Question about Teac RW-H300 CD Recorder
CD recorder difficulty
CD recorder stops at 35-45 minutes into a recording session and flashes "update." Can not finalize CD at this point and then a "disc error" message flashes. Happens whether it is only 1 long track, or several shorter tracks. Also happens no matter what mode I use to record: "record disc", "record manual" "record track" etc. Used several different types of CD-R's with no difference. This is an older Phillips model, but never abused. Getting tired of recording 25 minute CD's!
2 Suggested Answers
  • 218 Answers
SOURCE: Philips CD Recorder
Have you tried cleaning the lazer lens with a cleaning disk?
Posted on May 21, 2007
  • 112 Answers
SOURCE: CD-RW880 records only 10-15 minutes then stops
Sounds like either the grease on the laser rails has soldified making it difficult for the laser to push part it(easy fix)or some teeth have stripped off the gearing that moves the laser ( not so easy) - first thing to try is take the casing off,and use a q-tip or similar to run down the laser rails with the tray out of the unit.
Posted on Jan 28, 2008
0 characters
1 Points
Power failed in middle of a recording session when the machine was in Pause mode. How can I recover the recorded file?
You can try computer software like Nero or Roxio and finalize the disc as it is. This is exactly why I had advised Churches that went from reliable cassette tapes to CDR to put UPS units on the CD recorders as they do not react too well to power outages. If you were using an Open Reel there would be very little loss of the recorded signal.
Mar 24, 2013 | Marantz CDR-300 CD Recorder
That's a normal response to an interrupted Finalization.
The recorder was switched off/unplugged after recording without ejecting the disc. The recorder could not write essential recording information onto the disc.
While REPAIR is displayed, the recorder automatically examines the recorded area of the disc and updates the track numbers and recording time data. This process takes about 40 minutes for a fully recorded disc. Finalization or further recording is possible once the REPAIR message disappears.
Jan 23, 2011 | HHB BurnIt CDR830 CD Recorder
After i have finish recording and i am finalizing the the cd code OPC appears on the screen, and being finalize the cannot play in other cd player why?
OPC means the unit had trouble Optical Processing Calibration, which means the disc surface may be damaged. Using brand name media and being careful to not touch the recording surface would help.
It's not completing the finalization so it won't play in a CD player yet.
It's mostly in the manual
OPC: Stands for Optical Processing Calibration.
When you see this message in the Information
Display for the Record DeckK, it means
that the laser transport inside the unit is making
the calibrations and adjustments needed so that
the recording process is optimized for the specific
disc in use.
When an unfinalized CD-R or CD-RW disc is
placed in the Record Deck%, the letters
OPCwill flash once the Table of Contents has
been read. This indicates that the unit is optimizing
its circuits for maximum compatibility with
the specific recordable disc in use. the number
and total running time of any tracks that have
already been recorded will appear in the
Information DisplayK, and the appropriate
indicator SPwill light to tell you if a CD-R or
CD-RW disc is in use.
To Finalize a disc, place it in the Record
Drawer%. Once the disc's Table of Contents
information has been read and the OPC process
has been completed, press the Finalize button
E@and note that the Finalize Indicator
Uwill begin to flash. Within three seconds,
press the Select button9*and note that
the Finalize IndicatorUwill stop flashing.
The Finalization process will take up to two
minutes, depending on the length of material
recorded on the disc. During the Finalization
process the Record Deck will not accept any
operating commands.
Dec 29, 2010 | Harman Kardon CDR20 CD Player
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
How do i finallize disk with my tdk da-3826 dual-cd recorder
Press the Finalize button (and it will start flashing) and then press Play button right away (the finalize light will stop flashing and be a steady light).
Once the disc is complete the CD-R light will change to CD.
Dec 23, 2008 | TDK DA-3826 2-Disc CD Recorder
Can't finalize disc
wonder if thers firmware update for that model try anther cd just make sure not bad disk ok maxwell reg ones just fone always burn slower then needed also cheak website for firmware updates if avb
Oct 06, 2008 | Marantz CDR631 CD Recorder
Need user manual
I have the CDR-200 and did not have the manual either. However, I did discover the same problem and found the solution. There is a "confirm" button on the front of the unit under the display area. After you press the record button "Record" will begin to flash in the display area and then you press "Confirm". It should start recording. Note however the following:
Before starting this procedure make sure you have an AUDIO recording CD in the RECORDER tray of the CDR-200. A regular CD-R type of disc for computers is not going to work and may cause an annoying message on the display which does not go away until you put the right type of recording CD in the unit. It must be either an AUDIO CD-R or an AUDIO CD/RW.
1. When copying from an external cassette deck, you should set the source (press source button) until the setting is "Analog".
2. The "Dual" button should not be in effect. In the lower right portion of the screen you should only see a small number "1" with a circle around it. This indicates the CDs currently being used by the burner. In "dual" mode you can copy from the Playback CD of the CDR-200 to the Recorder CD. In dual mode you see "1" and "2" with circles around them. The active CD tray will flash on the display.
