Question about Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television
Mitsubishi WD-62327 Screen is very dim
I changed the Bulb out when it told me to. Since that time the Screen is very dim. The room needs to be dark to see anything. The VCR also is displaying in Black and White.
I tooked the front screen off the TV set. I fallowed the instructions from another wrighter. The Bottom mirror was clouded with dust. I used a cleaner made for cleaning ipods and put it back together with instant success. I had not cleaned it since I got it almost four years ago. I just thought it was getting dim.
As far as the VCR playing black and white it also an easy fix. The Satalite Service man was swapping out my receiver and inadvertaly put the device on componite side of the TV. I put them back on Inpute 1 and 2 and they also work just fine. Thank you for your help.
reading other people porblems I was able to repair it on my own.
Posted on Dec 28, 2008
We replaced the lamp in a tv mitsubishi wd-62327 now there is a orange flashing indicator light....now what?
if the set is now working,its just a matter of resetting the lamp-hour counter in the on-screen menus.be sure to clean any filters associated with the fan which cools the bulb,or your new lamp wont last long!
regards,steve
Jul 31, 2011 | Mitsubishi WD-62327 62" Rear Projection...
I have a mitsubishi wd 65738. My picture suddenly went dim. I can still see a picture but the room has to be very dark and its still hard to see. Do I just need to replace a bulb?
Hello
Its bulb has got traoubled or its control circuit has some faut with it. it is not a user serviceable item. Replacing bulb can be done by the user according to the instructions in its user manual. But trouble shooting its control section must be done be any experienced service technician. OK.
May 27, 2011 | Mitsubishi WD-65738 DLP TV
Replaced Bulb and sill have red lamp light
no you should not feel any click,the lamp plug
slides into the ballast plug in the groves.do not
force it,you could have the plug upside down or
you need to visually see if the ballast plug is
damaged.you may need to replace the ballast if you still are getting a red lamp error on the
front of the tv.
Jul 15, 2009 | Mitsubishi WD-62327 62" Rear Projection...
How do I install the lamp? how to install bulb mitsubishi wd 62327
The lamp is in the FRONT of the television set. Just remove the bottom front, no screws, and you'll clearly see directions on how to install the new lamp.
Simple, just a few screws.
Feb 28, 2009 | Mitsubishi WD-62327 62" Rear Projection...
I just replaced the lamp on my Mitsubishi WD-62327 picture is dim
TAKE THE FRONT SPEAKER PANEL OFF AND YOU WILL SEE TWO SCREWS ON THE LEFT AND RIGHT TOP CORNERS THAT HOLD THE TABS FOR THE SCREEN LOOSEN THEM THEN GO BEHIND THE TV AND REMOVE THE SCREWS AROUND THE PARIMETER OF THE BACK OF THE SCREEN 10 TOTAL THEN REMOVE THE FRONT CENTER PANEL 4 SCREWS AND UNPLUG THE SCREEN EASY TO SEE WHICH ONE THEN JUST LIFT THE SREEN STRAIT UP ONCED REMOVED YOU CAN CLEAN BOTH MIRRORS DONT USE CHEMICAL CLEANERS JUST A SOFT RAG HOPE THIS HELPS
Jan 23, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Dark picture problem
there are 2 mirrors did you clean both there is one down in front near the light source when front screen removed lean in and look down there is another smaller mirrorclean it
Jan 02, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD 62327 DLP TV
Can I ask where you got the capacitor kit from?
Aug 17, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD-62327 62" Rear Projection HDTV-Ready Television Logo
438 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
