Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Lamp Indicator is Orange
Lamp indicator came on, meaning the lamp is reaching end of life. I replaced the lamp with a new one but the indicator still shows orange color. How do I reset the indicator?
  • bigbrutus Dec 23, 2007
    lamp indicater is still showing orange when lamp has been replaced
  • riotact03 Feb 28, 2008
    I can get to the hours usage on the service menu, but then what? I can't scroll up or down to where it lists LAMP1, LAMP 2, LAMP 3, so on and so forth. If I hit enter the display screen completely disappears.
Press 'Enter' on the TV then press 'Mute' on the remote while holding 'Enter' down. A menu will pop up on the screen, allowing you to reset the light. It's also worth noting that you can get to the service menu by pressing 'Menu' on the remote and TV at the same time. There is an option for checking the number of hours on the lamp.
Posted on Aug 25, 2007
Tvtek - you are wrong! The instructions above work perfectly - with the standard remote. NO SERVICE REMOTE IS NEEDED!
Thanks to everyone, I just replaced my lamp and reset the clock.
Posted on Nov 11, 2007
The lamp indicator is 'off' now, thanks.
Posted on Oct 07, 2007
2cheap2pay is right. But should be noted you will need to hold down the buttons for +/- 5 seconds to get the menu's to pop up.
Posted on Aug 30, 2007
    President:
  • 1,284 Answers
The lamp reset can only be done with a LG/Zenith service remote control. Contact LG/Zenith or just leave it as because there is no affect leaving it like it is just annoying.
Posted on Apr 20, 2007
Seeems to be dirt some where on inside tried to cleans inside and out still there
Posted on Dec 23, 2007
I just did the reset using the regular remote and it worked great! Thanks!
Posted on Dec 19, 2007
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
I replaced a lamp on a Zenith Projection LCD TV model # D52wlcd. The new bulb is working fine. However, the end of bulb life indicator light ( orange ) would not go off. Any advise on how to reset the...
Resetting the lamp time
After pressing the "?" key on the remote control in Stand-By mode, press the "9876"
and press the "OK" button.
And then three LED in the front is stop after flashing for a moment.* Lamp Life Time Confirmation
1. Method1 : Enter ADJ mode with using the remote control. You can be confirmed
because " Lamp Life Time XX hr" is appeared.
2. Method2 : With using the remote control offered to consumer if you press the
menu button continuously, OSD menus will disappear then press the "9876" and
press the "OK" button to enter ADJ mode you can see "Lamp Life Time XX hr"
Oct 13, 2010 | Televison & Video
Indicator showing LAMP. Does this indicate the lamp needs replacing?
Yes. The lamp is timed and the replacement indicator signals when the lamp is near end of life. If the lamp fails catastrophically it makes a mess... best to replace before that happens.
Jan 03, 2010 | Dell 3400MP Multimedia Projector
Reseting the end of lamp life indicator
Hold down mute button on remote and enter on TV
at the same time for a few seconds, you should get
a screen promt asking if you want to reset the timer
for the lamp.
Mar 31, 2009 | Zenith E44W46LCD 44" Rear Projection...
Rear Projection TV shuts down after a few minutes.
My science teacher had the same problem.
After, he replaced the lamp it stoped over heating.
witch is most likelywhy the tv is over heating
Jan 21, 2009 | Zenith D52WLCD 52" Rear Projection...
Thanks
No one here knows where it is. However I found that if the lamp indicator is orange or blinking orange that means the life expectancy is nearing the end of its life cycle and you will get intermittant starts.
Mar 13, 2008 | Televison & Video
Lamp indicator blinks red
There is a problem with the lamp or around it? When it turns Orange, the lamp is at or near the end of it's life & needs replacing. What does the temperature indicator show? Orange, Red or Red Flashing? If not, then there is probably accumulated dust around lamp area
Dec 24, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
754 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
