Question about Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
I paired the Motorola H700 with my Blackberry Pearl 8100, but the headset still doesn't work. I selected the H700 device on my phone and hit connect, but I get the following message: "Handsfree connection to Motorola H700 failed." What am I doing wrong?
  • 10 more comments
  • paolondra Dec 11, 2007
    Hi, my Motorola H700 is new and it never worked. I successfully paired it with my Blackberry but the connection fails. Any help? thanks
  • ascetic2000 Jan 12, 2008
    Just went through the instructions for pairing the motorola h700 bluetooth headset to my blackberry pearl and am very "frustrated" that after following all the instructions I cannot get this bluetooth headset to work!!!! Any suggestions or solutions to this problem? I've completed the pairing of my phone and headset (yes, I entered the password too) but still....no signal/sound comes out of the earpiece when connecting to calls??? SOS SOS???
  • JD30307 Feb 08, 2008
    I have used the H700 for well over a year. Unfortunately I keep losing them, and have to replace them. Until recently there was never an issue getting thr H700 to connect with me 8100. The last two H700s I have bought exhibit the same problem as others have described, where supposedly I successfully pair the device with my Blackberry Pearl, but when I open the boom nothing happens, and when I try to manually connect it says that the connection attempt failed.
    I tried Solution #4 and it worked perfectly, and continues to do so. Not sure why this extra step is necessary but at least it now works.
  • ITdefunct Feb 23, 2008
    I paired the Motorola H700 with my Blackberry Pearl 8100, but the headset still doesn't work. I selected the H700 device on my phone and hit connect, but I get the following message: "Handsfree connection to Motorola H700 failed." How can I correct this?
  • Anonymous Mar 26, 2008
    The Motorola headset H700 is not connecting to my blackberry 8100. It keeps on saying handsfree connection failed. I don't understand why, I need help!
  • annnne May 11, 2008
    how do i pair my motorola 700 bluetooth with my blackberry pearl?
  • Anonymous Jul 19, 2008
    Solution 7 worked for me. Start pressing the headset button before you open the boom, and keep pressing after you open it till it turns purple.
  • smile1234 Aug 07, 2008
    I am trying to connect my blackberry pearl 8100 via bluetooth to nokia N72, but it's givign the message connection failed
  • pauaris Aug 07, 2008
  • Anonymous Aug 26, 2008
    Solution 5 was amazing. It worked! YES! Thank you thank you..
  • norma2day Oct 09, 2008
    Yes ihave the same problem
  • Anonymous Jan 14, 2009
MY PHONE TELLS ME THAT ITS PAIRED WITH THE DEVICE BUT IT STILL ISNT WORKING
Posted on Oct 10, 2008
Open the boom on the headset and hold the button until it turns purple. Go to "Setup Bluetooth." Click "OK" when it tells you to be sure the device is in pairing mode. When the list of devices comes up, choose the H700. Enter passcode "0000."
The device will appear in your paired devices list in the "Setup BlueTooth" screen. Close the boom on the H700 then reopen it and hold the button until it turns purple. Click on the H700 in the devices list. Choose "connect."
This worked for me.
Posted on Jul 02, 2008
Re-pair the phone per Solution #4. If you get a message along the lines of "No new devices found", select "no" and then select "motorola H700". Click the track ball and select "Connect". That did it for me.
Posted on Apr 03, 2008
Solution number 4 above worked for me. I have two H700's here; the new one behaves this way, the old one works the first time through without needing the second pairing trick. Motorola must have changed something in their latest version of this headset.
Also, don't forget the next step, once paired, you need to shut the boom, re-open it and answer Yes to the popup about accepting a connection from your headset (and check the 'dont ask in future' box). Because I hadn't done the magical 2nd-pair-connect solution above, this phase just wouldn't work for me so I'm glad I found it!
Posted on Jan 23, 2008
Tried paring up the Pulsar 590E Stereo Bluetooth Headset... my 8100 had the little blue icon with arrows next to it and the led was blinking blue... but couldn't hear any music... grrrr
Posted on Jan 17, 2008
0000 is the universal passkey for bluetooth devices...
