Question about SanDisk Sansa Connect MP3 Player
My sansa wont be read by the computer
My 4 gig sansa connect wont be read by the computer I have tried the recover tool Ican't sync it with media player 11 it wont be found! I can't get it to be found as new hardware the computer just makes 3 beeps when i plug it in and does nothing more also not showing in my computer.
  • 3 more comments
  • Anonymous Dec 26, 2008
    I'm still trying to understand their instructions, so you're way ahead of me.
  • Anonymous Jan 28, 2009
    i have a same problem my computer dosnt read sansa 4 gb clib
  • Anonymous Feb 11, 2009
    i have the same problem too but i dont have the disk im just trying to find out how it can be read
  • jfrizzo2 Apr 02, 2009
    my daudgter left it behind when she moved out so i would like to use it, but the is no software on my computer, how do i get it?
    where do get the software for my sansa connect, i have no disc
  • 758 Answers
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerre
Posted on Jan 26, 2009
Wont connect
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 26, 2008 | SanDisk Sansa Clip MP3 Player
I loaded my music but it skips (cuts in/out) as does FM radio.
Make sure the songs are in the correct format - WMA or Mp3.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
-Tha Mp3 Doctor
Dec 15, 2008 | SanDisk Sansa Clip MP3 Player
Windows Media player will not "Connect a Device"
Make sure the hold/lock is not engaged.
Try a different USB port.
If that fails:
-Tha Mp3 Doctor
Aug 23, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip 2 gig wont turn on
Try resetting it while disconnected. If it still will not keep charge, you will most likely have to replace this player.
Before you do, however, here are the other soft fixes that you can try:
-Tha Mp3 Doctor
Jul 02, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip bad tracks
-Tha Mp3 Doctor
Jun 29, 2008 | SanDisk Sansa Clip MP3 Player
Trying to recover my sansa 4gb
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Apr 12, 2008 | SanDisk Sansa e260 MP3 Player
Help
or
-Tha Mp3 Doctor
Jan 04, 2008 | SanDisk Sansa e260 MP3 Player
Wont turn on
Probably needs replacing, but you can try these common software fixes
-Tha Mp3 Doctor
Jun 05, 2007 | SanDisk Sansa e250 MP3 Player
(2 Problems)Will not connect to PC / Video and audio not in sync
Download latest Quicktime
-Tha Mp3 Doctor
Mar 19, 2007 | SanDisk Sansa e250 MP3 Player
Only reads intialising
-Tha Mp3 Doctor
Jan 27, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa Connect  MP3 Player Logo
237 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
