Question about Sony Walkman Bean NW-E307 MP3 Player
Bigger problem My situtation is a little more complicated: When I plug the usb it gets a drive letter so, as I cannt erase information from the usb (it appears "it is not allowed because the drive is write protected"), I noticed the drive has many information which wasn't music, so I assumed it was a virus, the computers where usb is connected were protected with norton and avira and no one found nothing, so I used the autorun virusn remover which found somehintg and it appears it was cleaned. Although I couldn't erase information, and when I tried format a similar adviced related to write protected status appears). I tried to chenge privileges for access but they were blocked, I tried to access by the hard disks manager of windows and the only thing a could do was delete the drive letter, it wasnt possible to format. At the end I use ubuntu to access and although I finally erase all the information, when I connected it to windows all the files were there again, so I am writting here, I also tried to upgrade the firmware but it isnt detected by the sw. Also I tried with Paragon partition manager, in windows safe mode, but all it says is it is not possible.
  • roager_mx Jan 04, 2009
    The solution: I connectted the USB in a Linux system and format the device
  • 3 Answers
Your OS(XP) is infected with virus.
Reinstall your os first and format ur pendrive in ubuntu before using it in windows.
Posted on Jan 21, 2009
Erase, re-format
Plug external drive into the USB port of the computer/laptop.
It will show as an additional drive for ex letter : E:/ or F:/
Right click on the drive letter and select format
Mar 17, 2015 | Toshiba 1TB USB 3.0 External Desktop Hard...
I just got a new laptop and I no longer have my softward installation disk for my simpletech 320GB external hard drive. I've gone onto simpletech.com and am having trouble finding the software program. ...
If you have a new laptop, you should not need the install disk to see the drive as the drive is USB 2.0 compliant.
And no, nothing will get erased unless you erase it on purpose.
Plug the drive into you laptop (USB cable).
Plug power into to the external drive.
Turn the drive on.
It may take a minute or so but your laptop should recognize the drive. It will get assigned a drive letter (assuming you are using Windows).
Apr 19, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
How do I reformat it?
To format a USB Flash Drive, follow the steps below for your OS:
A. Windows PC
1. Power on your computer. 2. Insert the USB flash drive. 3. Click on the "Start" menu and click on "My Computer". 4. Right-click the drive letter that corresponds to your USB flash drive. 5. Select "Format" from the context-menu. 6. A new window will open, input the following information in the correct fields:
File System: FAT32 Volume Label: "Give your USB drive a title" (optional)
7. Check the "Quick Format" checkbox. 8. Click "Start" 9. Upon completion, your USB flash drive will be formatted.
B. Mac OS
1. Power on your computer. 2. Insert the USB flash drive. 3. Double-click on your Macintosh HD. 4. Double-click on the "Applications" folder. 5. Double-click on the "Utilities" folder. 6. Double-click on the "Disk Utility" application. 7. The program will open, select your device from the left-hand pane. 8. Click on "Erase" on the main page. 9. Input the following information in the correct fields:
Format: MS-DOS Label: "Give your USB flash drive a title" (optional)
10. Click on the "Erase" button. 11. Upon completion, your USB flash drive will be formatted.
Aug 15, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
I have Windows XP on my computer. What program do I use to erase information on a DVD+RW disk?
While the DVD in the Drive Open the windows Explorer and right click the DVD
Drive Letter and select Erase this DVD,
this Help?.
Jul 23, 2009 | Memorex (32025541) 25 Pack 4x DVD+RW...
Had to erase USB drive Data, now Vmailer wants $40 for synch prog
Hi ,
you can try to get a free synch program for your U3 device , for example : Allway Sync n Go
if you want to delete the information on the device , you can format it as a regular Hard Disk (my computer, right click on the USB drive letter and choose format)
Jan 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Joybee 130 MP3 plaer
Plug your player into your computer via USB. If Windows recognizes it, a new drive should show up under "My Computer". It may be called "Removeable media". It may be some letter like "G" or "H". If you have an SD card bigger than 512 MB, then find the removeable drive that is bigger than 512 MB that shows up when you plug in your MP3 player and that drive is your SD card.
May 02, 2008 | BenQ Joybee 130 MP3 Player
USB 2.0 MObile Disk Drive
Try this:
Unplug the USB drive from the computer.
Double-Click on my computer and it will open a window.
Make note of when drive letters are shown. EX: C: D:
Plug the USB drive back in. Should hear alittle chime.
Whatever letter popped up should be that drive.
Double-click on it to access information.
Hope this helps.
Thanks!
Mar 24, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Insignia mp3
Please provide more information on the error message.
You can use Windows Explorer to transfer files to your insignia sport player. First, in the settings on your player, go to Settings, USB Mode, Connection Type and select File & Folder. Then, plug your player in to your USB cable. Windows XP should automatically find your player and make a new drive letter in Windows Explorer. Simply drag and drop your mp3 files from your c drive to the new drive for your player. You'll notice that when you delete the files on your new drive for your player that it doesnt remove them from your player. You'll need to use your player (settings, system, erase internal) to erase internal (and external), but after that when you add new files, they will be added to the player when it does the profiling after you disconnect the USB cable. Dave@OgleServices.com
Dec 21, 2007 | Insignia IN-MP3256 MP3 Player
Erasing or deleting stored materials
When you plug it in to your USB port, it should be assigned the next available drive letter that is not taken by a physical drive (your primary hard drive or another USB drive). Then you can browse the drive through Windows Explorer.
Sep 10, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sony Walkman Bean NW-E307 MP3 Player Logo
173 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
