Question about Symphonic ST419E TV
Where do I connect my games to the tv.
I have my remote. I can put my tv on game mode, but I can't find where to connect the games to the tv.( Symphonic model-WF 13.)
  • 3 more comments
  • Anonymous Dec 29, 2008
    game mode is on tv does not acknowledge the game even after the red white and yellow cables are connected.
  • harleebett78 Dec 29, 2008
    my problem is that there are no connections for the games.The remote that came with the tv can be set on game mode. I looked all over the tv, but I can't find where to connect the games to the set. Where do I plug the games on the set.
  • harleebett78 Jan 06, 2009
    I understand how to hook the red,yellow and white.Even if I buy a converter there is no where on the tv to connect it. My problem is, I have the remote that came with the tv, It can be set on game mode.The problem is there are no place to connect anything.No plugs, no outlets, nothing.Can the video converter still be used?
  • harleebett78 Jan 08, 2009
    yes you are absolutely right!
    That's because the rating was not intended. I was only making a comment, so I thought. But I appreciate all the responses I received.
  • Symphonic Master
  • 5,138 Answers
You have to have external jacks on TV yellow,red,white jacks these are used for hook ups to DVD-VIIDEO games, you can buy a Video converter at Wal-Marts.
Posted on Dec 26, 2008
  • 3 more comments
  • ladywinn
    ladywinn Dec 29, 2008
    Hook, Yellow to yellow/ wh to wh rd to red ////////Video jacks yellow is video--Red&White Audio. Make sure you witch inputs to Aux-game/DVD for external jacks to work.
  • ladywinn
    ladywinn Jan 06, 2009
    YOU WILL HAVE TO BUY A VIDEO CONVERTER box/ THAT HOOKS TO TV AND GAME! EVEN A 7yr old understands this.
  • ladywinn
    I Bet No one else will reply to this and Be rated what you rated a CORRECT ANSWER.YOU Need To Go Back To School.
  • ladywinn
    ladywinn Jan 08, 2009
    Its Funny ,you rated other person higher when the answer is the same.BUY VIDEO CONVERTER BOX you hook TV and DVD to it.
  • ladywinn
    God Bless You have a nice Day.
GO to Wal Mart buy Video convter box that hooks to TV and DVD or Game.
Posted on Jan 06, 2009
How can i put a crown ctt1506lc in game mode without remote?
I could not find an owner's manual online, so you get a generic answer. Look for an "Input" button among the TV's controls. If you don't find one, go to the TV's lowest channel number (in US TV sets, that's Channel 2). Press the Down Channel button once more. That may take you to the external video input, which I assume is what you want for "game mode."
Jul 26, 2014 | Crown Televison & Video
I'm trying to get my TV into game mode. How do I do that?
Please try the following:
  • With the TV on, press the Menu button which will take you to the main menu
  • Then select the "Setup Menu" and press enter
  • Select "Game Mode" and press enter
  • Select "On" and press enter
  • Then press Exit to leave the main menu
These steps should get you going, however if you have trouble please tell me the exact model of your Samsung TV and I can give you further instructions:
Feb 28, 2011 | Samsung Televison & Video
Tv is stock on tv mode. How to change to game mode?
You need the remote to change to game mode. The original remote doesn't appear to be available. A substitute remote with the function is here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=DWT2405&uuid=12931247714820 . The Game button switches to and from game mode. Other universal remotes may work but a source or input button is needed. Then try various codes for either Durabrand or Funai TVs (Funai built the TV). The other issue is that the remote needs to have been programmed at least 6 months after the TV was released. The remotes that are programmed via a USB connection to a computer will definately be able to match the function.
I hope this helps.
Dec 23, 2010 | Durabrand DWT2405 24" TV
How do you put the tv in game mode without a remote
Follow the steps below to switch your TV to game mode without using the remote:
1. Connect the game system to the TV using the AUDIO/VIDEO inputs on the FRONT of the TV.
2. Switch the game system on.
3. Press the "MENU" button on the front of the TV
4. Use the "CH" UP/DOWN buttons on the TV to highlight the "PICTURE" option. This is the first option so should already be highlighted.
5. Press the "VOL UP" button to select this option
6. Use the "CH" UP/DOWN buttons on the TV to highlight the "GAME MODE" option. This is the first option so should already be highlighted.
7. Press the "VOL UP" button to change the GAME MODE setting to "ON"
The TV should automatically switch to GAME MODE if you are using the inputs on the front of the TV.
8. Press "MENU" to exit and play your games.
Hope this helps. Please post back if you need further assistance.
Regards,
BElectric
Dec 06, 2010 | Sylvania 6427FF TV
How to change the tv mode. Its on AV mode and i want to change it back to TV mode
Hello
You can set the Game mode and External input mode at the same time by pressing the GAME button on the remote control. "GAME" appears on the TV screen. To exit the the Game mode and the external input mode, press the GAME button on the remote control again. To cancel GAME mode only, adjust the PICTURE control. The game mode will be set ot 'OFF" automatically. In this case "VIDEO" instead of "GAME" appeares on the TV screen. When you press the GAME button if the TV is off, the TV turns ON and will be in the GAME mode and external input mode automatically.
Nov 06, 2010 | Durabrand DWT1304 13" TV
How do I get the game mode back on?
[USING THE GAME BUTTON]
You may also set the Game mode and external
GAME button on the remote control. “GAME”
● To exit the Game mode and external input
control again.
● To cancel the Game mode only, adjust the
picture control. The Game mode will be set to
[OFF] automatically as explained in the previous
section. In this case, “VIDEO”(external
input mode) instead of “GAME” appears on
the TV screen.
● When you press the GAME button if the TV is
off, the TV turns on and will be in the Game
good luck
Jan 30, 2010 | Durabrand DWT1304 13" TV
Game mode not working properly on sylvania tv
did you try to switch the tv modes Ex. my tv has av 1 av 2 comp 1 comp 2 does it have those modes
Apr 21, 2009 | Sylvania Electronics - Others
I own a symphonic 27" television
I had this problem on a symphonic 27 inch TV I just bought from a friend who no longer had a remote. The thing with the menu and buttons on the front of the TV doesn't actually change the TV to true game mode. I don't know what it acutally does, but it isn't really in game mode. When it is in true "game mode" you can't change the channels until you turn game mode off. What I did was bought a universal remote (a specific one that someone told me about) for 8 bucks at walmart and I was then able to switch to game mode with the Input select on the remote. The remote I bought that actually worked is this one: http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=acc_glance_ce_ai_-2_1_tit/002-3174824-8273629
Make sure you look at it before you buy it and make sure it has a button that specifically says "input" on it. I know that some of the universal remotes don't have an input select button or one that doesn't work. As long as you get a Philips-Magnavox that has that button, you should be ok. Much better solution that paying 30 bucks for a new remote specifically for the TV. Hope this helps.
Mar 04, 2008 | Symphonic ST419E TV
Dwt 1905 tv stuck in game mode
Comcast universal remote code for dwt 1905 is 0171, just tried it, it works
Nov 26, 2007 | Durabrand DWT1905 TV
Game Mode
not familiar with this model but ill try try in the menu puting it on game mode then look for external input mode in the menu and turn it too dont work fix ur remote or bye a new one (be sure that the new remote will activate the game option) good luck windman
Jan 02, 2006 | Sylvania W4913LT TV
Symphonic ST419E TV Logo
293 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
