Question about Bose Lifestyle 30 System
How to connect Apple TV to Bose Lifestyle System
Serial # 035417951860339AE
SOURCE: How do I connect my iPod to Bose Lifestyle V20 System
You can only Connect a iPod via a iPod dock
Apple iPod Univeral Dock
and use either
Apple Composite AV Cable or Apple Component AV Cable
based on what Output you iPod Allows.
the list of which iPod that is supported is listed on each page of the AV Cables above.
You can use a IR Blaster Cable with the iPod Dock to control the iPod also.
Posted on Feb 01, 2009
SOURCE: System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Posted on Feb 05, 2009
SOURCE: Bose Lifestyle V20 Error 180
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Posted on Mar 10, 2009
SOURCE: audio problems connecting ps3 to bose lifestyle 48 system
audio has to connected seperatly.vs 2 is for video connection only..Bose is a ripoff.... u pay all that money and you need a seperate audio connection plus all those wires..it isn't worth it and regret i bought it.
Posted on Dec 28, 2009
SOURCE: Connecting ipod to Bose lifestyle 48
I have a Lifestyle 48 and called Bose today. It is possible all you need is a cord that is a 35mm headphone jack on one side and RCA jacks on the other. You plug it into the AUX jack in the back of your system and the headphone jack in the Ipod headphone spot. I got the cord at Best Buy for ten bucks. It works GREAT!
Posted on Apr 20, 2010
I try to plug apple TV to my Bose sytem lifestyle 20. The apple TV is plugged by hdmi on my TV (hdmi2). The apple tv image is good but the sound is coming from my tv not from my bose system. i decided to...
You might want to try connecting the Apple TV to your TV using HDMI, then using the optical cable from your TV to your Bose system. In your TV's settings, there should be an Audio Output option. You'll want to turn off the TV speakers. Optical audio can be a little strange compared to traditional analog. If your cord is going bad, it could result in behavior like you described.
Jan 24, 2011 | Bose Lifestyle 30 System
Problem with Airport express to BOSE Lifestyle
When i play the radio on my bose lifestyle , my radio sounds good. but when i send music with from my apple computer to . airport, and then to my bose lifestyle, the sound just come out from on 1 speaker. not the toher ones, but when i play radio all 5 works....
anybody got a solution??
Alex, Sthlm
Jan 20, 2010 | Apple AirPort Express with Air Tunes
Have audio through TV can't get audio through Bose
It sounds like your signal path from the dvd is going through your TV, rather than through your Bose V30. Either find an audio out port on your TV and route it back to an aux in on the V30, or, preferably, run your DVR and your DVD to the V30, and then from the V30 to your TV.
I hope that helps.
________________________________________
Download Bose LifeStyle V30 User Manual
Dec 12, 2009 | Bose Lifestyle V30 Home Theater System -...
The remote for Bose lifestyle V20 system does not work with Apple TV. I have component video coming out of the Apple TV into the Bose V20 system and then HDMI from the Bose V20 to a Sony Bravia HDTV. I...
I had the same problem, and called Bose tech support. They put me on track to the solution. The code you need is under AUX, Music Player, Apple where you probably looked already. The secret is that you need to "unpair" the apple remote first. If I remeber right, in apple TV you go to settings, general, remotes and unpair your remote. It still works, but is no longer the only remote that works.
Gerry
May 01, 2009 | Bose Lifestyle 20 System
and use either
Jan 04, 2009 | Bose Lifestyle V20 System - black Theater...
Integrated System (Bose Lifestyle) vs Component System
Better is a subjective term. Simpler vs complex is more accurate. I'd go for the separate components if conspicuity is NOT required and to allow unlimited future growth. Sub/sats have their place but nothing beats having full-range speakers alll around the room with some real horsepower to push them.
Dec 26, 2008 | Bose Lifestyle 30 System
TV audio through Bose Lifestyle 38
Did you select TV input on your AV38 Bose system and same thing for VCR. it should work unless from your TV audio if you watching HD signals some of the program had copy protection so it turn off the video and audio out at your TV output monitor that for TV
For VCR it must work make sure you select VCR input on your AV38
I hope that give some ideas
Dec 15, 2008 | Bose Lifestyle 38 System
Apple TV and Bose Home Theater
You should be able to connect hdmi from apple tv to bose v30 for picture and sound. You can also run component video to bose and a hdmi out of bose to tv. Just make sure your running hdmi out of bose system to tv if your tv supports hdmi if not use component video cable. Another way which isn't as good of quality is to run fiber optic from apple tv to bose v30 and hdmi straight to tv.
Nov 02, 2008 | Bose Lifestyle 30 System
Audio trouble with Bose System
make sure you have connected the rca cables from the 'out' of the TV to either of the video 'in' channels or try the tape 'in' on the bose. hope this helps. which bose are you using?
Aug 09, 2007 | Bose Lifestyle 48 System
Bose Lifestyle 30 System Logo
1,721 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
