Question about Stoves Newhome ECH600MXa Electric Kitchen Range
Stoves Newhome SI550DOm gas cooker
Can anyone help please,when i turn my oven on full or high,the flame is low to start with then it used to go to a full flame in a couple of minutes,now it,s taking longer and longer to reach full flame,sometime 40 minutes,any ideas please
  • mandy30 Dec 26, 2008
    hi,tried that but the flame is covering the wire,thankyou for trying
  • 1,036 Answers
This is a common safety feature, and is based upon the main gas valve inside the appliance. It regulates only a tiny ammount of gas through when closed - enough to light a pilot. This should then heat a component high enough to trigger the main gas valve and light the main burner.
With the door fully open. Turn on the oven and watch the pilot ignite FROM THE OUTSIDE. Look to see that it is heating what looks like a small wire in the flame. If it is not. Turn it off and let it cool.
You need to adjust this into the path of the flame just by bending it a little. Then try again.
If you cannot, or adjustment doesn't work,then you really need a replacement main gas valve - which is a registered appliance specialist job I'm afraid. Don't take chances with gas appliances.
Thank you for using Fixya.
Posted on Dec 26, 2008
H I have a stoves newhome 600si the rings,lite but when the grill or oven is on the flames nearly go out as if its lost full pressurean ideas please
I would have your regulator checked going to your stove to make sure you have enough flow rate or a obstruction
Jan 04, 2015 | Stoves Ovens
Stoves newhome gg700 grill flame goes out if lid is closed
I had a stove in my camper that did this. The answer was to let the flame burn for a few minutes BEFORE closing the door. I think the original problem is that there is too much gas flowing to the burner and it literally blows itself out, until you get everything heated up and working. The question, I think, is there a way to turn down the gas pressure??
Nov 19, 2013 | Stoves Newhome ECH600MXa Electric Kitchen...
I have a stoves newhome GL616 cooker that just
Hi I have a gl616 cooker when turned on and flame on gas mark 9 the flame dies down then it turns off, any reason why this happens have replaced the fan,problem still occurs.
Jul 06, 2011 | Stoves Newhome ECH600MXa Electric Kitchen...
I need a user manual for my Stoves Newhome GG600 Gas cooker
I have a newhome GG600 oven, burner will not open up to full capacity, staying on low flame. It does not get hot enough to do any cooking, please advice many thanks.
Jul 11, 2010 | Ovens
I have newhome es 550 cooker and the light inside the oven is not working.Can i get a replacement, if so can you tell me what i need and how do i go about changing the bulb.
Go to a Home Depot, or Lowe's and get a high temp bulb. Remove the screws that hold the cover on, and change the bulb like any other bulb
Mar 31, 2010 | Stoves Newhome ECH600MXa Electric Kitchen...
Low flame and not heating oven
we had the same problem on our 10 yr old creda. gas man said new ffd required (flame failure device). he reckoned on around 80 pounds sterling for new part,even if it was still available, plus maybe 2 hours labour. we bought a new cooker!
Nov 24, 2008 | Stoves 1000DFDLm Gas Kitchen Range
Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Oct 28, 2007 | Ovens
Newhome electric cooker = problems with oven
problem is 99% sure is the cvircular element round the fan. easy to replace
Jan 07, 2007 | Stoves Newhome ECH600MXa Electric Kitchen...
Stoves Newhome ECH600MXa Electric Kitchen Range Logo
613 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
