Mama, cleaning the filter on this is pretty easy. If you look at the lower spray arm, I believe that it just snaps on. Should be some clips on the lower part holding it on. Remove the spray arm and grab the filter trap handle. Turn it to the right or left 45 degrees and it will lift out. It's keyed to lock on and off. Now you can remove the filter and look right down into the sump. Just take your time and remember the position order so you can reverse it when putting it back together..This is for the model posted...Catriver..post back.
Hi
OE in your dishwasher is a
drain error and dishwasher not draining issue usually occurs due to kinked
drain pipe, clogged drain filter or drain pump. First make sure that the drain
is not clogged and remove clogs if present. If no visible lint is present then
remove the lower front access panel to check the drain filter and drain pump
for any clogs, you'll need to clean the drain filter and drain pump completely.
Also, check for any food pieces stuck near the pump impeller & clean the
chopper assembly. If the issue
returns after cleaning then the drain pump assembly should be replaced. Hope
this helps...please post back for further assistance.
Daniel
I had been pulling on the wrong part of 'the part' LOL. Glad hubby finally looked at it, but now I feel really dumb. I was just afraid I'd breakit or something. thanks for the help. tc
