Question about Sanyo HT27546 TV
Sanyo model HT27547 installed to Dishnetwork satellite.
Currently use rabbit ears to receive one local channel. What type of antenna/rabbit ears do I need to receive the new digital signal when the local channel goes digital?
  • juan200561 Feb 21, 2009
    I need a shematic diagram for a SANYO T.V model# HT27546, chassis # 27546, manufactured in 2006. I have this tv and I am trying to fix it, it has some burn parts.
  • 360 Answers
The model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
Posted on Jan 29, 2009
How can I get my channels set up
On what make and model TV using what system or service
Feb 02, 2018 | Televison & Video
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
Jul 24, 2015 | Winegard RV-5095 Sensar II RV TV Antenna...
When I hook up my sanyo model#clt1554 to my hdtv rabbit ears it does't work why?
Rabbit ears are a poor man's antenna. Maybe you have no analog stations in your area. If you do, then the signal is likely very poor.
Sep 30, 2014 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
2 tv's. recently had uverse removed. neighbor has rabbit ears-gets local channels. I get nothing. Does something with uverse change my tv's?
Your tv my have a setting for type of input. Cable of Air channels. You would need to switch that to AIr. Also, the air channels have gone to a digital signal and I believe they take "digital rabbit ears" I think the old style may not pull in the digital signal, but I'm not entirely certain about that one. Something like this http://www.amazon.com/AmazonBasics-Ultra-Thin-Performance-Indoor-Antenna/dp/B00DIFIO8E/ref=sr_1_1?ie=UTF8&qid=1409885138&sr=8-1&keywords=digital+antenna+for+hdtv+indoor
Sep 05, 2014 | Televison & Video
I live in Victoria Tx. I can not afford cable or dish. I am able to recieve all 4 of the the number 25 channels. Why am I not able to recieve any of the three number 19 channes. All 19 and 25...
Channel 19 actually broadcasts on VHF channel 11 (approximately 201MHZ) and channel 25 actually broadcasts on UHF channel 15 (approximately 479MHZ). I know that sounds a bit weird but it has been done so that stations don't have to change there "call" channel number when we switched to Digital TV. Your digital converter box keeps track of this. This is important to understand because you need and antenna that is good at picking up both UHF and VHF signals. If you're not getting channel 19 it may be due to a poor VHF portion of your antenna. If your using a basic old set of rabbit ears for your antenna that has a loop in the middle then I might have a trick for you. Most rabbit ears have 2 telescopic antenna elements. Extend or collapse until each length is 14.7 inches long. (Which is a quarter wavelength at 201MHZ). You are effectively tuning (Optimizing) your antenna specifically for that channel 19. You may need to rotate your antenna a bit to find the best signal.
There are other factors which can hinder you receiving channel 19 but this is a good starting point. Let me know what type of antenna you have. Hope this helps.
Dec 03, 2010 | Insignia Digital-to-Analog Converter for...
I can't get FOX on my converter box--what is the channel # for FOX?
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Apr 07, 2010 | Televison & Video
TV freezes up when turned to channel 33-1
I had the same problem. I also use rabbit ear antenna , no cable or satellite. I was watching ch. 33.1 and the tv turned off by itself. The remote wouldn't work. The power on/off buttons on the side of the tv wouldn't work. I had to un-plug the power cord to turn the tv off. The tv forze on ch. 33.1 when I turned it back on.
I called Vizio, they told me they received hundreds of complaints from people in Texas complain g about these problems.
I was told to un-plug the antenna cable and re-plug it. I did this plus I re-scanned all channels. The problem has been solved, the channel (33.1) no longer freezes and the tv doesn't turn off by itself.
Hope this helps.
Aug 22, 2009 | Vizio VW32L 32 in. LCD HDTV
Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
May 27, 2009 | Philips Televison & Video
DTV Converter Box
If there is no digital tuner built into the tv or unless you subscribe to Cable TV or Satellite service you will still need a converter to view tv with rabbit ears (air broadcast).
I Can Fix It
Sep 22, 2008 | Protron PLTV-32 Television
Re: Sanyo TV Model #: HT27547 Will I have to get a converter box to watch tv stations?? In a few days I will disconnect my satellite service. Thank you!
This link will verify that yours is digital ready.
If not click able go here.
http://reviews.walmart.com/1336/5652233/reviews.htm
to see reviews for your Sanyo flat screen model ht27547
You may have to purchase a new antenna to do that search for one that is specifically for digital reception and good for the distance from station to home. (Range rating)
Apr 25, 2008 | Televison & Video
Sanyo HT27546 TV Logo
414 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
