Question about Brother MFC-7820N Laser Printer
DR MODE - using the machine as a fax with a separate phone line
I have a small business and purchased the MFC-7820N printer. How do I program/set-up the fax capability to that it will "acknowledge" the distinctive ring of someone sending a fax so that it automatically detects the other end to be a fax and switch over (without me being home)? Likewise, when the other end is a person who wishes to leave a voice message, how do I program the machine to know that if it is not a fax transmission it should revert back to a landline so that the person can leave a voice message on the answering machine. For some reason, it is staying in "DR Mode". What is this? Thanks, so much!
  • Anonymous Feb 09, 2008
    dwas
SOURCE:
Mix-it-up
  • 832 Answers
SOURCE: "Receiving Sleep" on Brother Fax 4100
you might have to change the settings for the switching time into stand-by. plz have a look into the manual which describes these settings (zero seconds are possible)
Posted on Jan 10, 2008
Mix-it-up
  • 832 Answers
SOURCE: Fax does not receive or send
plz contact brother hotline of your country ( www.brother.com )because there are so many diffrent telephone standards which might affect a good working of the fax abillity.
Posted on Jan 31, 2008
SOURCE: Brother MFC 7820N
how do i program one touch dialing on my brother MFC 7820N fax machine
Posted on Sep 10, 2008
  • 215 Answers
SOURCE: All-In-One Brother 7420 not receiving
try leaving easy receive on and changing the receive mode to manual. when you pick up phone and hear the other faxs' tone, wait for your machine to take over by listening for the chirps. then hang up. if you don't hear chirps from your machine, then press *51.
hth,
razors
Posted on Jan 09, 2009
SOURCE: Brother MFC-240 will not receive faxes...
I cant get my MFC-290 to receive incoming faxes
Posted on Apr 27, 2010
Im using the Brother MFC 7820n at a hotel. how do i fax? i've tired 9+1+area code+the number, 9+area code+the number and a few others but nothing seems to work, what am i doing wrong?
Depends on the hotel.
Some have a specific dedicated line that allow direct dial (no 9). Some block long distance calls and required the use of a calling card.
Otherwise, dialing 9 should work.
Can you hear the dial tone? What kind of sound do you hear when it fails? Is ti list a fast busy signal? Or do you just hear nothing?
If they have the speaker off, try to call your cell phone from the FAX just to see if it can make an outbound call at all.
Also, try tracing the wire from the fax machine. Make sure it is plugged into LINE and not PHONE. (or the jack with the picture of a wall jack, not a picture of a phone). Some hotel patrons disconnect FAX machines to use the phone line on their laptop modem and then neglect to properly reconnect the fax machine. Also make sure it is connected at the wall.
Apr 20, 2011 | Brother MFC-7820N Printer
How do I increase the number of rings on my Brother MFC-780n fax/printer before it picks up?
Setting the Ring Delay
The Ring Delay sets the number of times the
MFC rings before it answers in Fax Only or
Fax/Tel mode. If you have extension
phones on the same line as the MFC or
subscribe to the telephone company’s
Distinctive Ring service, keep the Ring Delay
setting of 4.
(See Operation from extension telephones on
page A-4 and Easy Receive on page 4-3.)
1 If it is not illuminated in green, press
(Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many times
the line rings before the MFC answers
(00 - 04).
Press Menu/Set.
(If you select 00, the line won’t ring at
all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Apr 02, 2010 | Brother MFC-7820N All-In-One Laser Printer
Printer says DR mode in use what does this mean
DR Mode means distintive ring. This is if you are using two or more phone numbers on one line. For example, you could have your voice mail number and your fax number on the same line, but when a call comes in to your voice mail the fax will recognize the ring pattern and won't pick up the call. If it is truly a Fax, then your fax will pick up the call by recognizing the ring pattern.
Oct 07, 2009 | Brother MFC 8840D All-In-One Laser Printer
Cannot send or receive faxes
Try to call from your fax if u make calls then the line is ok,if not check the line.check the cable have 4 pin ,Take the user settings in the reports menu,check and confirm the mode is "tone" if its "pulse" change it as Tone.
