Question about SanDisk Sansa Clip MP3 Player
Music lost when charging battary
When my son pluged his Mp3 player up to out DVD Player (it has a usb port) when he removed it a few hours later all his music was eraised. What happened and how do we keep it from happening again. PS we do not have a computer.
    Problem Solver:
  • 4 Answers
Go to a public LIBRARY into the computer go to LIMEWIRE and download songs
Posted on Dec 27, 2008
How can I recharge the battary by AC main directly on 220 volts
MP3 players are charged with the supplied USB cable and connecting it to a computer's USB port OR connecting it to an USB 5 volt mains charging adapter.
Apr 08, 2012 | Copenhagen TA-454 256 MB MP3 Player
How do you charge the delstar ds 821, & down load music?
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Mar 08, 2012 | Audio Players & Recorders
Sro 8120 transonic mp3 keeps cutting out like its going flat when its charging a red light comes on sometimes flashes and the device will only play for a few minutes
Taken from the Quickstart User Manual
LED Light 1 (L1) - is by the earphone socket
LED Light 2 (L2) - is by the USB connector
Charging: Please switch on the player before charging. (Push the on/off switch to 'on' )
When charging the battery for the first time it is recommended that the player is charged about 8 hours. Connect the player to an active USB port using the supplied cable. The computer must remain on during the charging process.
Recharging: Recharge the player will take about 3 to 4 hours. When it's charging, L2 will turn on in red, when it's fully charged, L2 will turn to green light.
When playing music, L1 will shine.
Sep 01, 2011 | Audio Players & Recorders
How do I recharge my mp3 player? I have lost my manual.
MP3 players are charges with the USB cable. Connect the cable to your player and then plug it into the USB port in your computer. While it is charging you can download mp3 music files to your player.
May 16, 2011 | SanDisk Sansa Fuze MP3 Player
Can you keep player plugged into usb charger while playing music files indefinatly or will it over charge and possibly cause damage? im shopping around and am not even shure it will play while pluged in to...
You can keep the Sansa plugged in without fear of overcharging. The Sansa will play while it is connected to a USB port that is supplying only power, such as a USB charger operating off a car cigarette lighter. It will not play while connected to a computer.
Mar 09, 2011 | SanDisk Sansa Clip MP3 Player
I charged my swimP3 but it won't turn on when disconnected from the computer.
The Swimp3 Player does need to be charged for at least 3 hours for the best experience. Here are some tips that could help solve your problem:
Problem: The player doesn't turn on.
Suggestion: Charge the battery in the player for at least three hours, this will allow it to fully charge. You can charge it by plugging it into the USB port on your computer or by using a USB wall charger (sold separately). If you do choose to use a computer to charge it, be sure your computer is turned on. If there is no power to the computer, then no power is going to the USB port to charge the Swimp3 player.
Additional Tip: The charging answers are in the Green Indicator Light.
If the green light is flashing off and on, then your SwiMP3 player is charging
If the light is solid green, the SwiMP3 player is fully charged
If you have no green light - then it is not receiving a charge - check the connection, make sure its plugged in properly, or check to see that there is power from the computer or USB wall charger.
Problem: I have charged my player, the light is solid green, but no music plays.
Suggestion 1: Have you loaded music onto the player? Try adding a few mp3 or wma files and test it again.
Suggestion 2: If the power is on, you loaded music, clicked the Play button and no music comes out, press and hold the RESET button for 4 seconds. It's kind of like rebooting your computer when it crashes. Many times a simple reset clears up any challenges.
If that doesn't work, then it could be the
* volume
* incompatible files or
* folders
Volume: On some units the factory volume setting is very low.
Solution: Try turning up the volume by pressing and holding the "+" PLUS button. If you click the "+" button it changes the song, pressing and holding the button will actually control the volume. And if its too loud, press and hold the "-" MINUS button to bring the volume back down.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
Michelle
Authorized Finis Dealer
Get Swimp3 Deals at WaterproofMusic.com
May 21, 2010 | Finis Swi MP3 Player
When i charge the mp3, can i play music?
you cannot play music while charging with the usb. you can play while you charge with the wall or car charger.
Apr 03, 2009 | SanDisk Sansa Fuze MP3 Player
My creative zen won't charge or turn on
To resolve this problem, establish that the player is charging correctly as follows:
  1. Connect the player to a USB port on the back of a desktop PC, to a powered hub, or to a power adapter (separately available).
  2. Check the display for the charging icon battery_ac_charge_1.jpg.
    • As the display times out after a few seconds, press any button on the player to reactivate the display.
    • If the battery is fully depleted, the charging icon may not be displayed.Cupthe player in your hands to check that the blue power LED behindthePlay/Pause and Options buttons is glowing on and off repeatedly. This indicates that the player is successfully charging. After 1 hour of charging, power on the unit to activate the display. The charging icon should be displayed.
  3. Allow the player to charge for at least 6 hours. During this time, if charging from a USB port, please ensure your PC does not enter a power conservation mode (Standby, Sleep, or Hibernate) as this will interrupt charging.
Ifthe player does not indicate a charge, or will not power on afteratleast 6 hours of charging, please contact Customer Support.
Creativerecommends updating your ZEN V or ZEN V Plus firmware to takeadvantageof new features and functionality. To learn more, click here.
Hope this helps
Chris (ziraffa)
Jan 14, 2009 | Creative Labs ZEN V Plus MP3 Player
Sandisk sansa shaker
If you have a small USB cord that is really small on one end & big in the other, hook it up in one of the USB ports in your computer. Place the small end of the USB cord into the really small slot where you put the batteries in.
You should have heard you copmuter make a sound, Then your MP3 player should be lit up around the pause/play button.
Open my computer, Removable disk F ,Then open the drive on disc F ( which is your mp3 player )
then you have a new window open, you should be able to just drag the music files into the new window which will go directly onto your mp3 player
Oct 19, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Didn't expect this
let the mp3 player run out of batery then charge it and turn it back on and it should work
Oct 07, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
