Question about Sony KV-32FS13 TV
KV-32fs13 TV tuner problem
I'm a new international student in United States, I bought a used KV-32fs13 a few days ago which works fine well with DVD players and the other external devices attached to it, however the man who sold the TV told me that he had no cable to test it for me. I brought TV to home and found out that there's a problem with its tuner which makes the picture to flip between black & white and color continuously with a disturbing buzzing sound. I took the TV back off and found out that when I push the board under the tuner up whole things go right so I'm sure that there is something wrong with the Tuner maybe it has a loose connection but since I'm no expert in dealing with electrical circuits I want to know what should I do? How can I find the loose connection or the problem? Can I use an external tv tuner box instead of its own internal tuner? I also wanted to have a technician look at it but it costs tooooooo much about 3 folds that I paid to buy the TV so I as a student can't afford it.
  • 790 Answers
Hi
This defective Crystal frequency, The tuner is also a suspect. but this is expensive to replace with no surety if defective or no. for me this nedds to diagnose!
Thanks!
Posted on Dec 27, 2008
When I type Shift + @, my new Acer computer give me " and vice versa. How may I alter this?
This is probably a different keyboard layout that you used to know.
  1. Click Start , type intl.cpl in the Start Search box, and then press ENTER.
  2. On the Keyboards and Language tab, click Change keyboards.
  3. Click Add.
  4. Expand the language that you want. For example, English (United States).
  5. Expand Keyboard list, select the United States-International check box, and then click OK.
  6. In the Default input language list, click Language name - United States-International (where Language name is the language that you selected in step 4), and then click OK two times.
  7. In the Regional and Language Options dialog box, click OK.
    Notice that the Language bar appears on the taskbar. When you position the mouse pointer over it, a ToolTip appears that describes the active keyboard layout
  8. Click the Language bar, and then click United States-International on the shortcut menu that appears.
    The United States-International keyboard layout is selected.
For more help check here
May 22, 2011 | Microsoft Windows 7 Home Premium 64BIT...
New Vizio tv shuts off after June switchover
Well, your TV is no doubt under warranty. The only reason I can thing of why they want you to use a DVD player is to find out if the Digital Tuner inside the TV is the source of the problem.
They need to replace the Digital tuner board or the main mother board. Either way, they have to come out to your house to replace a part.
Just keep hammering them of the warranty coverage.
Jun 27, 2009 | Vizio L32 32 in. LCD HDTV
How do I bypass the bad tuner on my Sony KV-32FS13 through my VCR - I have DISH Sat.
Hookup the the vcr to the AV jack then plug the antenna and other devices into the vcr and tune everything through this. The AV ports on a TV are independent of the internal analog/digital tuner.
May 08, 2009 | Televison & Video
Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Oct 02, 2008 | Sony KV-32FS13 TV
Sony WEGA TV Model KV-32FS13 analog or digital?
No...your set has a digital tuner. Many of us will have a source
box for other reasons, such as getting sports packages or
movie channels......T.
Feb 27, 2008 | Sony KV-32FS13 TV
Blowing Fuses
main rectifier could be shorted, main regulator could be shorted MOV surge supressor is probably shorted. MOV will be a little disc close to the power cord input (after fuse).
Jul 31, 2007 | Sony KV-32FS13 TV
[MSI 8606 TV Tuner Card] Can't get a picture
here is a link for the driver, http://drivers.softpedia.com/get/TV-Tuner-Co/Others/MSI-TV-Tuner-Master-8606-WDM-279165.shtml
Mar 10, 2007 | MSI 8606-020
No signal error when turning on TV
check if have signal tuner frecuency intermediate or fi. and if tuner is bad maybe cost is 85 dlls
Jan 19, 2007 | Sony KV-32FS13 TV
Will not work with cable
The set has a problem with the tuner itself and there are no resets in this new sets,you should remove the back cover and carefully tap with a wooden or rubber handle the tuner area where the cable comes in to see if a channel would tunes in,if it does react is likely it has loose conections in the tuner grounds or pins,the conector where you screw the cable to can not be loose either,it should be nice and solid,if you are familiar with tv service is something you can try but if you are not too familiar call for assistance from a servicer or just save the money and use a vcr to change the channels using the same imput as the dvd player unless you have two separete aux.imputs. Let Us know if you need more information.
Nov 10, 2006 | Sony KV-35S45 35" TV
Sony KV-32FS13 TV Logo
83 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
