Question about Pinnacle PCTV HD Pro Stick USB 2.0 TV Tuner
I can't find any TV signals but I know they exist in this area
  • Derek Fuller
    Derek Fuller May 11, 2010
    Are you using a decent external antenna? Forget about the little "stick" aerial they provide with the tuner ...they are hopeless.
  • 42 Answers
Make sure you select the right setup for cable are air signals and the it is setup for atsc this is digital not ntsc which is air and the old standard 4:3 display
Posted on Feb 22, 2009
Screen freezes BBC Channels only. Unfreeze by switching off TV. Handset and TVs buttons fail to work. Minutes laterscreen freezes again. No problem with non BBC channels
turning tv off and on wont make it better
you on roof antenna or a cable tv
if antenna only
you may be in weak signal area
or a new construction site or buildings deflecting the signal
antenna problem or needs upgrade
go back to TV set up and re-tune tv to bbc if possible
if it freezes then you know its an interrupted signal
Mar 26, 2017 | Televison & Video
After the most recent software upgrade my under 12 month old Sony KDL75W850C Smart TV will no longer program our National Broadcasters 7 operating channels, not even recognising them as existing.
Signal strength of those seven channels may be below detection level. In this area, channels 3, 6, and 23 are consistently MIA no matter how often scanned.
Aug 14, 2016 | Sony Televison & Video
TV reception breaking up pretty bad because of rainy weather here in Brooklyn New York I live in an apartment and I'm using a Winegard amplified antenna does anyone have any suggestions what improving...
Television signals are at such high frequencoies they will be reflected form buildings and other objects, and attentuated by moisture in the air and through the leqaves of trees, etc. In large cities yourt TV singals can arrive from different paths Digital TV signals bounce as di the old "analog TV" signals but the technology allows the receiver to ignor singals that are out of phase so the picture is "clean" despite multipleversions of the signal arriving at the antenna at slightly different times. That said, if the signal is weak, there is little you can do other than experimanet with positioning the receivng antenna. Typically, building walls attentuate televisoin signals so locating the receving antenna close to a window often provides for stronger signal reception.
Amplified antennas cannot amplify what is not there. Moisture in the form of fog, rain and snow will attenuate television signals and if thre signals are marginal in good weather, they may be virtually not-existent in wet weather. Digital TV signals are threshold dependent. When they are toow eak, you won't see anything. Back in the old analog TV days, you could see a "snowy picture" but digital TV doesn't allow for that. The signal is either strong enough to be viewed or it is not.
You have few real options if you do not subscribe to cable or a satellite tv provider. Amplified antennas can help but if you need them you live in a marginal TV reception area to begin with and more prone to the vagaries of weather and the seasons.
Jan 18, 2015 | Winegard FL5500A FlatWave Amped Indoor...
Digital tv recorder
No, I don't think that is the issue... I don't think a TV exists that is incapable of decoding an analogue signal. We need more information about how your TV is connected... do you have cable or satellite? Do you use a cable or satellite "box"? How is your cable/satellite (if you have) box connected to your TV?
Oct 18, 2013 | Televison & Video
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Sep 27, 2011 | RCA Televison & Video
Is the PT50LC13 a digital TV? I didn't buy a converter box thinking that the TV didn't need one, but over time and unable to see any channel even with one, I wonder if the TV is indeed digital or not. I...
This tv only has an analog tuner (NTSC). That is why it works with cable and dvds. You will need a converter box to view OTA signals. (In addition, digital signals have a firm cut-off of signal strength; if the tuner doesn't get enough signal the channel will not be available.) So check with antennaweb.org or tvfool.com for details on the antenna direction for your area channels. antennaweb is very conservative in the channel listing it provides (even with the assumption of an external antenna). tvfool gives the color specifications of the antenna that should receive a given set of channels in your area.
The converter boxes are still available from select vendors but the government coupons program is not. Here's one that is listed as in stock: http://www.radioshack.com/product/index.jsp?productId=3150939&CAWELAID=198809366 . This is one of the standard definition output boxes. High Definition digital to analog converters also exist but are more expensive.
A cheap alternative may be to use a PC TV tuner (either USB or internal card) attached to the antenna and then output to the TV. This TV has a VGA port. (If you want to use component video in on the TV, you will need to check if your video card will support the non-RGB signal or a converter box for that.)
I wish that I could be of more help.
(many shows are available online either from the networks or from hulu.com)
Oct 11, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Cannot tune all digital cahnnels on Sharp aquos
Start by doing a factory settings/ defaults on the Sharp rather than a normal automatic retune.This should then be ok. You need to empty the existing presets first so it will find the new type of signal BBC is now using.
If still not working for BBC1 +2 then look at whether you have too much aerial signal strength. (ie a booster/splitter that you could bypass)
Nov 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I can not get my Olevia 32' tv to show cable. Does
what input do i put my tv on to get a picture it says no signal
Aug 09, 2009 | Olevia Televison & Video
I just purchased an amplified indoor HDTV Antenna to better receive HD tv. Is the LCD display supposed to be on all the time??? How can I get better reception from a broken picture even rotating the...
I don't know in what area you live & therefore how strong your reception area will be, but as a general rule an indoor antenna is never the best type of aerial to have to receive digital signals, you will always find that you pick up some good strong channels but more often the rest of the channels will be poor or non-existant & will constantly break-up/freeze etc. The best advice would be to try & fit an outdoor antenna if possible.
Jul 15, 2009 | Televison & Video
Help! How to get the best TV reception in this part of my house!
the area where you live creates reflexions or gaps in the signal (seeing how hard is to get the signal) maybe mountains around maybe big constructions or just simple a deep in the overall terrain. In all this cases maybe the solution is to get signal from the sky. This is done by: ex (dishnetwork, comcast) or any of those vendors with the little round antenna that you pay monthly. Now if the problem is only in that room of the house; then an xtra instalation can feed signal to that area from the other areas in the house where the signal is working good with you other tvs around the house. Just a couple of splitters and good isolated cable is needed to transport it.
Apr 14, 2009 | Televison & Video
Pinnacle PCTV HD Pro Stick USB 2.0 TV Tuner Logo
221 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
