1) try to change new batteries with digital batteries from r. schack
2) clean the contacts batteries with ethilyc alcohol and cotton swab
3) use the adapter for to see if the problem dissapear.
4) if the problem dissapear, is o.k .Otherwise you have problem with the Syscom and relative circuit see the block.
Go to the repair shop from your company camera.
God bless you
SOURCE: Canon SD900
First off, see if Canon can help you. If not, the following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
SOURCE: lens do not open
try smacking the sides of camera.also try to make the lens up down with you hand couple of times.then check out.
SOURCE: Canon SC100 Lens Error
I have a 3 year old Canon PowerShot SX100 IS. While testing an external battery power supply I built, the external power connector pulled out while the lens barrel was extending just after I turned on the camera. Power to the camera was lost before the lens barrel fully extended and wouldn't reset when I repowered the camera. The dreaded error message "Lens error, restart camera" appeared and the camera shut down. I restarted the camera over and over and over again but the lens wouldn't reset. I was extremely lucky to find the information here and read various fixes. I didn't want to take the camera apart so I tried various fixes others have successfully used. I first tried smacking the bottom of the camera hard with the palm of my hand just after pushing the on/off button but that didn't work. The one which worked was smacking the camera on the side immediately after I pushed the on/off button. I smacked it quite hard twice with the palm of my hand then, suddenly, the lens barrel began to move and the lens reset itself back to its starting position. Thanks to everyone who has posted here!
SOURCE: Lens not working
How to put the lens mechanism of the camera to its own place?
1. Turn off the camera.
2. Remove your battery and memory card.
3. Unscrew the screws and open the back cover of the camera.
4. Unscrew the screws of the main board.
5. Remove the lens mechanism.
6. Be careful not to touch the rear part of optic parts for protecting to the fingerprints and not to cut the wiring system.
7. Take out the lens mechanism and watch the lens roads. Is there any broken parts around there? If not it is a good news. Then go on to look carefully around the lens mechanism. Is there anything looking unusual? But if you have unusual noise that has two meanings.
a. There is a dust in the lens mechanism. Then it is very easy to fix it. In this position you should give a pressured air to clean it. And collect the camera parts together.
b. There are some broken parts in it. Then there are two solutions.
(1) Give pressured air to clean it. It is easy and does not need to change any part. Go on from 8.
(2) Lens mechanism needs to be changed. Buy new lens mechanism or find it from one of second hand and out of order cameras. Go on from 8.
8. If there is nothing looking unusual, take the lens mechanism to your hand. Then control its move while sliding it slowly and carefully.
9. Collect the camera part as you have unscrewed.
10. Install the memory card and battery.
11. Turn on the camera. Try to focus on any subject specially on the mode that you recently faced with.
Where can you buy a new lens mechanism and how much does it cost?
1. If you need to change the lens mechanism, then you can buy it from http://www.ebay.com
2. Open this address and write to the search box the item number:170482444552
3. You can see the price of this item there. If it is suitable for you then buy it and change it as I said above.
I hope it is helpful.
Testimonial: "Very Thorough. I have not got to try it yet, because I have not had time, but I will defintely try and also take the advice to a repair man, if I can't do it myself."