Posted on Jan 15, 2008
I was having trouble pairing my H700 to my Blackberry 8100. You have to do it twice. The first time for the initial pair where you type the passcode for the headset. After that when you open the headset you dont hear anything and it doesnt connect by just opening the boom. To solve that, you have to go to the paired devices list, select the H700, your Blackberry should have the oiption to connect. But first, close the boom on your headset and hold the button until it turns purple, then hit connect on the Blackberry, it should say Connected! You will notice a double arrow next the the bluetooth icon on the main screen when you open the boom, it will disconnect and reconnect every time after that.
I dont have a soultion but my phone ask's me for a numeric passkey and i dont have one???
Posted on Dec 23, 2007
TYPE 0000 FOR AN ACCESS CODE
Posted on Oct 05, 2007
Place the unit headset back in pairing mode by holding the call button for 1 to 5 seconds until the light turns purple. Then open the boom. Then try to reconnect .
Posted on May 04, 2007
I bought a bluetooth Insignia headset and I cannot hear the music on my blackberry pearl 8100 on the headset. But when I receive an outside call I can hear the music for a few minutes when I hang up.
Posted on Jan 04, 2008
2 Suggested Answers
otacon
  • 1944 Answers
SOURCE: Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
Posted on May 20, 2008
Can u reset the h700 headset
trying to pair a motorola h700 bluetooth to a blackberry pearl need to reset password
Jul 11, 2009 | Motorola Mobility H700 Wireless Headset
May 20, 2008 | Motorola Mobility H700 Wireless Headset
H700/ blackberry storm
On the Blackberry, Go to Options, Bluetooth. Select the blackberry button, Add Device, and search. If search doesn work, try listen. While these are going conduct the following on the Headset:
Close theheadset. Go to the phone and choose discover, or search. Open theheadsetand pressand hold the big button. It should then turn purple and should be recognized.
Also make sure thebatteryon theheadset is charged before doing this.
If this doesntwork: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
Jun 11, 2009 | Motorola Mobility H700 Wireless Headset
Pairing Issues
Try the passkey as 1234 and then try to connect.
May 27, 2009 | RIM BlackBerry Pearl 8100
Having problems pairing motorola h700 with blackberry curve
Mar 23, 2009 | Motorola Mobility H700 Wireless Headset
I have a problem with my bluetooth headset h500 pairing it?
The Blackberry Pearl was designed to work with 2.0 model bluetooth handsfree headsets. Whereas the Motorola H500 is compatible with 1.1 - 1.2 bluetooth apps only. I'm guessing you will have to dish out the cash on this one, sorry!
Jan 14, 2009 | Cell Phones
Pairing Issues
Thanks guys
U helped me bigtime.
Andrea313
Feb 05, 2008 | RIM BlackBerry Pearl 8100
Pairing HT820 with Blackberry Pearl
yeah... You need the 8120 pearl for that feature.. I am guessing you have an 8100?
Nov 22, 2007 | Motorola Mobility HT820 Wireless / Cable...
Pairing blkberry w/ h700
Hold down the call from an off position until the button lights up in purple color. Flips open the microphone boom. The purple light stays on. Click OK to start the pairing with Blackberry Pearl. When asked for passkey, key in 4 zeroes then press enter. Pairing should be complete from this point.
Oct 09, 2007 | Motorola Mobility H700 Wireless Headset
Motorola H700 Problems with BB Pearl 8100
Steps to pair a H700 headset with any bleutooth pone:
  1. Make sure the H700 fully chared (very important)!!
  2. Make sure the microphone boom is folded closed, i.e. power is off!
  3. Hold the call button for 1-5 seconds until the light is steady lit purple
  4. Flip out the microphone boom, the light should stay lit purple!
Now you are ready to pair the headset with your phone, so follow the pairing instructions of your phone.
Note: When prompted for the Passkey; it is most likely 0000 but the correct Passkey should be on the headset accessory instructions.
I must add that indeed my headset on occation (once or twice every three months) also loses its connection with the blackberry (a 8703e) . At which time I have to remove the headset from my phone bluetooth device list, and start the above described steps to pair my headset with the phone again.
Jun 02, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
1,339 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
