Question about Garmin nuvi 260W GPS Receiver
GPS does not have maps
Display read "no detailed maps found that support routing. The nuvi can not be used without them."
  • 2 more comments
  • dsaf70 Jan 04, 2009
    Same problem, all of a sudden "no maps found".
  • kmwtarheel Jan 06, 2009
    same problem.. help!!! I have soft reset and hard reset the device
  • Anonymous Jan 11, 2009
    When I siwtched my nuvi 260w the other day it said "No detailed maps found that support routing.The nuvi cannot be used without them." Now I am stuck. Don't know how to fix it. Have I lost the addresses I had saved ??
  • vance_rupe Jan 12, 2009
    I have been using this device since xmas and today when i turned it on at first it acted like i was first setting it up and it didn't have any of my saved locations. when i got home i tried it again and it just says "no detailed maps found that support routing. The nuvi cannot be used without them." It had been sitting in my office two days.
    Problem Solver:
  • 4 Answers
I had the same problum , it showd the car but no roads . My maps where on the sd card , dont know how it got there !!!! when i put it back in it worked ok
Posted on Jul 24, 2009
bestdarngood
  • 3037 Answers
SOURCE: No detailed maps found to support routing
Have you tried updating the unit at Garmin's Website?
Let me know if you need help, I can get you the right web-link if needed.
Benjamin
Posted on Feb 28, 2009
madguy1089
  • 21 Answers
SOURCE: Garmin Nuvi 200 Maps Disappeared
Contact Garmins Tech support hot Line they will walk you through the process and if they can't fix it over the phone they will send you a disk that will completely fix the "NO detailed maps found that support routing" I have contacted them with the same problem and the disc was free of charge.
Posted on May 27, 2009
  • 48 Answers
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
Posted on Jun 02, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin Nuvi ~ No detailed maps found that support routing.
Please see this link for more inforamtion on this problem. I can help you resolve the issue. Your map unlock code is either corrupted or missing.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Posted on Aug 20, 2009
sharcnet
  • 2130 Answers
SOURCE: no detailed maps found that support routing on my
This is a common problem. Your map unlock code has either been corrupted or is missing. Please see this link for more info on this problem:
- Jim
Posted on Aug 24, 2009
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
No detailed maps found that support routing on my
- Jim
Aug 24, 2009 | Garmin nuvi 205 GPS Receiver
- Jim
Jul 11, 2009 | Garmin nuviĀ® 200 Car GPS Receiver
Benjamin
Feb 28, 2009 | Garmin nuvi 255W GPS Receiver
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
81 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
