer – but dustbuster and vacuums like that do not tell you and when people buy the item they just turn it on for a minute or two and then the battery does not get a “memory” as per how long it should run. By doing this the dustbuster will last and run longer and will have fewer problems. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 31, 2008 | Vacuums
REPLACEMENT FILTERS
I suggest calling customer service.
http://www.blackanddecker.com/CustomerCenter/
Incidentally, the model number you gave is a 3.6 volt vacuum.
Dec 15, 2007 | Black & Decker CWV3630 DustBuster Wet/Dry...
Black & Decker V9650 DustBuster Handheld Wet/Dry Vacuum Logo
544 people viewed this question
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