May 05, 2009 | Brother MFC-7820N All-In-One Laser Printer
Can't Send or Receive Faxes from MFC-7820 N
You may not need a separate fax line from Vonage. If you don't need a dedicated fax line, you can try changing the "Bandwidth Saver" settings on your Vonage voice line from your account on the Vonage website. Perform the following:
1. Login to your Vonage account online and click the "Features" tab.
2. Scroll down to the "Bandwidth Saver" link and click on the "Configure" button.
3. You will see a scrollbar with 3 settings: 30kbps, 50kbps and 90kbps
NOTE: My "Saver" was set to 90kbps (Highest Sound Quality) by default.
4. Click on 30kbps (Normal) and click "Submit".
5. Wait about an hour before testing as it could take that long for the change to take effect.
6. Send a test fax to the HP fax test service at 1-888-hpfaxme (1-888-473-2963).
NOTE: This is a GREAT service provided by HP. If your fax goes through correctly, you will receive a return fax within five minutes.
We upgraded to Verizon FiOS and never thought the increased upload speed (4mbps) would present an issue sending faxes. WRONG. We never had fax issues with DSL, Comcast or even Broadstripe VOIP service but for some reason Vonage + FiOS = no fax. That is until we set our Vonage VOIP sound quality to "Normal". Our phone voice quality has been much more reliable since throttling back. This sentiment has also been shared by other Vonage users who have experienced echoing and noise when utilizing the higher quality settings.
Your phone coversations may not have FM quality sound but they will have AM quality and usually that is just fine.
If your fax machine has a Telephone Answering Device (TAD) setting, you can share your voice line with your fax machine and be able to receive faxes and voice messages. Hopefully this will work for you.
Dave Grannas
Nov 04, 2008 | Brother MFC-7820N Printer
Brother MFC 7820N
Sep 09, 2008 | Brother MFC-7820N Laser Printer
Not able to send fax to an eFax number
I've had the same problem before. I don't know if it will solve your problem directly but I can offer a work around or two.
1. I have an efax number but with a company called callwave.com , I fax stuff to other customers using callwave and my MFC 7820n completes each fax successfully. So if you can get yourself a callwave efax number you can fax to yourself and forward fax as an email to your intended party.
2. Or, you can use your mfc 7820n to scan your fax docs as a pdf directly to your computer and then emailing them to your intended party.
Unfortunately it might be a brother issue because at the office when I use the hp fax machine instead of the brother machine, the hp faxes to efax numbers without a problem.
Sep 05, 2008 | Brother MFC-7820N Printer
Fax doesn't recognize incoming phone call
Try this: using a cell phone, call your fax. Listen on the cell for a busy signal, fax tones, dial tone, etc. If the fax does not answer the cell, check the following: make sure the phone line is plugged into the LINE jack on the fax, NOT THE PHONE JACK. The phone jack is to connect a TELEPHONE to the fax. If problem still exists, press MENU on your MFC, and scroll to GENERAL SETUP, FAX. Scroll to SETUP RECEIVE, and, after writing down the settings, try changing the RING DELAY or RING TIME settings. If problem is still there, press CLEAR/BACK button until GENERAL SETUP appears on screen. Scroll down to INITIAL SETUP, and select RECEIVE MODE. Try changing RECEIVE MODE settings. Write them down before you change anything.
Sep 01, 2008 | Brother MFC-5840CN All-In-One InkJet...
Cannot get printed faxes
the phone line needs filtering off ,because your fax machine is an analoque device
Mar 26, 2008 | Brother MFC-7820N Laser Printer
Brother mFc 7820
I had work done on my laptop. I have a Brother MFC 7820N printer, scanner,fax,copier. I cannot find my cd for setting the drivers to have my laptop use the 7820N. Where can I pull the information down on line to enable my laptop to use my printer?
Shaun at WardLF357@aol.com:
Oct 17, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-7820N Laser Printer Logo
409 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
