Question about HP Pavilion a305w (DM181AR) PC Desktop
Nothing put a beeping when power is turned on
When you turn the tower on it just beeps, a constant beep,beep beep! thanks very much
  • Brian Ebeling May 11, 2010
    turn it of and unplug the keyboard and then turn it on without the keyboard in. wondering if it's a stuck key.
    if it still beeps let me know
  • 35 Answers
When a beep sound occurs, it means that there is always something.
Go to this website and find out what your beep means.
http://www.computerhope.com/beep.htm
You will have to find out what manufacture your motherboard is from, and from there, you can see the list of errors from the beep sound that your computer is sending out.
Posted on Dec 29, 2008
  • 741 Answers
Sounds like bad RAM memory. That is normally the beeps you get when a memory stick has gone bad.
Posted on Dec 26, 2008
I have a Antec performance all tower that use too beep when turned on now its just a solid orange light and does nothing
All PC's beep when turned on, it is a sign that the system has passed power up test. If it is not beeping then the system is faulty. It could be a power supply failure or something else.
May 27, 2016 | Computers & Internet
The tower turns on but does not boot the monitor
There could be a problem with the connection to your monitor.
Dec 21, 2013 | Gateway ATXSTF MNT Pro S P4 1500 Tower...
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
I turn computer on blue light on computer tower comes on monitor power **** turns blue and the on screen message going into power save mode and then nothing change motherboard battery and took out graphic...
Short of it being something simple like your monitor cable is unplugged, the more likely problem is that there's a fault on your motherboard or graphics card.
You should have an internal speaker connected to your motherboard, it should be giving beeps depending on what the problem is. If everything is ok then there should be a single beep.
If you are not hearing anything try removing your RAM and boot up, you should get lots of loud beeps, if you hear nothing then it's likely your motherboard is faulty.
Apr 05, 2010 | Dell Computers & Internet
When turned-on. tower will not boot and only beeps
If you recently added new hardware, remove it. Also unplug any USB devices. If that doesn't get you past the BIOS screen, then you need to take your PC to a shop, it sounds like a bad motherboard.
Nov 01, 2009 | Computers & Internet
Computer tower started beeping
If you added more memory this may make your tower beep.
If so I WOULD REMOVE THE ADDED MEMORY AND THEN RESTART
Jan 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Aug 27, 2008 | HP Compaq dc5100 PC Desktop
Beeping Upon Bootup
dependent on how many beeps you hear is dependent on what might be the problem. A fuller explanation from pushing the power button to nothing happening would be more than helpful. Beeps in a Poweredge can mean motherboard, memory or as you said power supply problems.
May 06, 2008 | Dell POWEREDGE 2400 Server
Constant beeping and will not re-boot
Question- the beeping, is it short (1 second beeps) or long (2 or more seconds) and how many before it stops? or doesn't it? does it have any rhythm? The beeps correlate to some hardware problem, if you want to check the beeps yourself, just google "Bios beeps" and it will bring up a table of what the beeps mean.
J
Jan 07, 2008 | Computers & Internet
Constant beeping,won't turn on
What is the beep pattern? beeeeeeeep, beep,beep beeeeeep etc. also what BIOS do you have?
Aug 05, 2006 | Gateway EV 700 17" CRT Monitor
HP Pavilion a305w (DM181AR) PC Desktop Logo
1,614 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
