Question about Sony MHC-EC68Pi Shelf System
Music wont play from my iPod when I connect to my MHC-EC68Pi
I bought an MHC-EC68Pi Stereo. I hooked up the speakers as instructed as well as the antenna for the FM Tuner. Now it also comes with an Ipod dock from Sony all included in the box. Its the TDM-iP10 dock. I connected my Ipod to it, and connected it to the DMSPORT on the front, and it wont play music. So I:
~Made sure the Ipod was playing music: Check
~Made sure the Ipod volume was high: Check
~Made sure the stereo was set to DMSPORT mode: Check
~Made sure the volume on the stereo speakers were up: Check
Nothing worked. I Shut off the stereo, unplugged the dock, unplugged the ipod. Than...turned the stereo back on, plugged the ipod into the dock, and the dock into the DMSPORT. Nothing. Help me asap!
  • azmf1 Dec 26, 2008
    I forgot to add that I have a 1st generation Ipod nano, when it first came out, the small one.
  • Anonymous Jan 22, 2009
    exactly similar problem.
3 Suggested Answers
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
SOURCE: Sparse radio reception with Sony MHC-GX250
a am loop antenna should work.
Posted on Aug 06, 2009
SOURCE: My Sony TDM-iP10 ipod port wont charge my ipod
The media adaptor is not fully compatible with the latest ipod. If you add a Scorsche adaptor to the set up, it will facilitate the charging.
Posted on Jan 17, 2010
How do I play iPhone on Memorex m1111
I plug my iPhone into the Memorex Stereo (which has an iPod ...
discussions.apple.com > Support > Apple Support Communities
AppleJun 2, 2012 - I plug my iPhone into the Memorex Stereo (which has an iPod function) and the music is not playing on the speakers. My son's iPod does work ... Memorex recorder-burned DVD's won't play on iMac
Sep 21, 2013
ipod touch will not play through dock speakers
Aug 16, 2010
More results from discussions.apple.com
Amazon.com : Memorex Home Audio System with iPod ...
www.amazon.com/Memorex...Player.../B0017Q6HB...
Amazon.com, Inc.Amazon.com : Memorex Home Audio System with iPod Dock and CD Player ... Sony ZSS3IPN Lightning iPhone/iPod Portable CD Radio Boombox Speaker Dock .... but there is a cord for FM radio reception and I'm sure if I play with it, I can get ...
Amazon.com : Memorex MI3602P PurePlay Portable ...
www.amazon.com/Memorex...PurePlay.../B0040YGJ...
Amazon.com, Inc.
Jan 10, 2016 | Cell Phones
Play Ipod thru JVC CD car stereo using RCA cable?
JVC KD-S731R does not have the option of connecting an ipod. The RCA ports on the rear of the unit are a Line-Out. These RCA's only OUTPUT sound. Not an INPUT RCA that you require. The only other method of using an ipod with this stereo is to purchase an FM-Modulator to connect the ipod. Once purchased, you must connect the antenna wire coming from the vehicle to the module, then you must connect the antenna wire coming from the module to the stereo. The other wire will be connected to either a jack or a ipod specific plug depending on the type of modulator used.
Dec 08, 2009 | JVC Car Audio & Video
For some reason my ipod touch won't play when I plug it into my stereo. It is playing out of the ipod itself. How do I turn this off.
Hello.
This is a very common problem, you may have to get a different jack that works with the headset jack thats on the iPod. iPhones and iPods have a weird style jack on the top that wont allow most headphone or 3.0mm to 3.0mm jacks to go fully inside the jack causing it so there is not connection with the jack itself in the iPod. You can check this by turning the volume up and down using the rocker buttons on the side while you are at the home screen with no music playing and see if it says speaker or headphones when your turn the volume up and down. Speaker means there is no jack connection, headphone means that there should be music playing through the stereo. Thats using the jack.
If your talking about an iHome or other direct plug in stereo specifically for the iPods and iPhones, make sure that the dock is the correct dock for the iPod, and make sure that it is pressed fully down onto the dock. If all that is correct there should be no problem. If the problem still is happening, it may be your stereo. =/ Goodluck! Hope this helps!
Dec 07, 2009 | Apple iPod touch
Is there a way to hook up an ipod to this stereo so it will play the ipod music through the stereo? Can I purchase a docking station that will hook up to this stereo?
Just get an adapter for to connect from the Ipod headphone jack to a standard RCA cable pair. Jack into AUX or whatever available input you have.
Dec 05, 2009 | RCA RS2652 Shelf System
Jul 16, 2009 | Sony MHC-EC68Pi Shelf System
IPod connection
ipod...^.^ you can use a fm transmitter that you can buy from an ipod store, or you can use a audio cable ussually used in audio- video connection to a television set or hdtv sets. if you are trying to use a tape input-output, try it first in some devices. such as an cd player or walkman. if these works in two speakers maybe the plug is not compatible to your ipod. or maybe you bought an mono tape input-output instead or stereo type.
you can see if its an mono or stereo, by looking at the plug if it has two black lines it is an stereo if it's just one, that is mono.
hope I helped you with your problem..
Jul 12, 2008 | JVC RX-554V Receiver
Is there a feature that allows music to play randomly and it wont allow me to hook up my mp3 through usb
Well, the p2 is made to charge and get music put on it when it detects a usbbut ipods can still play music.So no fix just an answer.
May 02, 2008 | Samsung Yepp YP-P2 Digital Media Player
Sony MHC-EC68Pi Shelf System Logo
66 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
