Question about Hobart 24 in. LXIC-5 Built-in Dishwasher
Not reaching temp
I have lx18 under counter that only displayes 170 degrees suppose to sanitize at 180.
  • 640 Answers
Those buttons your talking about are calle hi-limits.they pop when the temp inside the booster goes above 215 degrees.does it happen every time after you reset them or just occasionally?the water temp going to the unit should not exceed 150 degrees.if the water is hard in your area the booster may be clogged and therefore causing your problem.how old is your unit?
Posted on Aug 01, 2007
On the machine that we have, there are two [2]push button switches in line for the heater tank. One is on the front of the tank and the other is around the right side. I have always called them clicks-on's but.. they are red in color and need to be rested if ever they get to hot. Be sure to relise that they did infact pop for some resone. Did the tank for some resone run dry?
Posted on Jun 07, 2007
My 1990 BMW 525i is over heating
Try replacing the thermostat. It is supposed to open when the water temp reaches a certain point usually around 180 degrees. It might be stuck in the closed position.
Sep 28, 2012 | 1990 BMW 525i
2000 jaguar xj8 overheating and fans come periodically
Sounds like the temp sensor for the fans is faulty.Check with your dealer where this is and try a replacement.
Jun 19, 2011 | 2006 Jaguar XJ8
Which thermostat do I purchase for my 1994 Dodge Stealth (automatic SOHC)? Choices are Beck/Arnley 170 Degrees F, Stant 170 Degrees F, Stant 180 Degrees F, Stant 195 Degrees F.
either of these manufactures are good just install one with the manufactures recommended temperature rating,as the wrong temp range can change how the car will run.example gas mileage,running temperature,cooling fan operation etc.
May 01, 2011 | 1994 Dodge Stealth
Rinse temp too low, first it comes up to 180 degrees and then drops to wash tank temperature, WHY?
The rinse temp only reaches 180 degrees for a couple of seconds towards the end of the cycle. This will sanitize all warewash and meets most health code regulations. The rinse water temp will drop rapidly as it is incorporated in to the machine and sprayed on the dishes.
Regards
Feb 23, 2010 | Moyer Diebel 24 in. 301HT-40 Built-in...
Why sanitize button?
no, no home d/w will ever sanitize dishes, to sannitize dishes the rinse water has to be @180 degrees or above , only 1 d/w had that capability which was the old kitchenaidmod. which hobart produced for them
Oct 25, 2009 | Dishwashers
Pool Not Heating Display Wrong
where the thermostat is located, the pump is not circulating the water
Sep 04, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Hobart LX30H washing to hot.
what temp is it washing at. washing should not be the problem. This machine is designed to rinse at 180 degrees + to sanitize dishes. The machine could be converted to a chemical sanitize, it would use bleach in the rinse water instead of 180 degree water to sanitize.
Sep 04, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX30
Hopefully you took the suggestion to run the correct 50 amp 208-240 service to the unit.
Converting the unit to an LX30C has a couple of pitfalls. The LX30C is connected directly to the incoming water supply, which should run 120-140 degrees. By reprogramming the unit as an LX30C, the booster would be disabled, which would mean the incoming water would flow through the de-energized booster and be cooling off while it sits in there between cycles and when the unit is shut down.
The incoming fill plumbing (5/8" heater hose) would have to reconnected from the fill solenoid valve directly to the vacuum breaker on the rear of the unit to bypass the booster heater.
On the 208-240 volt LX18/30/40's, the pump motor, booster heater, and sump heater run on 208-240. To convert it to 120 volts you would have to replace the sump heater and reconfigure the motor wiring in the motor junction box.
By the time this is all done, you've downgraded a great machine, confused the next service guy, and have to deal with nasty chlorine and all of it's headaches.
I
Aug 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Counter depth refrigerator
Do you have room to pull the fridge out from the wall, maybe just a couple inches? Pulling it out from the wall should give you more door swing without hitting the counter.
Let me know if this works for you.
Thanks,
Bill
May 16, 2008 | Refrigerators
Oven temp indication
it could be your oven control unit
Dec 10, 2007 | Whirlpool RF367 Electric Kitchen Range
Hobart 24 in. LXIC-5 Built-in Dishwasher Logo
401 people viewed this question
Top Hobart Dishwashers Experts
Marvin
Marvin
Garth Jackson
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
