Question about Sony KV-32S45 32" TV
KV-32S45 Disappearing Picture, Good Sound
My Sony KV-32S45 has worked great for years, no problems. Just a few days ago, the picture started disappearing. The TV turns on fine (red light flashes for a few seconds before picture appears), and will work great for about 5 minutes. Then the picture gets compressed to the upper third of the screen, in kind of a trapezoid shape. The picture is full width at the top, and only a few inches less than the screen width at the bottom of the picture. The picture wavers quite a bit during this time. This usually lasts for 2-5 seconds, and then the screen goes blank (no flashing red light though). The sound is working fine the whole time. I've read through solutions to similar problems, but this one seems unique enough that I'm not sure of the solution. I do have a service manual that I found free on the web, with instructions on how to safely open up the chassis and replace parts. I am also comfortable enough with a voltmeter and soldering iron that I feel I can do some minor repairs. I'm just not sure where to start. Anyone have any ideas? Is this something that can be fixed with adjustments or do I need to order replacement parts? Also, if this is fixable with replacement parts, can anyone suggest a good place to order from?
  • Bruce James Apr 20, 2007
    Thanks tony91, you are the second person to tell me this. Just in case someone else needs this information in the future, on my schematics, it is actually a 7-pin IC: TDA8172. It is marked as V-OUT, Ref # IC561 for this model, the Sony Part Number is 8-759-980-58. I was able to find the part in stock at Tritronics for $15.36.
  • Bruce James May 31, 2007
    Finally got around to working on the TV last weekend, I replaced the IC, as well as 2 capacitors and a resistor:
    REF NO PART NO DESCR REMARK
    C561 1-126-967-11 ELECT 47MF 20% 50V ($2.14)
    C565 1-126-969-11 ELECT 220MF 20% 50V ($4.57)
    R565 1-215-890-11 METAL 470 5% 2W ($1.07)
    I was able to purchase these parts through Sony:https://servicesplus.us.sony.biz/sony-pa...
    TV is working great now!
Lightly tap circuit board using any non conductive thing like plastic ruler or wooden stick. If picture apears then look for bad or cold solders. Resolder all Vert. IC pins.
Posted on Oct 07, 2007
  • 81 Answers
Yes you have a bad vertical ic . i,ve seen bad conections on this ic too, it may not need to be replace its a ic that stands up 6 pins the numbeer on it starts with TDA
Posted on Apr 20, 2007
Sony KV-32S45 turns on at first, than blinks out, still sound
I would look for intermitent solder connections on the small horizonal driver transformer as well as other HV Componets.(HV Transformer etc.) Also solder up the Vetical output IC. These have been common causes of failures. I would not use the set until these have been checked and soldered. If you don't, a massive failure of the hoizonal circuit and powersupply will occur.
Hope this helps,
Skyassoc
Jun 18, 2009 | Sony KV-32S45 32" TV
Picture stays on for 3 mins, then slowly disappears
sounds like the filament of the picture tube is losing voltage. normally this would be caused by a bad/broken/cracked solder connection. If this is the problem, it may not be too dificult to fix if you have the soldering skills and know what to look for.
Dec 15, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV40XBR800
YOU MAY HAVE A BAD IC 2504 OR M BOARD EST $250.00-450.00
Sep 05, 2008 | Sony FD Trinitron WEGA KV-27FV310 27" TV
SONY WEGA KV-32XL90E
Hallo, IC MCZ3001D is damage. Cost 30 Euro. Greatings from Germany
Jan 04, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My Sony TV KV32s45 32" Shows no picture but has sound. After a few houres of unpuging the TV the screen is good but then the picture gose up and all i see i a black screen but the sound is good. THE stanby...
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
Intermittent video or snow
Resolder points A, B, C, D in tuner PCB, check cold solder on tuner shield 2-106-349-21
Nov 23, 2007 | Sony KV-32S45 32" TV
No power Up , No Sound , No picture
Requires careful, meticulous soldering of horiz drive circuit +
rebuild power supply.....requires four parts......Horiz out xistor,
two converter xistors and one resistor....would you like part list?
Nov 22, 2007 | Sony KV-32S45 32" TV
Sony KV32s45 sudden failure
heard a pop sound -- then the set went dead -- no lights, no nothing, and then there was a slight electrical burn smell coming from the back of the set :(
It's an old 32" set
Nov 19, 2007 | Sony KV-32S45 32" TV
Picture Flashes off and on
probably the tv has a loose solder in the board. this is normal especially when tv is aging. most of the components inside are emitting heat resulting to loose the solder. try to inspect and resolder if possible. but if you dont have the proper tools and equipment and you're not inclined with this kind of job, better bring it to a qualified tv technician. good luck!
Jan 31, 2007 | Sony KV-32S45 32" TV
Sony KV-32S40 32" TV problem
intermittent problems can usuall be liked to bad solder connections. And sony typically has some that will develop after a few years in the power supply. so check for bad sodler connections throught the main board & give a close look to the power supply & check you work after to make sure you have no shorted pins. good luck.
Dec 27, 2006 | Sony KV-32S40 32" TV
Sony tv picture keeps flashing
You likely have bad solder connections around the tuner area. This model has a history of problems in that area or the tuner itself.
Aug 29, 2006 | Sony KV-32S35 32" TV
Sony KV-32S45 32" TV Logo
209 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
