Question about Dryers
Dryer Timer not Working
Got a Whirlpool LEN200LWo Elec dryer. Given to me. Excellent condition. Noticed when door opened, dryer did not stop all the time.
Also when shut door would not come on from the "push" button on. For a while could wiggle door, stand on one foot, cross my eyes and then some times it would work. Now, nothing works. Any ideas? Frustrated mom
  • 179 Answers
Check the door switch it could be getting stuck
Posted on Dec 26, 2008
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
Won't stop, have to manually open door
Sounds like a bad timer. Your dryer is a Whirlpool a replacement timer should be easy to locate. If the timer is advancing but the dryer won't stop, the problem could be the control unit. Run another load of clothes and take notice of the timer's position. If it doesn't run out, then it's very likely the timer. The video below shows step by step instructions for replacing the timer unit.
Mar 30, 2012 | Estate TEDS740JQ Electric Dryer
Whirlpool model LER8648LW0 - the dryer will not stop when door is opened and the interior light does not light. I have changed the bulb on the light but it still does not work. I suspect the problems are...
I suspect the problem with your dryer is the door switch as opposed to the timer...its the responsibility of the door switch to stop the dryer when the door is opened as well as turning on the light too when the door is opened.
The part number for the door switch is 3406107 it could be purchased at your local appliance parts store or online at;
This youtube video will show ya how to replace the door switch
Sep 12, 2011 | Whirlpool LER8648L Electric Dryer
My whirlpool elec dryer will not turn on. I tested the door switch which is working properly. we turned the dryer on and it started than stopped and wont turn on again.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
Apr 16, 2011 | Whirlpool Dryers
My whirlpool dryer #LER5636KT0 seems to be working ok with the exception that it won't turn off when the door is opened. I have to turn the timer knob to the off position for it to stop. What would be the...
There is a door switch so that when you open the door the dryer turns off. Be sure to unplug dryer before trying to remove the switch, it needs a new switch put in.
Apr 07, 2011 | Dryers
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
I have a Whirlpool dryer model #LEN200LWO. It takes 3-4 times through the cycle to finally get the clothes dry. I've noticed too that there doesn't seem to be much lint on the screen - which I clean before...
bad airflow definitely bad airflow use real metal vent hose not the coil and plastic or mylar. make sure the vent at the outside wall is not stopped up somewhere there is a blockage
May 07, 2008 | Dryers
Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Jan 24, 2008 | Whirlpool LER3624JQ Electric Dryer
Dryers Logo
138 people viewed this question
Top Dryers Experts