3. When copying from an external cassette unit, you use the "Record" button to start the recording. At the end of the cassette track you MUST press the STOP button by the CD Recorder tray. After you press STOP the unit will say "Update" which indicates it is closing out the track on the CD-R. You can continue to write tracks by pressing RECORD again, then CONFIRM when the tape is positioned at the right PLAYBACK track. It is usually helpful to have a few seconds of blank tape at the start of the PLAYBACK track before pressing RECORD. Press play on the cassette deck, then RECORD followed by CONFIRM on the CD burner.
4. When the track has finished burning you must press STOP to close the track on the CD-R. After you press STOP, the unit will display "Update" to indicate it is updating or closing the track. When the process completes, the unit will display the tracks it has written to the CD-R and will be ready for you to copy another track or FINALIZE the CD-R. When the unit is waiting after the STOP, you can change the cassette tape, reposition to a playback track and ready the playback tape for more recording. When the PLAYBACK tape is ready repeat STEP 3. Repeat steps 3 and 4 until you have about 14 or 15 tracks on the CD-R.
5. When you have finished recording about 14 or 15 tracks onto the CD-R, you will want to finalize the CD-R. Press the FINALIZE button, and then press the CONFIRM button. You will see the the unit start to display the progress of the finalize by advancing the level meters of the left and right channels in the display. When the unit is finished finalizing it will return to the number of tracks display for the CD-R. After finalizing the CD-R you can play it back to make sure the burn was successful. Be sure to wait for the tracks display before removing or playing the CD-R after the finalize is done. Removing before the finalize is done may damage the unit and may render the CD-R bad.
1. Set the unit to "Dual" mode. As described above, you will see "1" and "2" with small circles in the lower right portion of the display.
2. Make sure the "Source" mode is set to "Analog" by repeatedly pressing the SOURCE button until it shows "Analog".
3. When copying from the PLAYBACK CD tray you will not use the RECORD button by the CD Burner tray. You will use the 'DUB" button just to the right of the display.
4. Put an audio CD in the PLAYBACK CD tray and press the skip track button ">>" until you arrive at the track you wish to record from. If the track you want to start at is track 1, then you don't need to skip tracks.
5. When positioned at the correct playback track, press the DUB button. The unit will show "CDR" and then "DUB" on the display. When it says "DUB" press the CONFIRM button. The unit will start recording. You can adjust the record level during the first few seconds to make sure you don't have the recording volume level set too high.
6. When the track is finished, you should see the unit indicate on the display "Update". This indicates it is closing the track and it should do this automatically. If it does not do this you may have to press STOP near the RECORDER Tray to force closing of the track. Usually the unit indicates "AUTO" in the display area and I believe that is what controls the automatic track numbering feature. I am not sure how the AUTO feature is turned on. I noticed on the CDR-200 it is on by default.
7. After the UPDATE is complete, the unit will display the number of tracks it has written to the CD-R. You can at this point change the PLAYBACK CD to another one or advance to another track for continued recording. When at the correct track simply go back to step 5 and continue.
8. When you are all done copying tracks from one or more CDs, and you wish to finalize the CD press FINALIZE and then press CONFIRM to start the finalize process. I noticed on the CDR-200 if you wait too long after recording a track the unit may start the finalize process automatically. This happened after at least 5 minutes. It is best to try and stay with the copy process to monitor what is happening. The finalize can also start if you have written to many tracks to the CD-R and it runs out of space. Typically, your safe if you burn about 14 to 15 tracks to a CD-R at a time. You might be able to fit more if the tracks are very short (2-3 minutes each).
One last note about the connections on the back of the unit. Read the labels of the connections on the back very carefully. The CDR-200 and probably the 201 have separate outputs for the PLAYBACK CD (CD) and BURNER CD (CDR). You will want to connect these to seperate inputs on your audio amplifier. Or you might also wish to merge them using adapters into one input on your audio amplifier. If you keep them separate you will need to change sources on the audio amplifier to hear each tray. For example, you might need to switch to "CD/TAPE" for the CD, and "AUX" for the CDR. It is probably easier to merge the two using audio adapters which can be readily obtained from RadioShack.
I hope this helps!
May 08, 2008 | Classic Electronics CDR201 CD Recorder
Recording Errors
Hi. I did a google search to see how to fix mine. It's doing the same exact thing. I wonder if the CD's are the problem. I hadnt'had problems in the past, but I'm thinking maybe the companies are making their cds's a little different with the speed. I use the audio cdr's but I have had this problem.
Sep 25, 2007 | Philips CDR770 CD Recorder
Hi i would say try other cd recordable media but it sounds like your player has a tracking/laser pick-up problem or a laser mechanism fault,i would suggest you take it to the nearest repair agent to get them to look at it for you. regards. paul.
Sep 04, 2007 | Teac CD-RW880 CD Player / Recorder
Open Questions:
See all Teac RW-H300 CD Recorder Questions
Teac RW-H300 CD Recorder Logo
Top Teac CD Players Experts
Jaime Hernandez
Are you a Teac CD Player Expert? Answer questions, earn points and help others
