Question about KitchenAid KEHC379JSS Electric Double Oven
Outer Glass Microwave window shattered after baking popcorn
Shortly after making some standard bagged popcorn (using the "Popcorn" feature), the microwave window shattered. This is a new unit; only in place for a week, and this was the first time using the referenced feature. The repair tech comes tomorrow to fix, but I am curious as to what we cause such a problem.
    President:
  • 1,462 Answers
Doubt anything to do with popcorn. glass like that does sometimes shatter probably a stress fracture. quite often happens with oven doors as well
Posted on Apr 19, 2007
The outer glass of my oven door shattered, can I still use it until it is repaired?
Hello- I would be careful using the oven mostly because the inner glass will be VERY hot to the touch, meaning you will get burned if you touch it. If you have children I would refrain from using the oven, too risky. If it is just you, or just adults then you should be ok to use it until you can repair it. Keep in mind that you will probably lose a lot of heat out the door and it make take longer to bake. Again, be wary of the inner door glass if you use the oven. Do a test run with a low heat and see how it performs. Hope this helps, best regards.
Sep 27, 2010 | Whirlpool Ovens
Tbf-610 outer oven door shattered how do i fix it
unless you have a spre from the dealer, then simply measure the fitting dimentions and don forget the thicknes. Then go toyour local glass dealer and ask for same size of glass but make sure its toughened glass and its high temparature tolerant. You can use the same ruber gascket or if not you can buy High temparature silicon silant to fit it back
Aug 06, 2010 | Ovens
Even when we press the popcorn button our popcorn always burns can you tell me what to do abt it.
I am working on a "programmable popcorn button" that a user could set to a time for a box of popcorn bags and reset it when a new bag is purchased in order to pop a bag for a longer period of time, or a shorter period of time.
Sorry noone has thought of this before, but help ism on the way.
Nov 28, 2009 | Ovens
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
TKC 8522/2 top oven outer door shattering
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
Dec 30, 2008 | Tecnik TKC8522 Electric Double Oven
Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Sep 28, 2008 | Ovens
Microwave door shattered
This is not a job you should do. Microwaves are dangerous things and can cause injury. An improperly fitted door will leak. A new door, installed and checked out by a technician is needed here The economics are beyond my area.
Jun 16, 2008 | Ovens
Outer glass plate
glass was not tempered correctly contact the manufacture or possibly industrial glass products in ambridge pa they make them
Dec 14, 2007 | Miele H326-3 B Electric Single Oven
No heat or rotate
did you check the door switches?
Aug 18, 2007 | GE JKP85 Electric Double Oven
KitchenAid KEHC379JSS Electric Double Oven Logo
235 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
