Question about Hoover H130E Front Load Washer
Hoover VHD h12, 8kg 1200rpm. will not run...
Hi i went to turn it on and all it does now is light up and the light's just flash,it will not start any programs but there power
3 Suggested Answers
kapishtech
  • 2272 Answers
SOURCE: hoover vision HD 1400 AAA,
Check if the inner drum is spinning without noise when you turn it on manually.If the same noise is heard then it can be drum center bearing,that is out of alignment/.The other possibility can be the timer ,it must be getting short causing the noise. Check out.keep updated. Thanks.
Posted on Sep 18, 2010
SOURCE: Hoover visionHD vhd 842-80 will not complete its
Mine done the exact same thing and it was the bushes that went not the pump, so you can change them your self if you can
Posted on Jan 17, 2012
I have a Hoover VHD Sensor Dry 1400 AAA that trips the house fuse each time I turn it on. What should I do?
disconnect from the power outlet and call an technician to find the short or earth leakage problem
Feb 20, 2018 | Hoover Washing Machines
Hoover VHD sensor Dry shows Eo8 vibrate badly and stops any suggestions please regards Peter
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/specific-faults/3070-hoover-vision-hd-washing-machine-fault-codes.pdf
Mar 09, 2015 | Hoover Washing Machines
Hoover vision hd
the bearing are gone
Jan 18, 2014 | Washing Machines
Hi I have a hoover vhd 9143 zd washing machine which went 'pop' today. Now it doesn't work and the red digital display does not work properly? Any suggestions?
unplug the unit then remove the cover and look for the circuit board which get wet.or a wiring that get loose connection.
Oct 15, 2012 | Washing Machines
I have HOOVER vhd 8143db80 when it went into its final spin, it started screaming. So I've taken the back off,I've noticed a lot of black carbon/metal dust on the pulley wheel. I've turned the...
That could be two things. Belts scream when they slip and are worn out. An bearings scream when they are dry or worn.
Your machine seems a bit obscure, as Google doesn't seem to know that model?
HOOVER vhd 8143db80 Google Search
VHD812
https://service.hoover.co.uk/manuals/VHD812.pdf
Feb 19, 2018 | Hoover Washing Machines
VHD 814 Hoover Vision HD wash stops and timer saver light flashes. Does not wash properly and have to select spin manually. Any answers?
this happens with mine too....
Any solution would be very welcome. The machine seems to have a mind of it's own.
Dec 21, 2010 | Hoover H160E Front Load Washer
Hoover visionHD vhd 842-80 will not complete its cycle (does not spin) lights flashing are 1200 &time saver button
Nov 07, 2010 | Hoover Washing Machines
Not working at all. my washer was on working and i heard a big bang and my electrics went off, i turned everything back on and the washer started up again but then stopped and now will not work. when...
The ticking that you hear is probably the timing motor for the dial.
Was the "bang" from outside the house? If so, then a transformer probably blew and hit your house with a power surge. Motor is likely damaged, and will need replacement.
If the bang was inside the house, the capacitor on the motor probably blew (unusual failure mode though), and will need to be replaced, motor is likely damaged as well.
Sep 18, 2010 | Hoover Washing Machines
Hoover H130E Front Load Washer Logo
43 people viewed this question
Top Hoover Washing Machines Experts
shaun taylor
Hjalmer Lamminen
Hjalmer Lamminen
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
