Question about Samsung UpStage SPH-m620 Cellular Phone
Power on.....power off
My phone recently started acting funny. It will not turn on unless it is on the charger, and when i put it on the charger it begins to charge and then it turns off and the "samsung" comes up and begins charging again! The process keeps repeating. So when i power it on when i put it on the charger it loads up fine. If i let the phone sit without pressing any buttons for more than 30 seconds it turns itself off and starts repeating the charging for about 1 minute, then turns off and starts charging again. i havent dropped or smashed it or got it wet or anything!
Please help!!
  • 3 more comments
  • jai_baby4eve Jan 28, 2009
    Same Happened to mines someone please please please :[ help me i need it soooooooo BAD! i hate this phone
  • Anonymous Feb 01, 2009
    phone repeadily shuts on and off. in approx 30 second intervals. has been doing so for past 2 days. does anyone know how to fix it
  • Anonymous Feb 05, 2009
    This is the second time this happened to me.
  • Anonymous Feb 07, 2009
    Same problem, this is the worst phone! touch pad sucks... just bought a new one.. wont deal with this stupid problem
  • Anonymous Feb 27, 2009
    same thing happened to me today for the second time. i sent it before to get fixed but the is horrible.
  • 127 Answers
Go to Service center
Posted on Dec 27, 2008
I put my U5i to charge and when I woke up in the morning it was shut down and I can't turn it on...In two words the phone died.
Did you drop the phone in water recently? Did you get it wet in the rain? Apart from the likely possibility that the phone is actually damaged/battery damaged, this happens if the power button gets damaged. When you put the phone to charge, in the middle of the night the power button "acted" as if it was pressed and held and the phone turned off. Now when you press the power button, nothing happens because the power button is damaged.
Take it to a repair shop and check the power button for damage. It is replaceable and should not cost a lot.
Does your phone have a removable battery? If yes then you might be in luck. If not, then just take the phone to repair shop and get the power button checked and repaired.
If battery is removable I know that it is possible to turn on the phone this way:
1) Plug in the charger to the phone
2) Remove the battery and insert it immediately. Do this multiple times and the phone should turn on without having to press the power button.
Hope that works.
Sep 27, 2013 | Sony Ericsson Vivaz U5i ruby Red Unlocked,...
Screen turns blue when booting
cuz it got wet!!! take out battery and use hair dryer?
Aug 12, 2012 | Samsung Solstice SGHa887
Electrical issues, battery not charging and loss of power
You could start by checking the alternator and voltage regulator. Things will "act funny" if the system voltage is low.
Mar 20, 2010 | 1981 Yamaha XS 400 Special
Samsung SCH-U340 blue cell phone acts like it has no power
I have the exact same problem. Has it been in contact with water recently? It may be corroded. Check your charger slot for corrosion. That may be the problem. If you see signs of corrosion, your phone is shot. If you don't, take it in to your service provider to have it checked. hope this helps :)
Jan 08, 2010 | Samsung SCH-u340 Cellular Phone
My car won't start. It's cold. Battery acting funny. But, jump start failed to get it going. What do I need to start it again?
if you can't jump start it in the cold bring battery into warm place and put it on a charger.the cold is an enemy of batteries. but this might happen again battery sounds like its weak, unless car has been sitting in cold for long time.you can get a new battery for about 60 dollars have all your problems solved.
Jan 07, 2010 | 2002 Saturn Sl
Starter has no power in start 95 Lumina would not start after shutting off. All accessories work. I also jumped the solenoid and it turns but the starter doesnt.
You are reading this wrong...solenoids don't turn. They activate the starter...that turns. Check your battery connections and battery/charging system. The starter requires far more power than anything else in the car, so those items working won't tell you much.
May 27, 2009 | 1995 Chevrolet Lumina
NOKIA 5310 can't turn on
Did you replace battery recently? Sounds like it has bad or wrong battery. If not, it is just dead.
To fix:
Power up phone on charger
While it is ON, pull the battery
Leave out for 1/2 to 3hr - phone still plugged in
Replace Battery, phone will power cycle and start charging
Leave plugged into charger 10-14hrs
Should be good now
Mar 26, 2009 | Nokia 6500 Slide Cellular Phone
Blue On G1
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
Mar 05, 2009 | HTC G1
Samsung UpStage SPH-m620 Cellular Phone Logo
310 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
