Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Picture adjustment I own a panasonic projection tv and there is not more brightness. When i try to adjust the image on more brightness, when in the picture is too much white then the image enlarge on verticaly and the space between the lines become bigger. I believe there must be a capacitor which is playing with me but I dont know which one. Can you help me?
  • 375 Answers
SOURCE: convergence
covergence amp ic"S need to be replaced.
Posted on Aug 18, 2007
SOURCE: dark picture
@ 6 years old I'd be willing to bet that it's time to replace the lamp. They lose brightness over time so that could be what the problem is.
Posted on Jan 02, 2008
experttv
  • 203 Answers
SOURCE: Convergence On Panasonic PT-47WX54j
You dont need codes for the service menu you need to repair the convergence circuit. If the lines wont line up in the customer menu they wont line up in the service menu either. Do you know how to solder? If so we can fix this yourself with a little instruction. Otherwise you will need to call a repairman. A good repairman will run you $300-$500 depending on your area. Let me know what you want to do.
Tim Nolan
Posted on Sep 25, 2008
SD Tech
  • 14553 Answers
SOURCE: Blue line Ghost Image on Panasonic Projection TV
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This set uses two Stk-392-110 convergence IC chips; both need to be replaced along with any of the 2.2. ohm light blue resistors around them; a bad resistor will be white in the middle; You can buy both for less than 13 dollars plus shipping on Ebay.
The chips are located on metal heat sinks with fins and are side by side. They are black(about 2 inches wide by 1 1/2 tall) and should have the STK-392-110 number printed on them in white.
Depending on your level of skill at this kind of work you may be able to do it yourself---if you need step by step instructions contact me---I have them in Microsoft word---start to finish repair including what you will need to do it.
If you are not able to do the repair yourself now is the slow time of year for TV repair shops----It should be fixable right in your home and the repair takes about an hour--I have done hundreds of these sets--some shops charge 300-400 but I do lots of them for 200-250 total cost. Make sure whoever you get changes BOTH of the chips!
Shop around and if they say "needs to go to shop" keep looking; any good tech can do this right in your home.
I do this here for free so if this helps you give me a vote here. If you need direct help contact me.
etower.766@netzero.net
Posted on Aug 27, 2009
asnowman
  • 788 Answers
SOURCE: Panasonic PT56HX41PF projection TV. Image blurred
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. What you might be experiencing based on this symptom sounds like a convergence IC problem. But if the set fixes itself you will need to have it repaired as soon as possible if you wait too long there are several components that will fail in due time. If you want to repair it yourself or know someone that can solder components on the circuit board, you will need to re-solder the convergence IC’s. All you will need is some solder wick, a good 45W soldering iron, Acid free solder and some solder wick (this is for the clean-up of solder joints and cleaning up solder bridges.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With any Projection Television that has a damaged or interment convergence problem, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky
How do I tell if the IC’s are damaged?
When looking at the area around the convergence IC’s you see some resistors that have changed colors, or you test a resistor and it no longer reads the marked value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
Posted on Nov 30, 2009
Adjust brightness on panasonic th-50px60
The TV's Brightness setting only affects the intensity of the color white. The easiest way to see changes is to pause a movie or TV show that has clouds in the image. Then change your Brightness setting to your preferred video.
Mar 18, 2014 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panasonic hdtv 1080i picture bright
It could be your main board going bad.
Jun 01, 2013 | Televison & Video
Where is manual control panel for brightness and color on tv
I have attached a image where the buttons are located.
You can adjust the brightness by Pressing MENU button---> Picture---> brightness.
Thanx
Jul 31, 2010 | Hitachi 42V710 42" Rear Projection HDTV
We adjusted the brightness and the picture went
possibly the light bulb inside the TV is dead. Complicated fix, try to call a technician
Oct 21, 2009 | RCA D52W23 52" HDTV CRT TV
Vs 4561 weak picture
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Good Luck, big IRISH.
Apr 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Televison & Video
Dark picture
do you get all three colors? red, blue and green?
Dec 16, 2007 | Panasonic PT-51G44 51" Rear Projection...
How to adjust picture on projection tv
i have a 52" rca projection , and the screen looks like this ") (" on the sides can i do something to straiten it back out?
Aug 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
