Question about Logitech MouseMan Wheel
Take apart a mouseman
I have an older Logitech mouseman that needs cleaning. I would like to take it apart. There is a screw on the underside that I loosened but at the front where the cable connects, the bottom of the mouse stays connected to the housing. Is there a special place to push or pull to get the top to separate from the bottom?
  • jamey staub Apr 19, 2007
    I found that by carefully wiggling the bottom in a side to side fashion loosened the top from the bottom.
  • 33 Answers
Is it a wheel mouse or a lazer mouse if it is a lazer mouse all you have to do is unscrew it all the way and it should come off easly
Posted on Apr 19, 2007
SOURCE:
Logitech Mouseman Driver Does Not Automatically Load At Startup
Try troubleshooting your mouse here. You may also need to UPDATE your drivers. Also try changing the USB input. Plug it into a different one.
Hope this helps :)
Jan 20, 2008 | Computers & Internet
My mouse moves very little and I need to move my hand 5-6 times to reach the other side of screen. If i clean out the bottom laser hole it will work for a short while propperly.
Try cleaning the laser hole with a Q-tip and denatured alcohol. Also clean the surface that you are using the mouse on.
Hope This Helps.
Zeppelinx12
Mar 06, 2011 | Logitech Cordless MouseMan 2 (911163-01)
How to clean the underside of the scanner glass on an HP4400C flatbed scanner.
This is acutally easier than it looks. I just had the same problem with a cloudy film starting to form underneath the glass on my older HP 4400C scanner.
First completely remove the hinged top lid by lifting straight up on both long ends of the lid - notice the 2 hinges on the back end of the lid will come straight up and out of the body of the scanner, still attached to the lid.
Next look down inside the 2 hinge holes (on the main body of the scanner where the lid hinges just came out of) and you will see a screw in each hole. Remove both screws using a phillips screwdriver. This will allow the rear end of the scanner to come apart enough so you can now lift it up a few inches to separate it and get your hand inside there to clean the underside of the glass with a soft cloth - BUT JUST REMEMBER THE FRONT END OF THE SCANNER WILL STILL BE CONNECTED, so don't pull it too far apart because it could snap and break something that is still holding the front end together. (I could not figure out how to separate the front end piece, and then I realized I didn't have to).
So on the rear end of the scanner, now carefully pull the light upper colored plastic apart from the lower dark plastic just enough so you can get your hand inside the compartment and use a soft cloth to clean the underside of the glass. I just used a small piece of an old cotton t-shirt with a couple little dabs of water on it and then just kept rubbing the dirty areas on the underside of the glass over and over until all the dust film/streaks disappeared and the glass was once again clean and all clear.
Then gently lower the glass back down and line up the plastic pieces together on the rear end and put the 2 screws back in the hinge holes, and then reinsert the hinges in their slots and lower the lid back on top of the scanner glass and it is ready to go again !!
Hope this works for you like it did for me.
Nov 19, 2010 | HP Scanjet 4400c Flatbed Scanner
I need to change my batteries and do not haVE A MANUAL
Battery is at the bottom. Open the cover at the base and slide it and it will pop open.The battery is there and you can replace it.
Take care.
Aug 12, 2010 | Logitech Cordless MouseMan Optical
I need to downloed m rg53 crdless mouse logitech
logitech.com support has software for all of their mice. I'd look at that sight and download the appropriate software for your mouse and os.
Jan 26, 2010 | Logitech Cordless MouseMan 2 (911163-01)
How to diassembly mouseto clean a left button
Is quite easy to take a mouse apart, there is usually only one screw on the bottom which you can undo with a phillips screw driver
If you see no screws on the underside of the mouse they might be underneath the little rubber pads on the underside of the mouse.
Once the screw is out the mouse should split into 2 parts, the top half containig the buttons that you wish to clean. All the mouse buttons are normally connected together on one flimsy bit of plastic that can break easily so be really carefull getting the buttons out. On most models of mouse the buttons will just pop out together with a little gentle pressur or wiggling, try and remember exactly what you do as you dissasemble the mouse as this will make re-assembly a lot easier
Would not reccomend this with an optical mouse(the ones with the red light on the underside)
good luck!
Jul 01, 2009 | Logitech LX 700 9674180101
Software for Logitech cordless mouseman won't install
MY RECOMMAND YOU TO GO ONLINE TO:
WWW.LOGITECH.COM/DRIVERS
WWW.LOGITECH.COM
FIND TECHN SUPPORT OR THE DRIVERS SECTION AND FIND THE MOUSE DRIVERS AND DOWNLOAD NEW DRIVERS.
*****************************************************8
*************IMPORANT*************************
REMOVE ANY MOUSE DRIVERS, LOGITECH OLD ONE AND ANY MICROSOFT ALSO
GO INTO CONTROL PANEL TO PROGRAMS AND FEATURES AND REMOVE ALL MOUSE DRIVERS AND REBOOT THE SYSTEM.
THEN RE INSTALL NEW DRIVERS AND REBOOT..
ALSO CHECK THE POWER SOURCE OR REPLACE THE BATTERIES BEFORE REINSTALLING THE NEW DRIVERS
THE LAST THING IS TO PUSH ON THE RESET BUTTON ON THE BUTTOM OF THE MOUSE IF IT HAS ONE
UNTIL THE COMPUTER SAYS IT HAS FOUND SOME NEW HARDWARE.
THE SOFTWARE YOU HAVE MAYBE OUT DATED AND WILL NOT WORK UNTIL YOU ACTIVATE IT BY GOING TO THE WEB SITE AND THAN IT WILL ASK YOU IF YOU WANT TO UPDATE.
DRIVERS ARE CORRUPTED SOME HOW AND UNREADABLE
RODGANDYSR
Mar 03, 2009 | Logitech Cordless MouseMan Optical
Cordless mouseman optical fixing
If you have alll the parts, it should not be difficult. If repairs are beyond your scope of expertise, replace it...accordianman
Jan 31, 2008 | Logitech Cordless MouseMan Optical Wheel...
Logitech MouseMan Wheel Logo
137 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
