Question about Dynex 32 in. LCD Flat-Panel HDTV
Connecting pc speakers to a dynex lcd tv
Is it possible to connect the logitech x-540 speakers to the dynex 32" lcd tv, and if so how?
usmcdcf
  • 5 Answers
SOURCE: Dynex 19 LCD
Yes, the current video driver is not configured for the higher resolutions supported by the Dynex TV/monitor. I ran into this same problem setting up my system. The solution is simple and only requires that you uninstall your current video driver and reinstall with the latest version driver for your systems VGA. You should be able to run the monitor at a resolution of 1440 x 900 with Color Quality at 32 bit Highest. Hope this helps.
Posted on Jan 11, 2009
SOURCE: need tv code number for 32"LCD Dynex Television for my universal
Ran a search and someone said Funai made it's codes are 0818, 0179, 0171
Someone else said it's made by Orion codes are 0236, 0179, 0463
You can try these codes hope they can help you.
Posted on Mar 25, 2009
dsacco86
  • 1077 Answers
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
Posted on May 29, 2009
SOURCE: How do you shut off the internal speakers in Dynex
The best solution i have found so far is to hit the mute button on the remote. It will display a small "MUTE" box in the lower left corner of the screen for a short while, but that will disappear. Another issue that makes this solution less than perfect is that you must hit the mute button every time you turn on the TV. There's got to be a better way, but I just can't find it.
Posted on Jan 29, 2010
tvtek
  • 1284 Answers
SOURCE: Trying to change tv format on my dynex 32 LCD
You are looking for a picture size, format or screen size button on the remote control to solve the issue. If it connected to a HD cable or satellite box then they also have format or picture size settings.
Posted on Apr 13, 2010
Hi, I bought recently a new 5.1 Surround Sound System Logitech X-530 and want to connect it to our new LCD LG 32LD450 HD TV. The LG TV has apart from all Digital, Optical and RCA Connections as well one...
You can't connect the speakers to your TV. I doesn't have any audio output available, just inputs. Those are for connecting the audio from sources like DVD players, and they go in to the TV's sound system. But there's no way of getting the sound out except through the set's internal speakers. The surround system you got is great for a computer, but it's not what you need for TV use.
The only solution I can offer is the suggestion that you invest in a home theater receiver. You can get decent basic systems with the receiver (often with DVD/audio CD playback capability built in) and surround speakers at reasonable prices. Then you use that to drive the speakers, and use the TV just as a video monitor. Then you will have surround sound.
Jun 01, 2011 | Logitech X-530 Computer Speakers
Connecting Logitech speakers to Sylvania TV
"All the audio inputs in the tv dont fit with the cable from the speakers." You would be connecting the speakers to an audio output on the TV.
Mar 18, 2017 | Sylvania LC320SS9 32 in. LCD TV
Surround System for TV
As far as i know you are unable to connect your PC and T.V to your PC sorround system sorry.
Dec 28, 2008 | Logitech X-540 Computer Speakers
What does the little electrical bolt symbol mean?
this is obviously a power or connectivity issue, check that the device ( your ipod ) is correctly seated into the logitech speaker system, and check the power cables are connected according to the manual which came with the logitech speaker system.
question u may ask yourself? - does the ipod work as it should on its own? (without non-apple devices/components attached to it) - if it doesnt - take to an apple store or call or seek apple support.
it sounds like your ipod is low on power from source.
i hope this directs you in the right direction, party on!
Nov 30, 2008 | Dynex 30-Pin Dock Adapter for Apple iPod...
X-530 with LCD Vizio TV
you need to go to radio shack and buy a y plug to be connected between tv and computer. unless i miss understand you...
Nov 05, 2008 | Logitech X-530 Computer Speakers
Connecting Logitech X-530 speakers to TV flatscreen.
It really depends on what the Tv is capable of, and how you want to strategize the connection, but yes, it can be done.
According to the X-530 User Manual , the speaker system comes with an included video game adapter, for hookup with a console. if your LCD TV has stereo RCA output jacks, you could hook up your speakers to it in that fashion. If not, you may have to buy an adapter that converts whatever you have to RCA.
Another way you could attempt to connect it, is to buy a stereo RCA-to-3.5mm (g9) adapter, and connect to your computer's line in (if it's stereo). Your computer would be doing all the speaker sound positioning, and would have to be left on while you're watching TV, but that would work, as well.
Jan 01, 2008 | Logitech X-530 Computer Speakers
LOGITECH X530
Locate the Audio output on your TV and connect it to ur X530 Audio input. Locate ur Audio output (exa. AUX-OUT, MONITOR OUT, ETC..) on ur Home audio then connect it to ur X530 audio input. Goodluck
Aug 11, 2007 | Logitech X-530 Computer Speakers
Can the cable ends be converted to fit a DVD?
You can certainly purchase a cable or an adaptor to connect the speakers to almost anything - this however is not the issue - z5300 computer speakers have an impedance of 8 ohms, whereas most home theatre systems will be set up to use speakers with an impedance of 4 Ohms or 6 ohms or 8 ohms - using the wrong type in the wrong configuration is very likely to result in damage. Also the speakers contain their own amplifier, and are designed to accept an input that has not been amplified to speaker levels before - most tv/dvd audio output will be amplified, depending on the model, so will almost certainly destroy your speakers unless you have a low amplification output on your tv/dvd. If you post back with the make and model of your tv and dvd player, hopefully i can find the necessary info to describe how you could make the connection if it is possible. Logitech says; "Logitech speakers are powered speakers and are designed to be used with a home computer. However, it is still possible to connect your speakers to many other devices. You can connect any Logitech speaker to any device that has a pre-amp mini-headphone jack. Home amplifiers will normally contain a standard ¼" headphone jack. You'll need to purchase a ¼" to 1/8th" adapter to connect your Logitech speakers to a home amplifier. Note: Under no circumstances should you connect your Logitech speaker system to an amplified output such as the rear outputs of a home amplifier. Doing so may cause damage to your Logitech speakers as well as your home amplifier." Hope this helps - please post back with details :)
Apr 19, 2007 | Logitech Z-5300 Computer Speakers
Dynex 32 in. LCD Flat-Panel HDTV Logo
907 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
