Question about Lexmark X4270 All-In-One InkJet Printer
I have a Dell XPS420 & I have a Lexmark4200 it is an all in one
Fax , copier & scanner is there anyway to make them compatible ?
I have a 4200 lexmark. I can't scan
Posted on Feb 18, 2009
  • 741 Answers
The key will be the drivers. If you have an install disk for the fax, copier, scanner and it loads without problem then it should work.
Posted on Dec 26, 2008
What can I do .....I am not receiving confirmation pages after I fax.
Anonymous,
Click the link below to download the online manual for the printer. The manual provides information on faxing as well as other helpful topics that you may need to resolve issues.
Dell 2155cn Printer Manual
http://dell.to/1PrwXMm
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 07, 2016 | Dell 2155CN Color Laser Fax, Copier,...
Dell 1135n not compatible catridge
If you look at the face of the cartridges and cound the pin connections you will see that they are different.
Nov 27, 2013 | Dell 1135N - Multifunction Printer...
I have a dell mfp 3115cn copier, fax, scanner. Th...
the fault is a mark on the glass over which the paper passes when being copied. it is the rectangular glass that is probably only 1cm wide but the full A4 length across the screen. Clean the mark off this thoroughly and voila, fixed.
Bristolprinters Ltd - with compliments!
May 21, 2010 | Office Equipment & Supplies
My dell xps 420 will not power on. power light
Hi
If your system's power light blinks amber, it means the computer is receiving electrical power, but an internal power problem might exist.
Do the following to tackle this issue:
  • If applicable, make sure that the voltage selection switch which is at the rear of your system matches AC power in your area.
  • Ensure that the power cable is securely connected to system board.
Here are links with pictures to assist you in opening the system and reconnecting the internal cables.
Please follow safety instructions before you perform these tasks. Here is a link, which gives you complete safety instruction.
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1372453
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1372490
Next is to see the system board design. Here is the link.
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/parts.htm#wp1402834
and if you wish to research a bit more here is the link,
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/trouble.htm#wp1076480
http://support.dell.com/support/edocs/systems/xps420/en/OM/HTML/trouble.htm#wp1097292
Here you will find complete manuals for further research
If this does not resolve the issue, then the motherboard or processor is faulty and you need to get it replaced, so if your system is within warranty why pay extra, get it replaced from Dell. Else contact a local tech and he'll help you out.
Please rate as per the assistance level. Thanks :)
May 21, 2010 | Dell XPS 420 PC Desktop
My Dell A810 won't scan. Prints ok, copies ok but won't scan. Have Vista home Premium and a new Dell Inspiron. have uninstalled and reinstalled the printer twice but still won't scan.
Can't remember, but I believe you should have a fault programme which can access to run a self check?
All in one means able to send a "Fax".
If I'm right you have two settings for faxing, either entering doc in to tray or placing on scanner to be copied then faxed.
If so and you are able to fax to anoth er fax number see if you can send fax via your scanner. I'm am trying to find out if your scanner then starts up, strode lights up and copies, least you know important bits are working.
If it does light up, chances are present prog is not vista compat. Go to www.hp.com enter your printer details search it will come up with latest updates and full progs, look for the vista prog. Good Luck.
Nov 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Using the scanner and fax on the Dell A940 printer
You can download the user manual from
support.dell.com/support/edocs/systems/a940/a940en1.pdf
Have fun!
Please make sure to rate this solution. Thanks.
Jul 16, 2009 | Dell A940 All-In-One InkJet Printer
My lexmark X7500 scanner wont communicate with my dell inspiron
it can be the problem of sccanner cable to scanner card.try to change it.it is only fault more.
Jan 24, 2009 | Office Equipment & Supplies
Dell AIO 924 Printer/Scanner Wont work with Vista
try to download the compatible driver for Vista!!
using the page of ur product starting with dell.com
Dec 12, 2008 | Dell 924 All-in-One InkJet Printer
Dell AIO 962 Photo printer
hmmm..interesting..sometimes, in the translation from one fax machine to another, the grey scale densities don't match up. So, your printer almost certainly has a higher resolution than a standard fax machine. Only way to do this is to test and attempt to balance it from one machine to another. Maybe you'll get lucky, and they will be compatible.
got backup?
Feb 18, 2008 | Dell 962 Photo All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
48 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
